  • 2868阅读
  • 6回复
SSS6691量产失败 请高手指教 [复制链接]
离线jswsb
只看楼主 倒序阅读 我要置顶 楼主  发表于: 2011-10-28
用的是MP_Ver2162_All不知道对不对
错误码是
Original Defect Block - 0:0:0x03CC
  Original Defect Block - 0:0:0x03CE
  Original Defect Block - 0:0:0x03D0
  Original Defect Block - 0:0:0x03D2
  Original Defect Block - 0:0:0x03D4
  Original Defect Block - 0:0:0x03D6
  Original Defect Block - 0:0:0x03D8
  Original Defect Block - 0:0:0x03DA
  Original Defect Block - 0:0:0x03DC
  Original Defect Block - 0:0:0x03DE
  Original Defect Block - 0:0:0x03E0
  Original Defect Block - 0:0:0x03E2
  Original Defect Block - 0:0:0x03E4
  Original Defect Block - 0:0:0x03E6
  Original Defect Block - 0:0:0x03E8
  Original Defect Block - 0:0:0x03EA
  Original Defect Block - 0:0:0x03EC
  Original Defect Block - 0:0:0x03EE
  Original Defect Block - 0:0:0x03F0
  Original Defect Block - 0:0:0x03F2
  Original Defect Block - 0:0:0x03F4
  Original Defect Block - 0:0:0x03F6
  Original Defect Block - 0:0:0x03F8
  Original Defect Block - 0:0:0x03FA
  Original Defect Block - 0:0:0x03FC
  Original Defect Block - 0:0:0x03FE
  Original Defect Block - 0:0:0x0400
  Original Defect Block - 0:0:0x0402
  Original Defect Block - 0:0:0x0404
  Original Defect Block - 0:0:0x0406
  Original Defect Block - 0:0:0x0408
  Original Defect Block - 0:0:0x040A
  Original Defect Block - 0:0:0x040C
太长删了一些从0 0 0x040E到0 0 0xFE2
  Original Defect Block - 0:0:0x0FE4
  Original Defect Block - 0:0:0x0FE6
  Original Defect Block - 0:0:0x0FE8
  Original Defect Block - 0:0:0x0FEA
  Original Defect Block - 0:0:0x0FEC
  Original Defect Block - 0:0:0x0FEE
  Original Defect Block - 0:0:0x0FF0
  Original Defect Block - 0:0:0x0FF2
  Original Defect Block - 0:0:0x0FF4
  Original Defect Block - 0:0:0x0FF6
  Original Defect Block - 0:0:0x0FF8
  Original Defect Block - 0:0:0x0FFA
  Original Defect Block - 0:0:0x0FFC
  Original Defect Block - 0:0:0x0FFE
  Original Defect Block - 0:0:0x1000
  Original Defect Block - 0:0:0x1002
  Original Defect Block - 0:0:0x1004
  Original Defect Block - 0:0:0x1006
  Original Defect Block - 0:0:0x1008
  Original Defect Block - 0:0:0x100A
  Original Defect Block - 0:0:0x100C
  Original Defect Block - 0:0:0x100E
  Original Defect Block - 0:0:0x1010
  Original Defect Block - 0:0:0x1012
  Original Defect Block - 0:0:0x1014
  Original Defect Block - 0:0:0x1016
  Original Defect Block - 0:0:0x1018
  Original Defect Block - 0:0:0x101A
  Original Defect Block - 0:0:0x101C
  Original Defect Block - 0:0:0x101E
  Original Defect Block - 0:0:0x1020
  Original Defect Block - 0:0:0x1022
  Original Defect Block - 0:0:0x1024
  Original Defect Block - 0:0:0x1026
  Original Defect Block - 0:0:0x1028
  Original Defect Block - 0:0:0x102A
  Original Defect Block - 0:0:0x102C
  Original Defect Block - 0:0:0x102E
  Original Defect Block - 0:0:0x1030
  Original Defect Block - 0:0:0x1031
  Original Defect Block - 0:0:0x1032
  Original Defect Block - 0:0:0x1033
  ---> Max Bad of Plane (1037,3)
  ---> Max BAD/DIE = 1037
Total good blocks after SCAN: 2069 / 4148, Bad block=2079
==> 2-Plane mode
Max. Bad Block Allowed = 231(2079)
### Error: Too many bad block.
### Error: Low level format failed ###
SafeErase (0,4148)
请大家帮我看看是什么地方错了应该怎么做
还有就是量产失败的U盘怎么恢复
关键词: USB-CDROM
离线shuishou
只看该作者 1楼 发表于: 2011-10-28
本帖最近打赏记录:共2条打赏M币+10
离线jswsb
只看该作者 2楼 发表于: 2011-10-28
回 1楼(shuishou) 的帖子
离线shuishou
只看该作者 3楼 发表于: 2011-10-28
回 2楼(jswsb) 的帖子
本帖最近打赏记录:共2条打赏M币+10
离线jswsb
只看该作者 4楼 发表于: 2011-10-29
回 3楼(shuishou) 的帖子
离线no40
只看该作者 5楼 发表于: 2011-10-29
本帖最近打赏记录:共1条打赏M币+5
离线shuishou
只看该作者 6楼 发表于: 2011-10-29
回 4楼(jswsb) 的帖子
本帖最近打赏记录:共1条打赏M币+5
