  • 3462阅读
  • 6回复
[鑫创]金士顿  DataTraveler G3 4G  量产失败求助 [复制链接]
离线zxzw
只看楼主 倒序阅读 我要置顶 楼主  发表于: 2011-10-01
金士顿  DataTraveler G3 4G有一次插到电脑后就出现问题,用量产工具量产失败ERROR 8 求各位高手帮助。
主控6692  内存HVPF4F5  量产工具用的是论坛里的2128版。刷的文件6692_Kingston G3 CDROM Flash.ini  6692_B5-A_20100916_VB10000_63E2.BIN
报错信息如下:
Device 1:0xB5
    MP Version:2.182
    INI_File_Name:6692_Kingston G3 CDROM Flash.ini
    Random delay 0 msec
    --- Download MP ISP ---
    ### No support [SCAN_RDY_BSY-0xFF 0x30] !
    CE-0, Flash ID=98-D7-94-32-76-55-0D-00
    Found BACKUP Table (000001BB-0003)
    Defect Table (00000400-0008)
        Original Bad Block - 0:0x0000
        Original Bad Block - 0:0x0001
        Original Bad Block - 0:0x0002
        Original Bad Block - 0:0x0004
        Original Bad Block - 0:0x0005
        Original Bad Block - 0:0x0012
        Original Bad Block - 0:0x003F
        Original Bad Block - 0:0x00B2
        Original Bad Block - 0:0x00BD
        Original Bad Block - 0:0x00C2
        Original Bad Block - 0:0x0112
        Original Bad Block - 0:0x0122
        Original Bad Block - 0:0x0136
        Original Bad Block - 0:0x0186
        Original Bad Block - 0:0x01EE
        Original Bad Block - 0:0x02F8
        Original Bad Block - 0:0x0332
        Original Bad Block - 0:0x0392
        Original Bad Block - 0:0x03CA
        Original Bad Block - 0:0x03F6
        Original Bad Block - 0:0x040D
        Original Bad Block - 0:0x0422
        Original Bad Block - 0:0x0436
        Original Bad Block - 0:0x0442
        Original Bad Block - 0:0x047E
        Original Bad Block - 0:0x048A
        Original Bad Block - 0:0x04AE
        Original Bad Block - 0:0x04CE
        Original Bad Block - 0:0x04EE
        Original Bad Block - 0:0x0542
        Original Bad Block - 0:0x0546
        Original Bad Block - 0:0x0552
        Original Bad Block - 0:0x055E
        Original Bad Block - 0:0x0598
        Original Bad Block - 0:0x05BB
        Original Bad Block - 0:0x0660
        Original Bad Block - 0:0x0750
        Original Bad Block - 0:0x0778
        Original Bad Block - 0:0x07BA
        Original Bad Block - 0:0x07FE
        Original Bad Block - 0:0x0818
        Original Bad Block - 0:0x0846
        Original Bad Block - 0:0x0994
        Original Bad Block - 0:0x0996
        Original Bad Block - 0:0x0A48
        Original Bad Block - 0:0x0A58
        Original Bad Block - 0:0x0B1A
        Original Bad Block - 0:0x0B76
        Original Bad Block - 0:0x0BB2
        Original Bad Block - 0:0x0BC2
        Original Bad Block - 0:0x0BD6
        Original Bad Block - 0:0x0BDD
        Original Bad Block - 0:0x0BE2
        Original Bad Block - 0:0x0BEA
        Original Bad Block - 0:0x0C9A
        Original Bad Block - 0:0x0C9E
        Original Bad Block - 0:0x0D0A
        Original Bad Block - 0:0x0E2E
        Original Bad Block - 0:0x0EA6
        Original Bad Block - 0:0x0F4A
        Original Bad Block - 0:0x0F82
        Original Bad Block - 0:0x0F8E
        Original Bad Block - 0:0x1000
        Original Bad Block - 0:0x1001
        Original Bad Block - 0:0x1002
        Original Bad Block - 0:0x1003
    Defect Table shows 4034 Good blocks, 66 Bad blocks
    SafeErase (0,4100)
        Erase failed Block - 0:0:0x0000
        Erase failed Block - 0:0:0x0001
        Erase failed Block - 0:0:0x0002
        Erase failed Block - 0:0:0x0004
        Erase failed Block - 0:0:0x0005
        Erase failed Block - 0:0:0x0012
        Erase failed Block - 0:0:0x003F
        Erase failed Block - 0:0:0x00B2
        Erase failed Block - 0:0:0x00BD
        Erase failed Block - 0:0:0x00C2
        Erase failed Block - 0:0:0x0112
        Erase failed Block - 0:0:0x0122
        Erase failed Block - 0:0:0x0136
        Erase failed Block - 0:0:0x0186
        Erase failed Block - 0:0:0x01EE
        Erase failed Block - 0:0:0x02F8
        Erase failed Block - 0:0:0x0332
        Erase failed Block - 0:0:0x0392
        Erase failed Block - 0:0:0x03CA
        Erase failed Block - 0:0:0x03F6
        Erase failed Block - 0:0:0x040D
        Erase failed Block - 0:0:0x0422
        Erase failed Block - 0:0:0x0436
        Erase failed Block - 0:0:0x0442
        Erase failed Block - 0:0:0x047E
        Erase failed Block - 0:0:0x048A
        Erase failed Block - 0:0:0x04AE
        Erase failed Block - 0:0:0x04CE
        Erase failed Block - 0:0:0x04EE
        Erase failed Block - 0:0:0x0542
        Erase failed Block - 0:0:0x0546
        Erase failed Block - 0:0:0x0552
        Erase failed Block - 0:0:0x055E
        Erase failed Block - 0:0:0x0598
        Erase failed Block - 0:0:0x05BB
        Erase failed Block - 0:0:0x0660
        Erase failed Block - 0:0:0x0750
        Erase failed Block - 0:0:0x0778
        Erase failed Block - 0:0:0x07BA
        Erase failed Block - 0:0:0x07FE
        Erase failed Block - 0:0:0x0818
        Erase failed Block - 0:0:0x0846
        Erase failed Block - 0:0:0x0994
        Erase failed Block - 0:0:0x0996
        Erase failed Block - 0:0:0x0A48
        Erase failed Block - 0:0:0x0A58
        Erase failed Block - 0:0:0x0B1A
        Erase failed Block - 0:0:0x0B76
        Erase failed Block - 0:0:0x0BB2
        Erase failed Block - 0:0:0x0BC2
        Erase failed Block - 0:0:0x0BD6
        Erase failed Block - 0:0:0x0BDD
        Erase failed Block - 0:0:0x0BE2
        Erase failed Block - 0:0:0x0BEA
        Erase failed Block - 0:0:0x0C9A
        Erase failed Block - 0:0:0x0C9E
        Erase failed Block - 0:0:0x0D0A
        Erase failed Block - 0:0:0x0E2E
        Erase failed Block - 0:0:0x0EA6
        Erase failed Block - 0:0:0x0F4A
        Erase failed Block - 0:0:0x0F82
        Erase failed Block - 0:0:0x0F8E
        Erase failed Block - 0:0:0x1000
        Erase failed Block - 0:0:0x1001
        Erase failed Block - 0:0:0x1002
        Erase failed Block - 0:0:0x1003
        ---> Max Bad of Plane (29,5)
        ---> Max BAD/DIE = 29
    Total good blocks after SCAN: 4034 / 4100, Bad block=66
    ==> 2-Plane mode
    Max. Bad Block Allowed = 183(66)
    Adjust Max LBA = 7823360, 7823296
    MaxWindows=2/1910, MaxLBA=7823296, Size=3819 MB
    Max BAD of one plane is 29 (45),4100,1,1
    RootSector=0xE3D,Sec/Cluster=32, SuperPage=32 ---> Alignment=3
    Boot Block=0x0003,0x0006
    Lun0(7272888), Lun1(550408), Public=7272888, Secure=0, CDROM=550408
    Special FE Config = 56-0B-00
    Defect Table Block=0x0008
    --- Download ISP Code:G:\2182\ISP_CODE\6692_B5-A_20100916_VB10000_63E2.BIN---
    --- ISP Code installed.
    Public,Secure,CDROM = 7272888,0,550408
    PHY: E2/E4/E6=72h/36h/04h,  D0/C0/CFG10=DFh/0Bh/87h
    SN=00216B10AB72FBA01F8A2038
    === Preformat Done ===
    Low Level Format DONE
    Store INI/ERROR MSG to Block-0x0003:79.
    ### Error: Device capacity is 0 bytes
关键词: 量产失败求助
离线wan06
只看该作者 1楼 发表于: 2011-10-01
离线qsav
只看该作者 2楼 发表于: 2011-10-02
离线zxzw
只看该作者 3楼 发表于: 2011-10-02
还是不行
离线gamester
只看该作者 4楼 发表于: 2011-10-03
离线asdf20003
只看该作者 5楼 发表于: 2011-11-08
离线biyu2008
只看该作者 6楼 发表于: 2011-11-08
