配置[OEM]
PN=6692 + I&M 2xnm Normal Flash (256 page,8KB)
Note=6692_B5-IM_20110422_VB88200_B3EF.BIN
VID=0x0951
PID=0x1643
VENDOR_NAME="Kingston"
PRODUCT_NAME="DataTraveler G3"
STRING_DESC_ENABLE=1
SN_CustomerCode=0x0F
[FEATURE_SETTING]
FLASH_OP="ALL123"
ID35=1
ID43=0
ID45=1
[ISP]
Code=6692_B5-IM_20110422_VB88200_B3EF.BIN
[FLASH]
ForceFlashID=8988244BA9
Device 1:0xB5
MP Version:2.162
INI_File_Name:
Random delay 0 msec
--- Download MP ISP ---
CE-0, Flash ID=89-88-24-4B-A9-00-AD-DE
Searching SORTING BOARD table ...
--> Not Found
Found BACKUP Table (0000023A-0002)
Found BACKUP Table (0000123A-0012)
Original Bad Block - 0:0x0002
Original Bad Block - 0:0x0003
Original Bad Block - 0:0x0006
Original Bad Block - 0:0x0007
Original Bad Block - 0:0x0E9E
中间省略
Original Bad Block - 0:0x0E9F
Defect Table shows 3168 Good blocks, 928 Bad blocks
SafeErase (0,4096)
Erase failed Block - 0:0:0x0002
Erase failed Block - 0:0:0x0003
中间 省略
Erase failed Block - 0:0:0x0E9F
---> Max Bad of Plane (208,256)
---> Max BAD/DIE = 256
Total good blocks after SCAN: 3168 / 4096, Bad block=928
==> 2-Plane mode
Max. Bad Block Allowed = 174(928)
### Error: Too many bad block.
### Error: Low level format failed ###
SafeErase (0,4096)
省略
哪位高手帮我看下这份报告,到底错在哪里,能不能修复量产,或者有另量产工具.谢谢
