  • 6000阅读
  • 12回复
[MP3]求助:台电C430+开机无背光 ,内部升压IC 2093发烫。 [复制链接]
离线yzcfxz
只看楼主 倒序阅读 我要置顶 楼主  发表于: 2011-12-06
台电C430+开机无背光 ,内部升压IC 2093发烫,怀疑此IC损坏,经网上查询到此IC的详细型号为EMD2093
详细参数如下:
The EMD2093 designed with high efficiency step up DC/DC converter for driving white LEDs. The device can drive up 8 white LEDs from a single Li-Ion battery or a DC power 2.5V to 5.5V. The EMD2093 uses current mode and pulse-width modulated (PWM) operation. It switches at 1.2MHz and allows using small inductor and both of input/output capacitors. An internal c o mpensation can reduce external c o mponent.
The EMD2093 include under-voltage lockout, current limit, over voltage and thermal shutdown protection. The EMD2093 is available in SOT-26 package.
Features
WLEDs supports:
  Up to 8-LEDs support at VIN=3.7V
Up to 40mA current support at VIN=3.7V
Low Quiescent Current: 55 μA
Over Voltage Protection: 30V
  Inherently Matched LED Current
Shutdown Current < 1μA
  Reference Voltage 0.245V
Efficiency : 85% (Typ) at VIN=5.0V
  PWM Dimming Control
Internal Soft Start and Compensation
800mA Internal power MOSFET Switch
Low Profile SOT-26 Package
Applications
  Mobile Phone
Digital Still Cameras
Portable applications
GPS Receivers
由于此型号IC比较难找,不知道此IC能否找到替代品,还请各位大侠帮帮忙,小弟先在这里谢过各位了!
[ 此帖被lvcha在2011-12-07 02:30重新编辑 ]
离线279166235
只看该作者 1楼 发表于: 2011-12-06
本帖最近打赏记录:共1条打赏 ,M币+5
离线dzr4444
只看该作者 2楼 发表于: 2011-12-06
离线lvcha
只看该作者 3楼 发表于: 2011-12-07
Re:MP4开机故障求助各位
离线木鱼
只看该作者 4楼 发表于: 2011-12-07
离线yzcfxz
只看该作者 5楼 发表于: 2011-12-07
回 4楼(木鱼) 的帖子
离线木鱼
只看该作者 6楼 发表于: 2011-12-08
离线c2008bc
只看该作者 7楼 发表于: 2012-02-27
离线c2008bc
只看该作者 8楼 发表于: 2012-02-27
离线wave
只看该作者 9楼 发表于: 2012-02-28
