  • 7504阅读
  • 5回复
[鑫创]ERROR43错误SSS6692量产不成功! [复制链接]
离线经典含具
只看楼主 倒序阅读 我要置顶 楼主  发表于: 2011-09-30
如题,一个金士顿G3  4GB的U盘,主控芯片上面写的是:
6692
H2-U6C
J5P01-080B
1126
flash芯片上面是:
115T051LF
HVPF4F5
1122
115T051LF-3S-1
钢口号是:
DTIG3/4GB
C4416-303.A00LF 5V
0S 5410779 TAIWAN
用了好多不同版本的量产工具都不成功,最后居然不认U盘了,我短接一下又认识了,但还是不成功。请大大们帮忙啊!帮我找一款合适的量产工具和BIN,急死我了!!反复的ERROR43 报告如下:
Starting Time: 21:45:22
Device 1:0xB5
MP Version:2.182
INI_File_Name:6691_Kingston G3 CDROM Flash.INI
Random delay 0 msec
--- Download MP ISP ---
### No support [SCAN_RDY_BSY-0xFF 0x30] !
CE-0, Flash ID=98-D7-94-32-76-55-0D-00
--> ROOT is not found
Scan (0,4100)
  Original Defect Block - 0:0:0x0000
  Original Defect Block - 0:0:0x0002
  Original Defect Block - 0:0:0x0024
  Original Defect Block - 0:0:0x002E
  Original Defect Block - 0:0:0x006E
  Original Defect Block - 0:0:0x0086
  Original Defect Block - 0:0:0x008E
  Original Defect Block - 0:0:0x00A4
  Original Defect Block - 0:0:0x00CE
  Original Defect Block - 0:0:0x00D2
  Original Defect Block - 0:0:0x0100
  Original Defect Block - 0:0:0x012A
  Original Defect Block - 0:0:0x0150
  Original Defect Block - 0:0:0x0176
  Original Defect Block - 0:0:0x0184
  Original Defect Block - 0:0:0x01A8
  Original Defect Block - 0:0:0x0204
  Original Defect Block - 0:0:0x020C
  Original Defect Block - 0:0:0x0214
  Original Defect Block - 0:0:0x024A
  Original Defect Block - 0:0:0x026C
  Original Defect Block - 0:0:0x0272
  Original Defect Block - 0:0:0x02A0
  Original Defect Block - 0:0:0x02A8
  Original Defect Block - 0:0:0x02C4
  Original Defect Block - 0:0:0x02C8
  Original Defect Block - 0:0:0x02F8
  Original Defect Block - 0:0:0x02FC
  Original Defect Block - 0:0:0x030E
  Original Defect Block - 0:0:0x0326
  Original Defect Block - 0:0:0x033A
  Original Defect Block - 0:0:0x035C
  Original Defect Block - 0:0:0x036A
  Original Defect Block - 0:0:0x0380
  Original Defect Block - 0:0:0x038E
  Original Defect Block - 0:0:0x039C
  Original Defect Block - 0:0:0x03CC
  Original Defect Block - 0:0:0x03E8
  Original Defect Block - 0:0:0x041E
  Original Defect Block - 0:0:0x042C
  Original Defect Block - 0:0:0x0454
  Original Defect Block - 0:0:0x0460
  Original Defect Block - 0:0:0x04AE
  Original Defect Block - 0:0:0x04C4
  Original Defect Block - 0:0:0x04C6
  Original Defect Block - 0:0:0x04D6
  Original Defect Block - 0:0:0x0508
  Original Defect Block - 0:0:0x051A
  Original Defect Block - 0:0:0x0530
  Original Defect Block - 0:0:0x054E
  Original Defect Block - 0:0:0x0568
  Original Defect Block - 0:0:0x0578
  Original Defect Block - 0:0:0x0586
  Original Defect Block - 0:0:0x05C4
  Original Defect Block - 0:0:0x05E8
  Original Defect Block - 0:0:0x063E
  Original Defect Block - 0:0:0x065E
  Original Defect Block - 0:0:0x0666
  Original Defect Block - 0:0:0x06BC
  Original Defect Block - 0:0:0x06C8
  Original Defect Block - 0:0:0x06D4
  Original Defect Block - 0:0:0x06EA
  Original Defect Block - 0:0:0x06EE
  Original Defect Block - 0:0:0x06F6
  Original Defect Block - 0:0:0x0724
  Original Defect Block - 0:0:0x0730
  Original Defect Block - 0:0:0x0744
  Original Defect Block - 0:0:0x0748
  Original Defect Block - 0:0:0x0766
  Original Defect Block - 0:0:0x078E
  Original Defect Block - 0:0:0x0792
  Original Defect Block - 0:0:0x081C
  Original Defect Block - 0:0:0x0836
  Original Defect Block - 0:0:0x0856
  Original Defect Block - 0:0:0x0860
  Original Defect Block - 0:0:0x088C
  Original Defect Block - 0:0:0x08A0
  Original Defect Block - 0:0:0x08AE
  Original Defect Block - 0:0:0x08B6
  Original Defect Block - 0:0:0x08B8
  Original Defect Block - 0:0:0x08DA
  Original Defect Block - 0:0:0x08EC
  Original Defect Block - 0:0:0x08FB
  Original Defect Block - 0:0:0x08FC
  Original Defect Block - 0:0:0x0928
  Original Defect Block - 0:0:0x0932
  Original Defect Block - 0:0:0x0948
  Original Defect Block - 0:0:0x095A
  Original Defect Block - 0:0:0x095E
  Original Defect Block - 0:0:0x0988
  Original Defect Block - 0:0:0x098C
  Original Defect Block - 0:0:0x0990
  Original Defect Block - 0:0:0x0A0C
  Original Defect Block - 0:0:0x0A2A
  Original Defect Block - 0:0:0x0A2C
  Original Defect Block - 0:0:0x0A30
  Original Defect Block - 0:0:0x0A7C
  Original Defect Block - 0:0:0x0A8A
  Original Defect Block - 0:0:0x0AD4
  Original Defect Block - 0:0:0x0AF6
  Original Defect Block - 0:0:0x0AFA
  Original Defect Block - 0:0:0x0B06
  Original Defect Block - 0:0:0x0B0A
  Original Defect Block - 0:0:0x0B14
  Original Defect Block - 0:0:0x0B24
  Original Defect Block - 0:0:0x0B42
  Original Defect Block - 0:0:0x0B76
  Original Defect Block - 0:0:0x0B82
  Original Defect Block - 0:0:0x0B96
  Original Defect Block - 0:0:0x0BD2
  Original Defect Block - 0:0:0x0BD6
  Original Defect Block - 0:0:0x0C04
  Original Defect Block - 0:0:0x0C06
  Original Defect Block - 0:0:0x0C0A
  Original Defect Block - 0:0:0x0C30
  Original Defect Block - 0:0:0x0C42
  Original Defect Block - 0:0:0x0C44
  Original Defect Block - 0:0:0x0C54
  Original Defect Block - 0:0:0x0CEE
  Original Defect Block - 0:0:0x0CF9
  Original Defect Block - 0:0:0x0CFB
  Original Defect Block - 0:0:0x0CFE
  Original Defect Block - 0:0:0x0D08
  Original Defect Block - 0:0:0x0D1A
  Original Defect Block - 0:0:0x0D2E
  Original Defect Block - 0:0:0x0D3C
  Original Defect Block - 0:0:0x0D60
  Original Defect Block - 0:0:0x0D94
  Original Defect Block - 0:0:0x0DB0
  Original Defect Block - 0:0:0x0DC0
  Original Defect Block - 0:0:0x0DC4
  Original Defect Block - 0:0:0x0DE0
  Original Defect Block - 0:0:0x0DE6
  Original Defect Block - 0:0:0x0E08
  Original Defect Block - 0:0:0x0E3A
  Original Defect Block - 0:0:0x0E3C
  Original Defect Block - 0:0:0x0E44
  Original Defect Block - 0:0:0x0E62
  Original Defect Block - 0:0:0x0E8E
  Original Defect Block - 0:0:0x0EB2
  Original Defect Block - 0:0:0x0EEC
  Original Defect Block - 0:0:0x0F02
  Original Defect Block - 0:0:0x0F2C
  Original Defect Block - 0:0:0x0F38
  Original Defect Block - 0:0:0x0F42
  Original Defect Block - 0:0:0x0F48
  Original Defect Block - 0:0:0x0F68
  Original Defect Block - 0:0:0x0F6C
  Original Defect Block - 0:0:0x0F72
  Original Defect Block - 0:0:0x0F76
  Original Defect Block - 0:0:0x0F88
  Original Defect Block - 0:0:0x0FA6
  Original Defect Block - 0:0:0x0FB4
  Original Defect Block - 0:0:0x0FBC
  Original Defect Block - 0:0:0x0FC4
  Original Defect Block - 0:0:0x0FCE
  Original Defect Block - 0:0:0x0FD4
  Original Defect Block - 0:0:0x1000
  Original Defect Block - 0:0:0x1001
  Original Defect Block - 0:0:0x1002
  Original Defect Block - 0:0:0x1003
  ---> Max Bad of Plane (78,3)
  ---> Max BAD/DIE = 78
Total good blocks after SCAN: 3939 / 4100, Bad block=161
==> 2-Plane mode
Max. Bad Block Allowed = 183(161)
Adjust Max LBA = 7823360, 7823296
MaxWindows=2/1910, MaxLBA=7823296, Size=3819 MB
Max BAD of one plane is 78 (45),4100,1,1
### Error: Low level format failed ###
SafeErase (0,4100)
  Erase failed Block - 0:0:0x0000
  Erase failed Block - 0:0:0x0002
  Erase failed Block - 0:0:0x0024
  Erase failed Block - 0:0:0x002E
  Erase failed Block - 0:0:0x006E
  Erase failed Block - 0:0:0x0086
  Erase failed Block - 0:0:0x008E
  Erase failed Block - 0:0:0x00A4
  Erase failed Block - 0:0:0x00CE
  Erase failed Block - 0:0:0x00D2
  Erase failed Block - 0:0:0x0100
  Erase failed Block - 0:0:0x012A
  Erase failed Block - 0:0:0x0150
  Erase failed Block - 0:0:0x0176
  Erase failed Block - 0:0:0x0184
  Erase failed Block - 0:0:0x01A8
  Erase failed Block - 0:0:0x0204
  Erase failed Block - 0:0:0x020C
  Erase failed Block - 0:0:0x0214
  Erase failed Block - 0:0:0x024A
  Erase failed Block - 0:0:0x026C
  Erase failed Block - 0:0:0x0272
  Erase failed Block - 0:0:0x02A0
  Erase failed Block - 0:0:0x02A8
  Erase failed Block - 0:0:0x02C4
  Erase failed Block - 0:0:0x02C8
  Erase failed Block - 0:0:0x02F8
  Erase failed Block - 0:0:0x02FC
  Erase failed Block - 0:0:0x030E
  Erase failed Block - 0:0:0x0326
  Erase failed Block - 0:0:0x033A
  Erase failed Block - 0:0:0x035C
  Erase failed Block - 0:0:0x036A
  Erase failed Block - 0:0:0x0380
  Erase failed Block - 0:0:0x038E
  Erase failed Block - 0:0:0x039C
  Erase failed Block - 0:0:0x03CC
  Erase failed Block - 0:0:0x03E8
  Erase failed Block - 0:0:0x041E
  Erase failed Block - 0:0:0x042C
  Erase failed Block - 0:0:0x0454
  Erase failed Block - 0:0:0x0460
  Erase failed Block - 0:0:0x04AE
  Erase failed Block - 0:0:0x04C4
  Erase failed Block - 0:0:0x04C6
  Erase failed Block - 0:0:0x04D6
  Erase failed Block - 0:0:0x0508
  Erase failed Block - 0:0:0x051A
  Erase failed Block - 0:0:0x0530
  Erase failed Block - 0:0:0x054E
  Erase failed Block - 0:0:0x0568
  Erase failed Block - 0:0:0x0578
  Erase failed Block - 0:0:0x0586
  Erase failed Block - 0:0:0x05C4
  Erase failed Block - 0:0:0x05E8
  Erase failed Block - 0:0:0x063E
  Erase failed Block - 0:0:0x065E
  Erase failed Block - 0:0:0x0666
  Erase failed Block - 0:0:0x06BC
  Erase failed Block - 0:0:0x06C8
  Erase failed Block - 0:0:0x06D4
  Erase failed Block - 0:0:0x06EA
  Erase failed Block - 0:0:0x06EE
  Erase failed Block - 0:0:0x06F6
  Erase failed Block - 0:0:0x0724
  Erase failed Block - 0:0:0x0730
  Erase failed Block - 0:0:0x0744
  Erase failed Block - 0:0:0x0748
  Erase failed Block - 0:0:0x0766
  Erase failed Block - 0:0:0x078E
  Erase failed Block - 0:0:0x0792
  Erase failed Block - 0:0:0x081C
  Erase failed Block - 0:0:0x0836
  Erase failed Block - 0:0:0x0856
  Erase failed Block - 0:0:0x0860
  Erase failed Block - 0:0:0x088C
  Erase failed Block - 0:0:0x08A0
  Erase failed Block - 0:0:0x08AE
  Erase failed Block - 0:0:0x08B6
  Erase failed Block - 0:0:0x08B8
  Erase failed Block - 0:0:0x08DA
  Erase failed Block - 0:0:0x08EC
  Erase failed Block - 0:0:0x08FB
  Erase failed Block - 0:0:0x08FC
  Erase failed Block - 0:0:0x0928
  Erase failed Block - 0:0:0x0932
  Erase failed Block - 0:0:0x0948
  Erase failed Block - 0:0:0x095A
  Erase failed Block - 0:0:0x095E
  Erase failed Block - 0:0:0x0988
  Erase failed Block - 0:0:0x098C
  Erase failed Block - 0:0:0x0990
  Erase failed Block - 0:0:0x0A0C
  Erase failed Block - 0:0:0x0A2A
  Erase failed Block - 0:0:0x0A2C
  Erase failed Block - 0:0:0x0A30
  Erase failed Block - 0:0:0x0A7C
  Erase failed Block - 0:0:0x0A8A
  Erase failed Block - 0:0:0x0AD4
  Erase failed Block - 0:0:0x0AF6
  Erase failed Block - 0:0:0x0AFA
  Erase failed Block - 0:0:0x0B06
  Erase failed Block - 0:0:0x0B0A
  Erase failed Block - 0:0:0x0B14
  Erase failed Block - 0:0:0x0B24
  Erase failed Block - 0:0:0x0B42
  Erase failed Block - 0:0:0x0B76
  Erase failed Block - 0:0:0x0B82
  Erase failed Block - 0:0:0x0B96
  Erase failed Block - 0:0:0x0BD2
  Erase failed Block - 0:0:0x0BD6
  Erase failed Block - 0:0:0x0C04
  Erase failed Block - 0:0:0x0C06
  Erase failed Block - 0:0:0x0C0A
  Erase failed Block - 0:0:0x0C30
  Erase failed Block - 0:0:0x0C42
  Erase failed Block - 0:0:0x0C44
  Erase failed Block - 0:0:0x0C54
  Erase failed Block - 0:0:0x0CEE
  Erase failed Block - 0:0:0x0CF9
  Erase failed Block - 0:0:0x0CFB
  Erase failed Block - 0:0:0x0CFE
  Erase failed Block - 0:0:0x0D08
  Erase failed Block - 0:0:0x0D1A
  Erase failed Block - 0:0:0x0D2E
  Erase failed Block - 0:0:0x0D3C
  Erase failed Block - 0:0:0x0D60
  Erase failed Block - 0:0:0x0D94
  Erase failed Block - 0:0:0x0DB0
  Erase failed Block - 0:0:0x0DC0
  Erase failed Block - 0:0:0x0DC4
  Erase failed Block - 0:0:0x0DE0
  Erase failed Block - 0:0:0x0DE6
  Erase failed Block - 0:0:0x0E08
  Erase failed Block - 0:0:0x0E3A
  Erase failed Block - 0:0:0x0E3C
  Erase failed Block - 0:0:0x0E44
  Erase failed Block - 0:0:0x0E62
  Erase failed Block - 0:0:0x0E8E
  Erase failed Block - 0:0:0x0EB2
  Erase failed Block - 0:0:0x0EEC
  Erase failed Block - 0:0:0x0F02
  Erase failed Block - 0:0:0x0F2C
  Erase failed Block - 0:0:0x0F38
  Erase failed Block - 0:0:0x0F42
  Erase failed Block - 0:0:0x0F48
  Erase failed Block - 0:0:0x0F68
  Erase failed Block - 0:0:0x0F6C
  Erase failed Block - 0:0:0x0F72
  Erase failed Block - 0:0:0x0F76
  Erase failed Block - 0:0:0x0F88
  Erase failed Block - 0:0:0x0FA6
  Erase failed Block - 0:0:0x0FB4
  Erase failed Block - 0:0:0x0FBC
  Erase failed Block - 0:0:0x0FC4
  Erase failed Block - 0:0:0x0FCE
  Erase failed Block - 0:0:0x0FD4
  Erase failed Block - 0:0:0x1000
  Erase failed Block - 0:0:0x1001
  Erase failed Block - 0:0:0x1002
  Erase failed Block - 0:0:0x1003
Ending Time: 21:45:40
---------------- Device 1------------------
### Error: No found boot block (non-MPed disk)
[ 此帖被经典含具在2011-10-01 11:36重新编辑 ]
离线shuishou
只看该作者 1楼 发表于: 2011-10-01
本帖最近打赏记录:共1条打赏M币+5
离线gamester
只看该作者 2楼 发表于: 2011-10-01
本帖最近打赏记录:共1条打赏M币+5
离线经典含具
只看该作者 3楼 发表于: 2011-10-01
离线shuishou
只看该作者 4楼 发表于: 2011-10-01
回 3楼(经典含具) 的帖子
本帖最近打赏记录:共1条打赏M币+5
离线babx789
只看该作者 5楼 发表于: 2013-10-17
回 4楼(shuishou) 的帖子
