  • 32540阅读
  • 8回复
[网络]【拆光纤猫第二弹】ZTE中兴 ZXA10 F420 ONU 拆解 [复制链接]
离线miao_s
只看楼主 倒序阅读 我要置顶 楼主  发表于: 2011-09-12
闲着没事 再拿个坏的猫拆拆……
正面
背面
侧面  Monitor是什么 刷机的?
主板
2颗电话IC
HUB芯片
光信号处理的??
Flash  16M
Memory: 14088k/16384k available (1622k kernel code, 2276k reserved, 286k data, 100k init)
主控芯片
参数(超级终端里看来的):
CPU revision is: 00018448
Primary instruction cache 16kB, physically tagged, 4-way, linesize 16 bytes.
Primary data cache 8kB, 4-way, linesize 16 bytes.
CPU frequency 300.00 MHz
Using 150.000 MHz high precision timer.
两粒华邦
光单元。由于“地形”比较复杂 所以没把金属外壳掰开来了。
TTL线伺候
TTL线连接方法
分解完毕。。
附上TTL信息:
  1. Error: Out of Environment space
  2. Error: Out of Environment space
  3. Error: Out of Environment space
  4. Error: Out of Environment space
  5. Basic POST completed...     Success.
  6. Last reset cause: Hardware reset (Power-on reset)
  7. PSPBoot1.4 rev: 1.4.3.7
  8.      D2 TECHNOLOGIES
  9.    ======================
  10. Flash Manufacture ID    : EON_FLASH_ID
  11. Flash_Family            : FLASH_FAMILY_EON
  12. Warning: Flash Device ID is Unknown!
  13. Use EON_EN29LV640BT as default
  14. Flash_Device_ID         : EON_EN29LV640BT
  15. Flash_Layout            : FLASH_LAYOUT_BOTTOM
  16. Press ESC for monitor... 3321
  17. (psbl)
  18. Booting...
  19. Launching kernel decompressor.
  20. Starting LZMA Uncompression Algorithm.
  21. Compressed file is LZMA format.
  22. Kernel decompressor was successful ... launching kernel.
  23. LINUX started...
  24. Config serial console: console=ttyS0,115200n8r root=31:5
  25. Linux version 2.6.10_dev-malta-mips2_fp_len (arthur@localhost.localdomain) (gcc version 3.4.3) #78 Thu Mar 25 09:30:20 CST 2010
  26. CPU revision is: 00018448
  27. TNETV1020VDB Communication Processor detected
  28. Determined physical RAM map:
  29. memory: 14001000 @ 00000000 (reserved)
  30. memory: 0001f000 @ 14001000 (ROM data)
  31. memory: 0020e000 @ 14020000 (reserved)
  32. memory: 00dd2000 @ 1422e000 (usable)
  33. Built 1 zonelists
  34. Kernel command line:  console=ttyS0,115200n8r root=31:5
  35. Primary instruction cache 16kB, physically tagged, 4-way, linesize 16 bytes.
  36. Primary data cache 8kB, 4-way, linesize 16 bytes.
  37. Synthesized TLB refill handler (20 instructions).
  38. Synthesized TLB load handler fastpath (32 instructions).
  39. Synthesized TLB store handler fastpath (32 instructions).
  40. Synthesized TLB modify handler fastpath (31 instructions).
  41. PID hash table entries: 128 (order: 7, 2048 bytes)
  42. CPU frequency 300.00 MHz
  43. Using 150.000 MHz high precision timer.
  44. Dentry cache hash table entries: 4096 (order: 2, 16384 bytes)
  45. Inode-cache hash table entries: 2048 (order: 1, 8192 bytes)
  46. Freeing Bootloader reserved memory [0x0001f000 @ 0x14001000]
  47. Memory: 14088k/16384k available (1622k kernel code, 2276k reserved, 286k data, 100k init)
  48. Mount-cache hash table entries: 512 (order: 0, 4096 bytes)
  49. Checking for 'wait' instruction...  available.
  50. spawn_desched_task(00000000)
  51. desched cpu_callback 3/00000000
  52. ksoftirqd started up.
  53. softirq RT prio: 24.
  54. desched cpu_callback 2/00000000
  55. desched thread 0 started up.
  56. TI Optimizations: Allocating TI-Cached Memory Pool.
  57. Warning: Number of buffers is not configured. Setting default to 512
  58. Using 512 Buffers for TI-Cached Memory Pool.
  59. NSP Optimizations: Succesfully allocated TI-Cached Memory Pool.
  60. NET: Registered protocol family 16
  61. Can't analyze prologue code at 941b3c00
  62. Squashfs 2.1-r2 (released 2004/12/15) (C) 2002-2004 Phillip Lougher
  63. LZMA decompressor support based on LZMA SDK 4.05 by Oleg I.Vdovikin
  64. Serial: 8250/16550 driver $Revision: 1.90 $ 1 ports, IRQ sharing disabled
  65. ttyS0 at  (irq = 15) is a 16550A
  66. io scheduler noop registered
  67. PPP generic driver version 2.4.2
  68. NET: Registered protocol family 24
  69. Error getting CPMAC Configuration params for instance:0
  70. Environment Variable:MACCFG_A not set in bootloader
  71. Setting Default configuration params for CPMAC instance:0
  72. MAC CFG : Tx Interrupts off , threshold : 20
  73. Error getting CPMAC Configuration params for instance:1
  74. Environment Variable:MACCFG_B not set in bootloader
  75. Setting Default configuration params for CPMAC instance:1
  76. MAC CFG : Tx Interrupts off , threshold : 20
  77. TI CPMAC Linux DDA version 2.0 - CPMAC DDC version 0.3
  78. Cpmac: Installed 2 instances.
  79. Cpmac driver is allocating buffer memory at init time.
  80. elevator: using noop as default io scheduler
  81. Primary flash device: Found 1 x16 devices at 0x0 in 16-bit bank
  82. Amd/Fujitsu Extended Query Table at 0x0040
  83. cfi_fixup, detect mfr = 7f, id = cb
  84. cfi_fixup, detect mfr = 7f, id = cb
  85. number of CFI chips: 1
  86. cfi_cmdset_0002: Disabling erase-suspend-program due to code brokenness.
  87. avalanche flash device: 0x800000 at 0x10000000.
  88. Looking for mtd device :mtd0:
  89. Found a mtd0 image (0x150000), with size (0x240000).
  90. Creating 1 MTD partitions on "Primary flash device":
  91. 0x00150000-0x00390000 : "mtd0"
  92. Looking for mtd device :mtd1:
  93. Found a mtd1 image (0x50000), with size (0x100000).
  94. Creating 1 MTD partitions on "Primary flash device":
  95. 0x00050000-0x00150000 : "mtd1"
  96. Looking for mtd device :mtd2:
  97. Found a mtd2 image (0x0), with size (0x20000).
  98. Creating 1 MTD partitions on "Primary flash device":
  99. 0x00000000-0x00020000 : "mtd2"
  100. Looking for mtd device :mtd3:
  101. Found a mtd3 image (0x390000), with size (0x70000).
  102. Creating 1 MTD partitions on "Primary flash device":
  103. 0x00390000-0x00400000 : "mtd3"
  104. Looking for mtd device :mtd4:
  105. Found a mtd4 image (0x400000), with size (0x100000).
  106. Creating 1 MTD partitions on "Primary flash device":
  107. 0x00400000-0x00500000 : "mtd4"
  108. Looking for mtd device :mtd5:
  109. Found a mtd5 image (0x500000), with size (0x240000).
  110. Creating 1 MTD partitions on "Primary flash device":
  111. 0x00500000-0x00740000 : "mtd5"
  112. NET: Registered protocol family 2
  113. IP: routing cache hash table of 512 buckets, 4Kbytes
  114. TCP: Hash tables configured (established 1024 bind 2048)
  115. NET: Registered protocol family 1
  116. NET: Registered protocol family 17
  117. 802.1Q VLAN Support v1.8 Ben Greear <greearb@candelatech.com>
  118. All bugs added by David S. Miller <davem@redhat.com>
  119. VFS: Mounted root (squashfs filesystem) readonly.
  120. FWBGetBlockSize=0x10000.
  121. FWBGetBlockSize=0x10000.
  122. Freeing unused kernel memory: 100k freed
  123. @@@@@@@@init started:  BusyBox v1.00 (2010.03.25-01:30+0000) multi-call binary@@@@@
  124. Algorithmics/MIPS FPU Emulator v1.5
  125. [/etc/init.d/S03config.sh]
  126. Mounting proc and var ....
  127. avalanche_led: module license 'proprietary' taints kernel.
  128. ......
  129. EPON F420 D2 Alphanetworks
  130. ......
  131. Start xmldb ...
  132.     ----
  133.     Starting D2Tech vPort.
  134.     ----
  135.
  136. D2 OSAL kernel module 1.5 initialized
  137. D2 OSAL kernel module 1.5 initialized
  138. [/etc/scripts/misc/profile.sh] get ...
  139. lkm.c 133: devname /dev/d2vtspr
  140. /dev/d2vtspr registered successfuly @ 252.
  141. [/etc/scripts/misc/defnodes.sh] ...
  142. SH [/etc/defnodes/S10syncnodes.sh] ...
  143. SH [/etc/defnodes/S11setext.sh] ...
  144. PHP [/etc/defnodes/S12setnodes.php] ...
  145. PHP [/etc/defnodes/S40brand.php] ...
  146. [/etc/scripts/misc/defnodes.sh] Done !!
  147. [/etc/templates/timezone.sh] ...
  148. _tic.c(506) SLIC init success:1
  149. Setup Lan IP!
  150. FWBGetBlockSize=0x10000.
  151. FWBGetBlockSize=0x10000.
  152. FWBGetBlockSize=0x10000.
  153. FWBGetBlockSize=0x10000.
  154. device eth0 entered promiscuous mode
  155. :init i2c-driver adapt for eeprom
  156. :now probe i2c
  157. [/etc/init.d/S03config.sh] done!
  158. [/etc/init.d/S10system.sh]
  159. [/etc/templates/thttpd.sh] [start] ...
  160. Starting THTTPD ...
  161. [/etc/templates/housekeeper.sh] [start] ...
  162. [/var/run/housekeeper_start.sh] ...
  163. Starting housekeeper ...
  164. [/etc/templates/dns.sh] [start] ...
  165. auto ,zh ,en ,dir = /www
  166. [/var/run/dns_start.sh] ...
  167. [/etc/templates/flash_agent.sh] [start] ...
  168. _tic.c(506) SLIC init success:2
  169.                D2 Technologies
  170.       _   _  __
  171.      / | '/  /_  _  /_ _  _  /_  _  ._   _
  172.     /_.'/_  //_'/_ / // //_///_//_///_'_\
  173.                                 _/
  174.              Unified Communication Products
  175.                  www.d2tech.com
  176.           +D2Tech+ VTSP_RT VTSP_R_1_4_12
  177. [/var/run/flash_agent_start.sh] ...
  178. >>> ALPHA Flash Agent:
  179. [/etc/templates/logd.sh] ...
  180. [/var/run/logd_start.sh] ...
  181. Starting logd ...
  182. >>> ALPHA Log:
  183. /bin/alphaLogd: create logd_ipc(3) OK !
  184. [/etc/templates/diap.sh] [start] ...
  185. [/var/run/diap_start.sh] ...
  186. Starting DIAP ...
  187. [/etc/templates/telnetd.sh] ...
  188. [/var/run/telnetd_start.sh] ...
  189. Starting telnetd ...
  190. [/etc/templates/oam.sh] [start] ...
  191. [/var/run/oam_start.sh] ...
  192. Starting OAM ...
  193. [/etc/templates/verupdate.sh] [start] ...
  194. [/var/run/verupdate_start.sh] ...
  195. Starting Version Update ...
  196. [/etc/templates/megaco.sh] [start] ...
  197. [/var/run/megaco_start.sh] ...
  198. Starting Megaco ...
  199. [/etc/init.d/S10system.sh] done!
  200. rcS done!
  201. BusyBox v1.00 (2010.03.25-01:30+0000) Built-in shell (msh)
  202. Enter 'help' for a list of built-in commands.
  203. Alpha # log_init: shmget failed, retry[1]rt_setup: fd 4
  204. [EventSend]: send event msg to ipc fd(5), path = /tmp/mg_sock error! 2
  205. [EventSend]: send event msg to ipc fd(5), path = /tmp/mg_sock error! 2
  206. MG[Info]: Megaco Stack Version 2.5.1.5  Copyright (c) 2009 RADVISION
  207. MG[Info]: Stack initialed successfully.
  208. MG[Info]: Starting Media Gateway.
还有  打断载入系统后的命令:
  8.      D2 TECHNOLOGIES
  17. (psbl) help
  18. reboot            version           info              fa
  19. printenv          setenv            unsetenv          defragenv
  20. fmt               boot              dm                oclk
  21. help              tftp
  22. (psbl) dm
  23. 0xb4000000: aaaaaaaa 33333333 cccccccc 0f0f0f0f - ....3333........
  24. 0xb4000010: f0f0f0f0 00ff00ff ff00ff00 0000ffff - ................
  25. 0xb4000020: ffff0000 00000000 ffffffff 00000000 - ................
  26. 0xb4000030: 55555555 aaaaaaaa 33333333 cccccccc - UUUU....3333....
  27. 0xb4000040: 0f0f0f0f f0f0f0f0 00ff00ff ff00ff00 - ................
  28. 0xb4000050: 0000ffff ffff0000 00000000 ffffffff - ................
  29. 0xb4000060: 00000000 55555555 aaaaaaaa 33333333 - ....UUUU....3333
  30. 0xb4000070: cccccccc 0f0f0f0f f0f0f0f0 00ff00ff - ................
  31. (psbl) fa
  32. Current Flash Allocation:
  33. section :   PSBL, base : 0xb0000000, size :      65536 bytes
  34. section :    ENV, base : 0xb0020000, size :      65536 bytes
  35. unallocated Space Start: 0xb0030000
  36. unallocated Space End  : 0xb0800000
  37. (psbl) boot
本帖最近打赏记录:共11条打赏 ,M币+58 ,专家+1
12
关键词: 光纤猫ZTE中兴
离线jyl888
只看该作者 1楼 发表于: 2011-09-12
离线xiaorourou
只看该作者 2楼 发表于: 2011-09-12
离线zeng_zww
只看该作者 3楼 发表于: 2011-09-12
回 楼主(miao_s) 的帖子
离线wangili999
只看该作者 4楼 发表于: 2012-02-10
离线sweetx2004
只看该作者 5楼 发表于: 2012-04-11
离线lon91ong
只看该作者 6楼 发表于: 2013-01-20
回 5楼(sweetx2004) 的帖子
离线ericliu
只看该作者 7楼 发表于: 2015-11-26
离线wb1809
只看该作者 8楼 发表于: 2018-04-05
