  • 6373阅读
  • 24回复
[鑫创]SSS6691量产失败  有报告求高手。(已解决) [复制链接]
离线yujia1shao
只看楼主 倒序阅读 我要置顶 楼主  发表于: 2011-12-02
 设备描述: [M:]USB 大容量存储设备(Kingston DT 101 II)
 设备类型: 大容量存储设备
 协议版本: USB 2.00
 当前速度: 高速(HighSpeed)
 电力消耗: 100mA
USB设备ID: VID = 0951 PID = 1625
设备序列号: 001CC0EC34A2F071C7D61423
设备供应商: Kingston
 设备名称: DT 101 II
设备修订版: 0100
产品制造商: Kingston
 产品型号: DT 101 II
产品修订版: 1.00
 芯片厂商: SSS(鑫创)
 芯片型号: SSS6691-B3
---------------- Device 1------------------
FW version:0xB3
  CE-0, Flash ID=98-D7-94-32-76-54-0C
Found boot block at (0x00000080)
### Error: Read BPB
Device 1:0xB3
    MP Version:2.162
    INI_File_Name:
    Random delay 0 msec
    --- Download MP ISP ---
    CE-0, Flash ID=98-D7-94-32-76-54-0C-00
    Found BACKUP Table (000000BB-0001)
    Defect Table (00000200-0004)
        Original Bad Block - 0:0x0000
        Original Bad Block - 0:0x001B
        Original Bad Block - 0:0x0096
        Original Bad Block - 0:0x0112
        Original Bad Block - 0:0x0166
        Original Bad Block - 0:0x01D1
        Original Bad Block - 0:0x0241
        Original Bad Block - 0:0x029E
        Original Bad Block - 0:0x02C6
        Original Bad Block - 0:0x030C
        Original Bad Block - 0:0x0312
        Original Bad Block - 0:0x032A
        Original Bad Block - 0:0x0372
        Original Bad Block - 0:0x0386
        Original Bad Block - 0:0x03D3
        Original Bad Block - 0:0x03F1
        Original Bad Block - 0:0x0402
        Original Bad Block - 0:0x0462
        Original Bad Block - 0:0x0463
        Original Bad Block - 0:0x0490
        Original Bad Block - 0:0x0491
        Original Bad Block - 0:0x04C8
        Original Bad Block - 0:0x04D0
        Original Bad Block - 0:0x04E5
        Original Bad Block - 0:0x0514
        Original Bad Block - 0:0x053B
        Original Bad Block - 0:0x0552
        Original Bad Block - 0:0x0572
        Original Bad Block - 0:0x057B
        Original Bad Block - 0:0x0589
        Original Bad Block - 0:0x0592
        Original Bad Block - 0:0x059C
        Original Bad Block - 0:0x059D
        Original Bad Block - 0:0x05A2
        Original Bad Block - 0:0x05A7
        Original Bad Block - 0:0x05AC
        Original Bad Block - 0:0x05B0
        Original Bad Block - 0:0x05BC
        Original Bad Block - 0:0x05DD
        Original Bad Block - 0:0x05E0
        Original Bad Block - 0:0x05E1
        Original Bad Block - 0:0x05EA
        Original Bad Block - 0:0x05EB
        Original Bad Block - 0:0x05F0
        Original Bad Block - 0:0x05F1
        Original Bad Block - 0:0x05FC
        Original Bad Block - 0:0x0600
        Original Bad Block - 0:0x0601
        Original Bad Block - 0:0x061F
        Original Bad Block - 0:0x0621
        Original Bad Block - 0:0x062A
        Original Bad Block - 0:0x0630
        Original Bad Block - 0:0x0631
        Original Bad Block - 0:0x0640
        Original Bad Block - 0:0x064A
        Original Bad Block - 0:0x065C
        Original Bad Block - 0:0x0660
        Original Bad Block - 0:0x0661
        Original Bad Block - 0:0x0665
        Original Bad Block - 0:0x066B
        Original Bad Block - 0:0x0672
        Original Bad Block - 0:0x0686
        Original Bad Block - 0:0x0694
        Original Bad Block - 0:0x069D
        Original Bad Block - 0:0x06A2
        Original Bad Block - 0:0x06A9
        Original Bad Block - 0:0x06B7
        Original Bad Block - 0:0x06BD
        Original Bad Block - 0:0x06BF
        Original Bad Block - 0:0x06C2
        Original Bad Block - 0:0x06C3
        Original Bad Block - 0:0x06D9
        Original Bad Block - 0:0x06DB
        Original Bad Block - 0:0x06DC
        Original Bad Block - 0:0x06EE
        Original Bad Block - 0:0x06F1
        Original Bad Block - 0:0x0705
        Original Bad Block - 0:0x070A
        Original Bad Block - 0:0x0723
        Original Bad Block - 0:0x072C
        Original Bad Block - 0:0x072D
        Original Bad Block - 0:0x0759
        Original Bad Block - 0:0x075C
        Original Bad Block - 0:0x0778
        Original Bad Block - 0:0x079B
        Original Bad Block - 0:0x07C5
        Original Bad Block - 0:0x07D4
        Original Bad Block - 0:0x07D5
        Original Bad Block - 0:0x07E6
        Original Bad Block - 0:0x07E7
        Original Bad Block - 0:0x0802
        Original Bad Block - 0:0x084C
        Original Bad Block - 0:0x084D
        Original Bad Block - 0:0x088F
        Original Bad Block - 0:0x0923
        Original Bad Block - 0:0x092C
        Original Bad Block - 0:0x094C
        Original Bad Block - 0:0x09C5
        Original Bad Block - 0:0x0A12
        Original Bad Block - 0:0x0A1A
        Original Bad Block - 0:0x0A39
        Original Bad Block - 0:0x0A6E
        Original Bad Block - 0:0x0A81
        Original Bad Block - 0:0x0AD4
        Original Bad Block - 0:0x0AF5
        Original Bad Block - 0:0x0B21
        Original Bad Block - 0:0x0B30
        Original Bad Block - 0:0x0B31
        Original Bad Block - 0:0x0B3A
        Original Bad Block - 0:0x0BA1
        Original Bad Block - 0:0x0BC5
        Original Bad Block - 0:0x0BDE
        Original Bad Block - 0:0x0BE0
        Original Bad Block - 0:0x0BE6
        Original Bad Block - 0:0x0BF2
        Original Bad Block - 0:0x0C1B
        Original Bad Block - 0:0x0C20
        Original Bad Block - 0:0x0C94
        Original Bad Block - 0:0x0C95
        Original Bad Block - 0:0x0CAB
        Original Bad Block - 0:0x0CDB
        Original Bad Block - 0:0x0CEE
        Original Bad Block - 0:0x0CF0
        Original Bad Block - 0:0x0D06
        Original Bad Block - 0:0x0D22
        Original Bad Block - 0:0x0D29
        Original Bad Block - 0:0x0D42
        Original Bad Block - 0:0x0DA6
        Original Bad Block - 0:0x0DB6
        Original Bad Block - 0:0x0DCC
        Original Bad Block - 0:0x0E02
        Original Bad Block - 0:0x0E13
        Original Bad Block - 0:0x0E78
        Original Bad Block - 0:0x0F04
        Original Bad Block - 0:0x0F50
        Original Bad Block - 0:0x0F76
        Original Bad Block - 0:0x0FB2
        Original Bad Block - 0:0x0FE2
        Original Bad Block - 0:0x1030
        Original Bad Block - 0:0x1031
        Original Bad Block - 0:0x1032
        Original Bad Block - 0:0x1033
    Defect Table shows 4006 Good blocks, 142 Bad blocks
    SafeErase (0,4148)
        Erase failed Block - 0:0:0x0000
        Erase failed Block - 0:0:0x001B
        Erase failed Block - 0:0:0x0096
        Erase failed Block - 0:0:0x0112
        Erase failed Block - 0:0:0x0166
        Erase failed Block - 0:0:0x01D1
        Erase failed Block - 0:0:0x0241
        Erase failed Block - 0:0:0x029E
        Erase failed Block - 0:0:0x02C6
        Erase failed Block - 0:0:0x030C
        Erase failed Block - 0:0:0x0312
        Erase failed Block - 0:0:0x032A
        Erase failed Block - 0:0:0x0372
        Erase failed Block - 0:0:0x0386
        Erase failed Block - 0:0:0x03D3
        Erase failed Block - 0:0:0x03F1
        Erase failed Block - 0:0:0x0402
        Erase failed Block - 0:0:0x0462
        Erase failed Block - 0:0:0x0463
        Erase failed Block - 0:0:0x0490
        Erase failed Block - 0:0:0x0491
        Erase failed Block - 0:0:0x04C8
        Erase failed Block - 0:0:0x04D0
        Erase failed Block - 0:0:0x04E5
        Erase failed Block - 0:0:0x0514
        Erase failed Block - 0:0:0x053B
        Erase failed Block - 0:0:0x0552
        Erase failed Block - 0:0:0x0572
        Erase failed Block - 0:0:0x057B
        Erase failed Block - 0:0:0x0589
        Erase failed Block - 0:0:0x0592
        Erase failed Block - 0:0:0x059C
        Erase failed Block - 0:0:0x059D
        Erase failed Block - 0:0:0x05A2
        Erase failed Block - 0:0:0x05A7
        Erase failed Block - 0:0:0x05AC
        Erase failed Block - 0:0:0x05B0
        Erase failed Block - 0:0:0x05BC
        Erase failed Block - 0:0:0x05DD
        Erase failed Block - 0:0:0x05E0
        Erase failed Block - 0:0:0x05E1
        Erase failed Block - 0:0:0x05EA
        Erase failed Block - 0:0:0x05EB
        Erase failed Block - 0:0:0x05F0
        Erase failed Block - 0:0:0x05F1
        Erase failed Block - 0:0:0x05FC
        Erase failed Block - 0:0:0x0600
        Erase failed Block - 0:0:0x0601
        Erase failed Block - 0:0:0x061F
        Erase failed Block - 0:0:0x0621
        Erase failed Block - 0:0:0x062A
        Erase failed Block - 0:0:0x0630
        Erase failed Block - 0:0:0x0631
        Erase failed Block - 0:0:0x0640
        Erase failed Block - 0:0:0x064A
        Erase failed Block - 0:0:0x065C
        Erase failed Block - 0:0:0x0660
        Erase failed Block - 0:0:0x0661
        Erase failed Block - 0:0:0x0665
        Erase failed Block - 0:0:0x066B
        Erase failed Block - 0:0:0x0672
        Erase failed Block - 0:0:0x0686
        Erase failed Block - 0:0:0x0694
        Erase failed Block - 0:0:0x069D
        Erase failed Block - 0:0:0x06A2
        Erase failed Block - 0:0:0x06A9
        Erase failed Block - 0:0:0x06B7
        Erase failed Block - 0:0:0x06BD
        Erase failed Block - 0:0:0x06BF
        Erase failed Block - 0:0:0x06C2
        Erase failed Block - 0:0:0x06C3
        Erase failed Block - 0:0:0x06D9
        Erase failed Block - 0:0:0x06DB
        Erase failed Block - 0:0:0x06DC
        Erase failed Block - 0:0:0x06EE
        Erase failed Block - 0:0:0x06F1
        Erase failed Block - 0:0:0x0705
        Erase failed Block - 0:0:0x070A
        Erase failed Block - 0:0:0x0723
        Erase failed Block - 0:0:0x072C
        Erase failed Block - 0:0:0x072D
        Erase failed Block - 0:0:0x0759
        Erase failed Block - 0:0:0x075C
        Erase failed Block - 0:0:0x0778
        Erase failed Block - 0:0:0x079B
        Erase failed Block - 0:0:0x07C5
        Erase failed Block - 0:0:0x07D4
        Erase failed Block - 0:0:0x07D5
        Erase failed Block - 0:0:0x07E6
        Erase failed Block - 0:0:0x07E7
        Erase failed Block - 0:0:0x0802
        Erase failed Block - 0:0:0x084C
        Erase failed Block - 0:0:0x084D
        Erase failed Block - 0:0:0x088F
        Erase failed Block - 0:0:0x0923
        Erase failed Block - 0:0:0x092C
        Erase failed Block - 0:0:0x094C
        Erase failed Block - 0:0:0x09C5
        Erase failed Block - 0:0:0x0A12
        Erase failed Block - 0:0:0x0A1A
        Erase failed Block - 0:0:0x0A39
        Erase failed Block - 0:0:0x0A6E
        Erase failed Block - 0:0:0x0A81
        Erase failed Block - 0:0:0x0AD4
        Erase failed Block - 0:0:0x0AF5
        Erase failed Block - 0:0:0x0B21
        Erase failed Block - 0:0:0x0B30
        Erase failed Block - 0:0:0x0B31
        Erase failed Block - 0:0:0x0B3A
        Erase failed Block - 0:0:0x0BA1
        Erase failed Block - 0:0:0x0BC5
        Erase failed Block - 0:0:0x0BDE
        Erase failed Block - 0:0:0x0BE0
        Erase failed Block - 0:0:0x0BE6
        Erase failed Block - 0:0:0x0BF2
        Erase failed Block - 0:0:0x0C1B
        Erase failed Block - 0:0:0x0C20
        Erase failed Block - 0:0:0x0C94
        Erase failed Block - 0:0:0x0C95
        Erase failed Block - 0:0:0x0CAB
        Erase failed Block - 0:0:0x0CDB
        Erase failed Block - 0:0:0x0CEE
        Erase failed Block - 0:0:0x0CF0
        Erase failed Block - 0:0:0x0D06
        Erase failed Block - 0:0:0x0D22
        Erase failed Block - 0:0:0x0D29
        Erase failed Block - 0:0:0x0D42
        Erase failed Block - 0:0:0x0DA6
        Erase failed Block - 0:0:0x0DB6
        Erase failed Block - 0:0:0x0DCC
        Erase failed Block - 0:0:0x0E02
        Erase failed Block - 0:0:0x0E13
        Erase failed Block - 0:0:0x0E78
        Erase failed Block - 0:0:0x0F04
        Erase failed Block - 0:0:0x0F50
        Erase failed Block - 0:0:0x0F76
        Erase failed Block - 0:0:0x0FB2
        Erase failed Block - 0:0:0x0FE2
        Erase failed Block - 0:0:0x1030
        Erase failed Block - 0:0:0x1031
        Erase failed Block - 0:0:0x1032
        Erase failed Block - 0:0:0x1033
        ---> Max Bad of Plane (41,30)
        ---> Max BAD/DIE = 41
    Total good blocks after SCAN: 4006 / 4148, Bad block=142
    ==> 2-Plane mode
    Max. Bad Block Allowed = 231(142)
    Adjust Max LBA = 7823360, 7823296
    MaxWindows=2/1910, MaxLBA=7823296, Size=3819 MB
    Max BAD of one plane is 41 (57),4148,1,1
    RootSector=0xF4B,Sec/Cluster=32, SuperPage=32 ---> Alignment=21
    Boot Block=0x0001,0x0002
    Lun0(7823296), Lun1(0), Public=7823296, Secure=0, CDROM=0
    Special FE Config = 54-0B-00
    Defect Table Block=0x0004
    --- Download ISP Code:E:\原硬盘备份块。\在用量产工具G3\量产工具教程\KINSTON+G3\KINSTON G3用过了\ISP_CODE\6691_B3-A_20100331_VA10F00_9083.BIN---
    --- ISP Code installed.
    Public,Secure,CDROM = 7823296,0,0
    SN=6C626DA51D1BF1C0289D14EC
    === Preformat Done ===
    Low Level Format DONE
    Store INI/ERROR MSG to Block-0x0001:79.
    LBATest 10M activate
    ### Error: CopyTest Fail(Write LBA=0x00000000)
    ### Error: CopyTest Fail(BLANK LBA=0x00000000)
### CopyTest 10M fail ###
失败  看不懂。
[ 此帖被yujia1shao在2011-12-03 21:09重新编辑 ]
离线shuishou
只看该作者 1楼 发表于: 2011-12-02
本帖最近打赏记录:共4条打赏M币+18
离线gamester
只看该作者 2楼 发表于: 2011-12-02
本帖最近打赏记录:共5条打赏M币+25
离线kyk0416
只看该作者 3楼 发表于: 2011-12-02
离线hfsp
只看该作者 4楼 发表于: 2011-12-03
离线yujia1shao
只看该作者 5楼 发表于: 2011-12-03
Re:SSS6691量产失败  有报告求高手。
离线shuishou
只看该作者 6楼 发表于: 2011-12-03
回 5楼(yujia1shao) 的帖子
本帖最近打赏记录:共1条打赏M币+5
离线yujia1shao
只看该作者 7楼 发表于: 2011-12-03
回 1楼(shuishou) 的帖子
离线tango1q1q
只看该作者 8楼 发表于: 2011-12-03
离线yujia1shao
只看该作者 9楼 发表于: 2011-12-03
