  • 2013阅读
  • 1回复
[鑫创]量产失败,各位大侠来帮帮我这个新人吧,谢谢 [复制链接]
离线charlesymt
只看楼主 倒序阅读 我要置顶 楼主  发表于: 2011-12-23
Starting Time: 17:00:35
Device 1:0xB5
    MP Version:2.182
    INI_File_Name:6692_MG26_256P_8KB.INI
    Random delay 0 msec
    --- Download MP ISP ---
    Auto CE: 0x00 0xFF 0xFF 0xFF 0xFF 0xFF 0xFF 0xFF
    CE-0, Flash ID=2C-88-04-4B-A9-00-00-00
    Page/Block=256
    Searching SORTING BOARD table ...
    --> Not Found
    Found BACKUP Table (0000023A-0002)
    Defect Table (00000800-0008)
        Original Bad Block - 0:0x005A
        Original Bad Block - 0:0x005B
    Defect Table shows 4094 Good blocks, 2 Bad blocks
    SafeErase (0,4096)
        Erase failed Block - 0:0:0x005A
        Erase failed Block - 0:0:0x005B
        ---> Max Bad of Plane (1,1)
        ---> Max BAD/DIE = 1
    Total good blocks after SCAN: 4094 / 4096, Bad block=2
    ==> 2-Plane mode
    Adjust Max LBA = 16351232, 16269248
    MaxWindows=2/1986, MaxLBA=16269248, Size=7943 MB
    Max BAD of one plane is 1 (5),4096,1,1
    RootSector=0xFC1,Sec/Cluster=64, SuperPage=64 ---> Alignment=63
    Boot Block=0x0002,0x0004
    Lun0(16125580), Lun1(143668), Public=16125580, Secure=0, CDROM=143668
    Special FE Config = 56-0B-00
    Defect Table Block=0x0008
    --- Download ISP Code:E:\UPANGJ\6692_HY26_MP_V2182\ISP_CODE\6692_B5-IM_20101123_VBB0100_53FB.BIN---
    --- ISP Code installed.
    Public,Secure,CDROM = 16125580,0,143668
    PHY: E2/E4/E6=72h/36h/04h,  D0/C0/CFG10=DFh/0Bh/87h
    SN=E005C5ECA5ADFBC178AE203C
    === Preformat Done ===
    Low Level Format DONE
    Store INI/ERROR MSG to Block-0x0002:78.
    LBATest 10M activate
    CDROM image:F:\g.iso
    Total=16269248,CDROM=143668, PublicArea=16125452, SecureArea=0
    Create SECURE(CDROM=1,Public=7873 MB,Secure=0 MB)
      Write LBA(0x00F62F0C,128) Fail !
    ### Err: SECURE failed(2088773120).
Ending Time: 17:01:15
离线hfsp
只看该作者 1楼 发表于: 2011-12-23
回 楼主(charlesymt) 的帖子
本帖最近打赏记录:共1条打赏M币+3
