  • 9969阅读
  • 10回复
[鑫创]量产提示Error8问题 [复制链接]
离线二度沙
只看楼主 倒序阅读 我要置顶 楼主  发表于: 2011-09-24
— 本帖被 鱼水情 从 量产工具发布 移动到本区(2011-09-25) —
U盘钢号:DT1G3/8GB   04415-312. AOOLF 5V
SSS6692+HY 量产
量产工具提示:  Error8
[OEM]
PN=6692 + Hynix 26nm Normal Flash (256P,8KB)
Note=6692_B5-IM_20110422_VB88200_B3EF.BIN
VID=0x0951
PID=0x1643
VENDOR_NAME="Kingston"
PRODUCT_NAME="DataTraveler G3"
STRING_DESC_ENABLE=1
SN_CustomerCode=0x0F
[FEATURE_SETTING]
FLASH_OP="ALL123"
ID17=1
ID35=1
[CDROM]
CDROM_ISO=E:\XMPE.iso
[ISP]
Code=6692_B5-IM_20110422_VB88200_B3EF.BIN
量产    Report
Starting Time: 23:34:44
Device 1:0xB5
    MP Version:2.182
    INI_File_Name:6692_HY26_256P_8KB.INI
    Random delay 0 msec
    --- Download MP ISP ---
    Auto CE: 0x00 0xFF 0xFF 0xFF 0xFF 0xFF 0xFF 0xFF
    CE-0, Flash ID=AD-DE-94-D2-04-43-AD-DE
    Page/Block=256
    Searching SORTING BOARD table ...
    --> Not Found
    Scan (0,4096)
        Original Defect Block - 0:0:0x0002
        Original Defect Block - 0:0:0x0004
        Original Defect Block - 0:0:0x0005
                             中间省略
                Original Defect Block - 0:0:0x0896
        Original Defect Block - 0:0:0x0897
        ---> Max Bad of Plane (52,60)
        ---> Max BAD/DIE = 60
    Total good blocks after SCAN: 3872 / 4096, Bad block=224
    ==> 2-Plane mode
    Adjust Max LBA = 15441920, 15302592
    MaxWindows=2/1868, MaxLBA=15302592, Size=7471 MB
    Max BAD of one plane is 60 (64),4096,1,1
    RootSector=0xEF7,Sec/Cluster=64, SuperPage=64 ---> Alignment=9
    Boot Block=0x010C,0x010E
    Lun0(15302592), Lun1(0), Public=15302592, Secure=0, CDROM=0
    Special FE Config = 54-0B-00
    Defect Table Block=0x00BA
    --- Download ISP Code:E:\DOWNLOAD\LIANGCHAN\6692_HY26_MP_V2182\ISP_CODE\6692_B5-IM_20110422_VB88200_B3EF.BIN---
    --- ISP Code installed.
    Public,Secure,CDROM = 15302592,0,0
    PHY: E2/E4/E6=72h/36h/04h,  D0/C0/CFG10=DFh/0Bh/87h
    SN=000D874F6D41FB918F57202E
    === Preformat Done ===
    Low Level Format DONE
    Store INI/ERROR MSG to Block-0x010C:78.
    ### Error: Device capacity is 0 bytes
Ending Time: 23:34:52
      向各位求助这种量产问题错在那里,怎样解决,量产有时出现Error8或者Error43如何解除这些错误
本帖最近打赏记录:共1条打赏M币+1
离线木鱼
只看该作者 1楼 发表于: 2011-09-25
只看该作者 2楼 发表于: 2011-09-25
离线gamester
只看该作者 3楼 发表于: 2011-09-25
离线czwhehehe
只看该作者 4楼 发表于: 2011-09-25
离线二度沙
只看该作者 5楼 发表于: 2011-09-25
回 3楼(gamester) 的帖子
离线二度沙
只看该作者 6楼 发表于: 2011-09-25
回 4楼(czwhehehe) 的帖子
离线lves
只看该作者 7楼 发表于: 2011-10-18
离线sys170
只看该作者 8楼 发表于: 2011-10-28
离线skjoe
只看该作者 9楼 发表于: 2012-12-08
回 3楼(gamester) 的帖子
