  • 3994阅读
  • 3回复
[鑫创]SSS6692量产ERROR 29 [复制链接]
离线trotter
只看楼主 倒序阅读 我要置顶 楼主  发表于: 2011-10-02
            之前在xp下能够量产成功,在Windows server 2008 下出现 error 29 ,是不是系统必须是 xp/2000 ?
Device 1:0xB5
    MP Version:2.182
    INI_File_Name:6692_HY32_256P_8KB.INI
    Random delay 0 msec
    --- Download MP ISP ---
    Auto CE: 0x00 0xFF 0xFF 0xFF 0xFF 0xFF 0xFF 0xFF
    CE-0, Flash ID=AD-DE-94-D2-04-43-AD-DE
    Page/Block=256
    Searching SORTING BOARD table ...
    --> Not Found
    Found BACKUP Table (0000023A-0002)
    Defect Table (00000800-0008)
    Defect Table shows 4096 Good blocks, 0 Bad blocks
    SafeErase (0,4096)
        ---> Max Bad of Plane (0,0)
        ---> Max BAD/DIE = 0
    Total good blocks after SCAN: 4096 / 4096, Bad block=0
    ==> 2-Plane mode
    Max. Bad Block Allowed = 174(0)
    Adjust Max LBA = 15646720, 15646656
    MaxWindows=2/1910, MaxLBA=15646656, Size=7639 MB
    Max BAD of one plane is 0 (43),4096,1,1
    RootSector=0xE11,Sec/Cluster=64, SuperPage=64 ---> Alignment=47
    Boot Block=0x0002,0x0004
    Lun0(14362864), Lun1(1283792), Public=14362864, Secure=0, CDROM=1283792
    Special FE Config = 56-0B-00
    Defect Table Block=0x0008
    --- Download ISP Code:D:\GREEN SOFTWARES\MP TOOL\ISP_CODE\6692_B5-IM_20110114_VB80000_51F5.BIN---
    --- ISP Code installed.
    Public,Secure,CDROM = 14362864,0,1283792
    PHY: E2/E4/E6=72h/36h/04h,  D0/C0/CFG10=DFh/0Bh/87h
    SN=002100EDCC60FBA023972032
    === Preformat Done ===
    Low Level Format DONE
    Store INI/ERROR MSG to Block-0x0002:78.
    LBATest 10M activate
    ### Error: CopyTest Fail(Write LBA=0x00000000)
    ### Error: CopyTest Fail(BLANK LBA=0x00000000)
### CopyTest 10M fail ###
只看该作者 1楼 发表于: 2011-10-02
离线qsav
只看该作者 2楼 发表于: 2011-10-02
离线gamester
只看该作者 3楼 发表于: 2011-10-02
