  • 5103阅读
  • 5回复
[鑫创]SSS6692-B5量产失败,要怎么修复呀?请高手指教 [复制链接]
离线doomeng
只看楼主 倒序阅读 我要置顶 楼主  发表于: 2012-01-03
求高手帮忙。
repotr的信息如下:
Device 1:0xB5
MP Version:2.182
INI_File_Name:6692_MG26_256P_8KB.INI
Random delay 0 msec
--- Download MP ISP ---
Auto CE: 0x00 0xFF 0xFF 0xFF 0xFF 0xFF 0xFF 0xFF
CE-0, Flash ID=2C-88-04-4B-A9-00-00-00
Page/Block=256
Searching SORTING BOARD table ...
--> Not Found
--> ROOT is not found
Scan (0,4096)
  Original Defect Block - 0:0:0x005A
  Original Defect Block - 0:0:0x005B
  ---> Max Bad of Plane (1,1)
  ---> Max BAD/DIE = 1
Total good blocks after SCAN: 4094 / 4096, Bad block=2
==> 2-Plane mode
Max. Bad Block Allowed = 174(2)
Adjust Max LBA = 15646720, 15646656
MaxWindows=2/1910, MaxLBA=15646656, Size=7639 MB
Max BAD of one plane is 1 (43),4096,1,1
RootSector=0xDEF,Sec/Cluster=64, SuperPage=64 ---> Alignment=17
Boot Block=0x0002,0x0004
Lun0(14223708), Lun1(1422948), Public=14223708, Secure=0, CDROM=1422948
Special FE Config = 56-0B-00
Defect Table Block=0x0008
--- Download ISP Code:C:\USERS\ADMINISTRATOR\3S6692_MP_VER2182\3S6692_MP_VER2182\ISP_CODE\6692_B5-IM_20101123_VBB0100_53FB.BIN---
### Error: ISP code install failed.
### Error: Low level format failed ###
Store INI/ERROR MSG to Block-0x0002:78.
SafeErase (0,4096)
  Erase failed Block - 0:0:0x005A
  Erase failed Block - 0:0:0x005B
离线shuishou
只看该作者 1楼 发表于: 2012-01-03
回 楼主(doomeng) 的帖子
本帖最近打赏记录:共2条打赏M币+7
离线hfsp
只看该作者 2楼 发表于: 2012-01-03
本帖最近打赏记录:共2条打赏M币+7
离线hfsp
只看该作者 3楼 发表于: 2012-01-03
离线qsav
只看该作者 4楼 发表于: 2012-01-04
离线shuishou
只看该作者 5楼 发表于: 2012-01-07
回 5楼(goatok) 的帖子
本帖最近打赏记录:共1条打赏M币+5
