  • 3206阅读
  • 5回复
[鑫创]一个京士顿的8gU盘,经过反复看教程,还是不行,贴出log,兄弟帮忙看看 [复制链接]
离线yff0216
只看楼主 倒序阅读 我要置顶 楼主  发表于: 2011-06-18
— 本帖被 mydigit 从 量产工具发布 移动到本区(2012-12-16) —
用的是U3S_MP_V2159
Device 1:0xB2
MP Version:2.159
INI_File_Name:6691_TSB_43nm_D2_CDROM.INI
Random delay 0 msec
--- Download MP ISP ---
CE-0, Flash ID=98-D7-94-32-76-55-0A-00
CE-1, Flash ID=98-D7-94-32-76-55-0A-00
Found BACKUP Table (000000BB-0001)
Defect Table (00000200-0004)
  Original Bad Block - 0:0x0319
  Original Bad Block - 0:0x03DE
  Original Bad Block - 0:0x0580
  Original Bad Block - 0:0x0764
  Original Bad Block - 0:0x085A
  Original Bad Block - 0:0x085C
  Original Bad Block - 0:0x0A2B
  Original Bad Block - 0:0x0A2D
  Original Bad Block - 0:0x0DC7
  Original Bad Block - 0:0x0E0F
  Original Bad Block - 1:0x0092
  Original Bad Block - 1:0x02C0
  Original Bad Block - 1:0x07EC
  Original Bad Block - 1:0x07F0
  Original Bad Block - 1:0x0906
  Original Bad Block - 1:0x0BA6
  Original Bad Block - 1:0x0C42
  Original Bad Block - 1:0x0C46
  Original Bad Block - 1:0x0C74
  Original Bad Block - 1:0x0D55
  Original Bad Block - 1:0x0E38
Defect Table shows 8179 Good blocks, 21 Bad blocks
SafeErase (0,4100)
  Erase failed Block - 0:0:0x0319
  Erase failed Block - 0:0:0x03DE
  Erase failed Block - 0:0:0x0580
  Erase failed Block - 0:0:0x0764
  Erase failed Block - 0:0:0x085A
  Erase failed Block - 0:0:0x085C
  Erase failed Block - 0:0:0x0A2B
  Erase failed Block - 0:0:0x0A2D
  Erase failed Block - 0:0:0x0DC7
  Erase failed Block - 0:0:0x0E0F
  ---> Max Bad of Plane (3,3)
SafeErase (1,4100)
  Erase failed Block - 1:0:0x0092
  Erase failed Block - 1:0:0x02C0
  Erase failed Block - 1:0:0x07EC
  Erase failed Block - 1:0:0x07F0
  Erase failed Block - 1:0:0x0906
  Erase failed Block - 1:0:0x0BA6
  Erase failed Block - 1:0:0x0C42
  Erase failed Block - 1:0:0x0C46
  Erase failed Block - 1:0:0x0C74
  Erase failed Block - 1:0:0x0D55
  Erase failed Block - 1:0:0x0E38
  ---> Max Bad of Plane (5,1)
  ---> Max BAD/DIE = 5
Total good blocks after SCAN: 8179 / 8200, Bad block=21
==> 2-Plane mode
Max. Bad Block Allowed = 371(21)
Adjust Max LBA = 15646720, 15646656
MaxWindows=4/1910, MaxLBA=15646656, Size=7639 MB
Max BAD of one plane is 5 (46),8200,1,2
RootSector=0x1D71,Sec/Cluster=32, SuperPage=32 ---> Alignment=15
Boot Block=0x0001,0x0002
Lun0(15246892), Lun1(399764), Public=15246892, Secure=0, CDROM=399764
Special FE Config = 56-0B-00
Defect Table Block=0x0004
--- Download ISP Code:C:\USERS\ADMINISTRATOR\DESKTOP\U3S_MP_V2159111111111111111\U3S_MP_V2159\ISP_CODE\6691_B3-A_20100331_VA10F00_9083.BIN---
--- ISP Code installed.
Public,Secure,CDROM = 15246892,0,399764
SN=002269C5A646F16122CF14A2
=== Preformat Done ===
Low Level Format DONE
Store INI/ERROR MSG to Block-0x0001:79.
CDROM image:D:\1.iso
Total=15646656,CDROM=399764, PublicArea=15246764, SecureArea=0
Create SECURE(CDROM=1,Public=7444 MB,Secure=0 MB)
   Write LBA(0x00000000,128) Fail !
### Err: SECURE failed(41).
本帖最近打赏记录:共1条打赏M币+1
离线shuishou
只看该作者 1楼 发表于: 2011-06-19
离线yff0216
只看该作者 2楼 发表于: 2011-06-19
离线shuishou
只看该作者 3楼 发表于: 2011-06-19
离线yff0216
只看该作者 4楼 发表于: 2011-06-19
离线shuishou
只看该作者 5楼 发表于: 2011-06-19
本帖最近打赏记录:共1条打赏M币+5
