  • 2512阅读
  • 6回复
[鑫创]金士顿主控是6690的U盘量产失败 [复制链接]
离线了性
只看楼主 倒序阅读 我要置顶 楼主  发表于: 2011-10-30
Device 1:0xB1
    MP Version:2.159
    INI_File_Name:6690_D2.INI
    Random delay 0 msec
    --- Download MP ISP ---
    CE-0, Flash ID=98-D7-94-32-76-54-0C-00
    Found BACKUP Table (000000BB-0001)
    Found BACKUP Table (0000013B-0002)
        Original Bad Block - 0:0x0000
        Original Bad Block - 0:0x00C8
        Original Bad Block - 0:0x00C9
        Original Bad Block - 0:0x0434
        Original Bad Block - 0:0x0435
        Original Bad Block - 0:0x04BC
        Original Bad Block - 0:0x04BD
        Original Bad Block - 0:0x05E8
        Original Bad Block - 0:0x05E9
        Original Bad Block - 0:0x068A
        Original Bad Block - 0:0x068B
        Original Bad Block - 0:0x06BE
        Original Bad Block - 0:0x06BF
        Original Bad Block - 0:0x0734
        Original Bad Block - 0:0x0735
        Original Bad Block - 0:0x07B8
        Original Bad Block - 0:0x07B9
        Original Bad Block - 0:0x07F0
        Original Bad Block - 0:0x07F1
        Original Bad Block - 0:0x0848
        Original Bad Block - 0:0x0849
        Original Bad Block - 0:0x0A34
        Original Bad Block - 0:0x0A35
        Original Bad Block - 0:0x0AFE
        Original Bad Block - 0:0x0AFF
        Original Bad Block - 0:0x0C66
        Original Bad Block - 0:0x0C67
        Original Bad Block - 0:0x0EFE
        Original Bad Block - 0:0x0EFF
        Original Bad Block - 0:0x0F7C
        Original Bad Block - 0:0x0F7D
        Original Bad Block - 0:0x1030
        Original Bad Block - 0:0x1031
        Original Bad Block - 0:0x1032
        Original Bad Block - 0:0x1033
    Defect Table shows 4113 Good blocks, 35 Bad blocks
    SafeErase (0,4148)
        Erase failed Block - 0:0:0x0000
        Erase failed Block - 0:0:0x00C8
        Erase failed Block - 0:0:0x00C9
        Erase failed Block - 0:0:0x0434
        Erase failed Block - 0:0:0x0435
        Erase failed Block - 0:0:0x04BC
        Erase failed Block - 0:0:0x04BD
        Erase failed Block - 0:0:0x05E8
        Erase failed Block - 0:0:0x05E9
        Erase failed Block - 0:0:0x068A
        Erase failed Block - 0:0:0x068B
        Erase failed Block - 0:0:0x06BE
        Erase failed Block - 0:0:0x06BF
        Erase failed Block - 0:0:0x0734
        Erase failed Block - 0:0:0x0735
        Erase failed Block - 0:0:0x07B8
        Erase failed Block - 0:0:0x07B9
        Erase failed Block - 0:0:0x07F0
        Erase failed Block - 0:0:0x07F1
        Erase failed Block - 0:0:0x0848
        Erase failed Block - 0:0:0x0849
        Erase failed Block - 0:0:0x0A34
        Erase failed Block - 0:0:0x0A35
        Erase failed Block - 0:0:0x0AFE
        Erase failed Block - 0:0:0x0AFF
        Erase failed Block - 0:0:0x0C66
        Erase failed Block - 0:0:0x0C67
        Erase failed Block - 0:0:0x0EFE
        Erase failed Block - 0:0:0x0EFF
        Erase failed Block - 0:0:0x0F7C
        Erase failed Block - 0:0:0x0F7D
        Erase failed Block - 0:0:0x1030
        Erase failed Block - 0:0:0x1031
        Erase failed Block - 0:0:0x1032
        Erase failed Block - 0:0:0x1033
        ---> Max Bad of Plane (9,9)
        ---> Max BAD/DIE = 9
    Total good blocks after SCAN: 4113 / 4148, Bad block=35
    ==> 2-Plane mode
    Max. Bad Block Allowed = 232(35)
    Adjust Max LBA = 7823360, 7823296
    MaxWindows=2/1910, MaxLBA=7823296, Size=3819 MB
    Max BAD of one plane is 9 (58),4148,1,1
    RootSector=0xF4B,Sec/Cluster=32, SuperPage=32 ---> Alignment=21
    Boot Block=0x0001,0x0002
    Lun0(7823296), Lun1(0), Public=7823296, Secure=0, CDROM=0
    Special FE Config = 54-0B-00
    --- Download ISP Code:E:\DOWNLOADS\6690_TSBD2_MP_V2159\6690_TSBD2_MP_V2159\ISP_CODE\6690_B1-A_20110908_V150B_78E3.BIN---
    --- ISP Code installed.
    Public,Secure,CDROM = 7823296,0,0
    SN=000000000000F1A1E2CF202D
    === Preformat Done ===
    Low Level Format DONE
    Store INI/ERROR MSG to Block-0x0001:79.
    LBATest 10M activate
    ### Error: CopyTest Fail(Write LBA=0x00000000)
    ### Error: CopyTest Fail(BLANK LBA=0x00000000)
### CopyTest 10M fail ###
这是量产过得报告,怎么不成功?求指点!
离线gamester
只看该作者 1楼 发表于: 2011-10-30
本帖最近打赏记录:共2条打赏M币+10
离线shuishou
只看该作者 2楼 发表于: 2011-10-30
本帖最近打赏记录:共2条打赏M币+10
离线了性
只看该作者 3楼 发表于: 2011-10-30
回 1楼(gamester) 的帖子
离线qsav
只看该作者 4楼 发表于: 2011-11-05
离线biyu2008
只看该作者 5楼 发表于: 2011-11-05
本帖最近打赏记录:共1条打赏M币+5
离线biyu2008
只看该作者 6楼 发表于: 2011-11-05
