  • 2419阅读
  • 5回复
[鑫创]3S量产失败求助 [复制链接]
离线stifler
只看楼主 倒序阅读 我要置顶 楼主  发表于: 2011-11-18
Device 1:0xB5
MP Version:2.182
INI_File_Name:6692——256P_4KB_cdrom.INI
Random delay 0 msec
--- Download MP ISP ---
### No support [SCAN_RDY_BSY-0xFF 0x30] !
CE-0, Flash ID=98-D7-94-32-76-55-0C-00
Found BACKUP Table (000000BB-0001)
Defect Table (00000200-0004)
  Original Bad Block - 0:0x005E
  Original Bad Block - 0:0x00CE
  Original Bad Block - 0:0x0151
  Original Bad Block - 0:0x0168
  Original Bad Block - 0:0x020B
  Original Bad Block - 0:0x0267
  Original Bad Block - 0:0x02AB
  Original Bad Block - 0:0x02D2
  Original Bad Block - 0:0x02E3
  Original Bad Block - 0:0x0300
  Original Bad Block - 0:0x030F
  Original Bad Block - 0:0x0383
  Original Bad Block - 0:0x053A
  Original Bad Block - 0:0x0650
  Original Bad Block - 0:0x0722
  Original Bad Block - 0:0x07AB
  Original Bad Block - 0:0x07AE
  Original Bad Block - 0:0x07AF
  Original Bad Block - 0:0x0815
  Original Bad Block - 0:0x082A
  Original Bad Block - 0:0x0834
  Original Bad Block - 0:0x0842
  Original Bad Block - 0:0x0847
  Original Bad Block - 0:0x088D
  Original Bad Block - 0:0x0896
  Original Bad Block - 0:0x0957
  Original Bad Block - 0:0x0992
  Original Bad Block - 0:0x09CD
  Original Bad Block - 0:0x09DA
  Original Bad Block - 0:0x09E1
  Original Bad Block - 0:0x0B4B
  Original Bad Block - 0:0x0B7A
  Original Bad Block - 0:0x0BE1
  Original Bad Block - 0:0x0C02
  Original Bad Block - 0:0x0C03
  Original Bad Block - 0:0x0C80
  Original Bad Block - 0:0x0CA1
  Original Bad Block - 0:0x0CA2
  Original Bad Block - 0:0x0CAE
  Original Bad Block - 0:0x0CC2
  Original Bad Block - 0:0x0CE7
  Original Bad Block - 0:0x0D82
  Original Bad Block - 0:0x0DE5
  Original Bad Block - 0:0x0DF3
  Original Bad Block - 0:0x0E35
  Original Bad Block - 0:0x0E98
  Original Bad Block - 0:0x0FAF
  Original Bad Block - 0:0x0FC2
  Original Bad Block - 0:0x1000
  Original Bad Block - 0:0x1001
  Original Bad Block - 0:0x1002
  Original Bad Block - 0:0x1003
Defect Table shows 4048 Good blocks, 52 Bad blocks
SafeErase (0,4100)
  Erase failed Block - 0:0:0x005E
  Erase failed Block - 0:0:0x00CE
  Erase failed Block - 0:0:0x0151
  Erase failed Block - 0:0:0x0168
  Erase failed Block - 0:0:0x020B
  Erase failed Block - 0:0:0x0267
  Erase failed Block - 0:0:0x02AB
  Erase failed Block - 0:0:0x02D2
  Erase failed Block - 0:0:0x02E3
  Erase failed Block - 0:0:0x0300
  Erase failed Block - 0:0:0x030F
  Erase failed Block - 0:0:0x0383
  Erase failed Block - 0:0:0x053A
  Erase failed Block - 0:0:0x0650
  Erase failed Block - 0:0:0x0722
  Erase failed Block - 0:0:0x07AB
  Erase failed Block - 0:0:0x07AE
  Erase failed Block - 0:0:0x07AF
  Erase failed Block - 0:0:0x0815
  Erase failed Block - 0:0:0x082A
  Erase failed Block - 0:0:0x0834
  Erase failed Block - 0:0:0x0842
  Erase failed Block - 0:0:0x0847
  Erase failed Block - 0:0:0x088D
  Erase failed Block - 0:0:0x0896
  Erase failed Block - 0:0:0x0957
  Erase failed Block - 0:0:0x0992
  Erase failed Block - 0:0:0x09CD
  Erase failed Block - 0:0:0x09DA
  Erase failed Block - 0:0:0x09E1
  Erase failed Block - 0:0:0x0B4B
  Erase failed Block - 0:0:0x0B7A
  Erase failed Block - 0:0:0x0BE1
  Erase failed Block - 0:0:0x0C02
  Erase failed Block - 0:0:0x0C03
  Erase failed Block - 0:0:0x0C80
  Erase failed Block - 0:0:0x0CA1
  Erase failed Block - 0:0:0x0CA2
  Erase failed Block - 0:0:0x0CAE
  Erase failed Block - 0:0:0x0CC2
  Erase failed Block - 0:0:0x0CE7
  Erase failed Block - 0:0:0x0D82
  Erase failed Block - 0:0:0x0DE5
  Erase failed Block - 0:0:0x0DF3
  Erase failed Block - 0:0:0x0E35
  Erase failed Block - 0:0:0x0E98
  Erase failed Block - 0:0:0x0FAF
  Erase failed Block - 0:0:0x0FC2
  Erase failed Block - 0:0:0x1000
  Erase failed Block - 0:0:0x1001
  Erase failed Block - 0:0:0x1002
  Erase failed Block - 0:0:0x1003
  ---> Max Bad of Plane (13,13)
  ---> Max BAD/DIE = 13
Total good blocks after SCAN: 4048 / 4100, Bad block=52
==> 2-Plane mode
MaxWindows=2/1914, MaxLBA=7831552, Size=3824 MB
Lun0(7474724), Lun1(356828), Public=7474724, Secure=0, CDROM=356828
### Error: No support capacity for XP format. ###
### Error: Low level format failed ###
SafeErase (0,4100)
主控INI配置:
[OEM]
PN=6692 + (256 page,4KB)_flash
Note=ISP:6692_B5-A_20100916_VB10000_63E2.BIN
VID=0
PID=0
VENDOR_NAME="Kingston"
PRODUCT_NAME="DataTraveler G3k"
STRING_DESC_ENABLE=1
SN_CustomerCode=0x0F
[FEATURE_SETTING]
FLASH_OP="ALL123"
ID35=1
ID45=1
ID53=1
[ISP]
Code=6692_B5-A_20100916_VB10000_63E2.BIN
[LED]
LED_Period=1
LED_DutyCycle=10
离线auq0880wcw
只看该作者 1楼 发表于: 2011-11-18
离线木鱼
只看该作者 2楼 发表于: 2011-11-18
本帖最近打赏记录:共2条打赏M币+11
只看该作者 3楼 发表于: 2011-11-18
本帖最近打赏记录:共2条打赏M币+11
离线gamester
只看该作者 4楼 发表于: 2011-11-18
本帖最近打赏记录:共1条打赏M币+5
离线shuishou
只看该作者 5楼 发表于: 2011-11-18
回 4楼(gamester) 的帖子
本帖最近打赏记录:共1条打赏M币+5
