  • 8340阅读
  • 13回复
(已解决)金士顿G3鑫创主控量产失败,求救... [复制链接]
离线mofaji
只看楼主 倒序阅读 我要置顶 楼主  发表于: 2011-07-19
已解决,谢谢大家了。有空再整理发上来分享。
现在插U盘进电脑,右下角有显示"可移动设备"的图标,但在"我的电脑"里没有显示盘符."磁盘管理"也没有显示.量产工具也不能认出来啦.
这种情况用短接法能救回不?这个U盘好难打开,以前那些一扭就开了.
量产前的U盘信息:
芯片制造商: SSS(鑫创)
  芯片型号: SSS6691/SK6215
产品制造商: Kingston
  产品型号: DataTraveler G3
量产前量产工具获取的信息:
---------------- Device 1------------------
  MP Tool Version : V2.177_T2
  INI File Name : 99C4416-303.A00LF.INI
  Format Date : 2011-06-20 11:30:31
  Flash Part No : Toshiba 3xnm D2 MLC
  CE-0, Flash ID=98-D7-94-32-76-55-0C
  VID : 0x0951
  PID : 0x1643
  Vendor Name = Kingston
  Product Name = DataTraveler G3
  Serial Number = 001CC07CEB7FFB61491E2057
  Volume Label = KINGSTON
  F/W Version : 0xB5
  ISP Version : VB3.01
  Flash R/W Timing : 33.3ns
  Channel : Byte Mode
  Homogeneous Mode : On
  HID Function : Disable
  Planes(F/W) : 1
  Pages/Block : 128 pages
  Max Current : 100 mA
  Total Blocks : 4100
  Bad Blocks : 930
  Capacity : 7541072 Sectors, 3861028864 Bytes
                   3770536 KBytes, 3682.16 MBytes, 3.60 GBytes
量产失败的报告:
Device 1:0xB5
    MP Version:2.162
    INI_File_Name:
    Random delay 0 msec
    --- Download MP ISP ---
    CE-0, Flash ID=98-D7-94-32-76-55-0C-00
    Found BACKUP Table (000000BB-0001)
    Defect Table (00000200-0004)
        Original Bad Block - 0:0x0000
        Original Bad Block - 0:0x0013
        Original Bad Block - 0:0x0048
        Original Bad Block - 0:0x006C
        Original Bad Block - 0:0x00AC
        Original Bad Block - 0:0x0135
        Original Bad Block - 0:0x029C
        Original Bad Block - 0:0x04A8
        Original Bad Block - 0:0x04D3
        Original Bad Block - 0:0x04FC
        Original Bad Block - 0:0x0514
        Original Bad Block - 0:0x062E
        Original Bad Block - 0:0x0683
        Original Bad Block - 0:0x0758
        Original Bad Block - 0:0x07A1
        Original Bad Block - 0:0x0801
        Original Bad Block - 0:0x0803
        Original Bad Block - 0:0x0805
        Original Bad Block - 0:0x0807
        Original Bad Block - 0:0x0809
        Original Bad Block - 0:0x080B
        Original Bad Block - 0:0x080D
        Original Bad Block - 0:0x080F
        Original Bad Block - 0:0x0811
        Original Bad Block - 0:0x0813
        Original Bad Block - 0:0x0815
        Original Bad Block - 0:0x0817
        Original Bad Block - 0:0x0874
        Original Bad Block - 0:0x094F
        Original Bad Block - 0:0x09A3
        Original Bad Block - 0:0x09D2
        Original Bad Block - 0:0x0A14
        Original Bad Block - 0:0x0A57
        Original Bad Block - 0:0x0A82
        Original Bad Block - 0:0x0AEE
        Original Bad Block - 0:0x0BDB
        Original Bad Block - 0:0x0C11
        Original Bad Block - 0:0x0D41
        Original Bad Block - 0:0x0D7D
        Original Bad Block - 0:0x0EE3
        Original Bad Block - 0:0x0F2C
        Original Bad Block - 0:0x0F9D
        Original Bad Block - 0:0x0FA1
    Defect Table shows 4057 Good blocks, 43 Bad blocks
    SafeErase (0,4100)
        Erase failed Block - 0:0:0x0000
        Erase failed Block - 0:0:0x0013
        Erase failed Block - 0:0:0x0048
        Erase failed Block - 0:0:0x006C
        Erase failed Block - 0:0:0x00AC
        Erase failed Block - 0:0:0x0135
        Erase failed Block - 0:0:0x029C
        Erase failed Block - 0:0:0x04A8
        Erase failed Block - 0:0:0x04D3
        Erase failed Block - 0:0:0x04FC
        Erase failed Block - 0:0:0x0514
        Erase failed Block - 0:0:0x062E
        Erase failed Block - 0:0:0x0683
        Erase failed Block - 0:0:0x0758
        Erase failed Block - 0:0:0x07A1
        Erase failed Block - 0:0:0x0801
        Erase failed Block - 0:0:0x0803
        Erase failed Block - 0:0:0x0805
        Erase failed Block - 0:0:0x0807
        Erase failed Block - 0:0:0x0809
        Erase failed Block - 0:0:0x080B
        Erase failed Block - 0:0:0x080D
        Erase failed Block - 0:0:0x080F
        Erase failed Block - 0:0:0x0811
        Erase failed Block - 0:0:0x0813
        Erase failed Block - 0:0:0x0815
        Erase failed Block - 0:0:0x0817
        Erase failed Block - 0:0:0x0874
        Erase failed Block - 0:0:0x094F
        Erase failed Block - 0:0:0x09A3
        Erase failed Block - 0:0:0x09D2
        Erase failed Block - 0:0:0x0A14
        Erase failed Block - 0:0:0x0A57
        Erase failed Block - 0:0:0x0A82
        Erase failed Block - 0:0:0x0AEE
        Erase failed Block - 0:0:0x0BDB
        Erase failed Block - 0:0:0x0C11
        Erase failed Block - 0:0:0x0D41
        Erase failed Block - 0:0:0x0D7D
        Erase failed Block - 0:0:0x0EE3
        Erase failed Block - 0:0:0x0F2C
        Erase failed Block - 0:0:0x0F9D
        Erase failed Block - 0:0:0x0FA1
        ---> Max Bad of Plane (8,14)
        ---> Max BAD/DIE = 14
    Total good blocks after SCAN: 4057 / 4100, Bad block=43
    ==> 2-Plane mode
    Max. Bad Block Allowed = 183(43)
    Adjust Max LBA = 7823360, 7823296
    MaxWindows=2/1910, MaxLBA=7823296, Size=3819 MB
    Max BAD of one plane is 14 (45),4100,1,1
    RootSector=0xF4B,Sec/Cluster=32, SuperPage=32 ---> Alignment=21
    Boot Block=0x0001,0x0002
    Lun0(7823296), Lun1(0), Public=7823296, Secure=0, CDROM=0
    Special FE Config = 54-0B-00
    Defect Table Block=0x0004
    --- Download ISP Code:C:\6691MP_VER2162_ALL\ISP_CODE\6691_B3-A_20100331_VA10F00_9083.BIN---
    --- ISP Code installed.
    Public,Secure,CDROM = 7823296,0,0
    SN=00215D35A38AF17136AA14DC
    === Preformat Done ===
    Low Level Format DONE
    Store INI/ERROR MSG to Block-0x0001:79.
    LBATest 10M activate
    Total=0,CDROM=0, PublicArea=-128, SecureArea=0
    Create SECURE(CDROM=0,Public=2097151 MB,Secure=0 MB)
      Write LBA(0x00002000,128) Fail !
    ### Err: SECURE failed(41).
量产工具版本:
6691MP_Ver2162_All
[ 此帖被mofaji在2011-07-19 22:41重新编辑 ]
本帖最近打赏记录:共1条打赏M币+1
离线木鱼
只看该作者 1楼 发表于: 2011-07-19
离线sky文
只看该作者 2楼 发表于: 2011-07-19
离线gamester
只看该作者 3楼 发表于: 2011-07-19
离线gamester
只看该作者 4楼 发表于: 2011-07-19
离线mmbb88
只看该作者 5楼 发表于: 2011-07-19
离线mofaji
只看该作者 6楼 发表于: 2011-07-19
回 3楼(gamester) 的帖子
本帖最近打赏记录:共1条打赏M币+1
离线mofaji
只看该作者 7楼 发表于: 2011-07-19
回 1楼(木鱼) 的帖子
离线mofaji
只看该作者 8楼 发表于: 2011-07-19
回 2楼(sky文) 的帖子
离线mofaji
只看该作者 9楼 发表于: 2011-07-30
