  • 2147阅读
  • 4回复
[鑫创]请教一个问题 [复制链接]
离线tjliaomao
只看楼主 倒序阅读 我要置顶 楼主  发表于: 2012-02-10
Starting Time: 01:53:42
Device 1:0xB3
MP Version:2.162
INI_File_Name:
Random delay 0 msec
--- Download MP ISP ---
CE-0, Flash ID=AD-D7-94-9A-74-42-AD-D7
Searching SORTING BOARD table ...
--> Not Found
Found BACKUP Table (0000023A-0002)
Found BACKUP Table (0000033A-0003)
  Original Bad Block - 0:0x0002
  Original Bad Block - 0:0x0003
  Original Bad Block - 0:0x0006
  Original Bad Block - 0:0x0007
  Original Bad Block - 0:0x000A
  Original Bad Block - 0:0x000B
  Original Bad Block - 0:0x000F
  Original Bad Block - 0:0x0018
  Original Bad Block - 0:0x001A
  Original Bad Block - 0:0x001B
  Original Bad Block - 0:0x001E
  Original Bad Block - 0:0x001F
  Original Bad Block - 0:0x0020
  Original Bad Block - 0:0x0021
  Original Bad Block - 0:0x0022
  Original Bad Block - 0:0x0023
  Original Bad Block - 0:0x0026
  Original Bad Block - 0:0x0027
  Original Bad Block - 0:0x0029
  Original Bad Block - 0:0x002E
  Original Bad Block - 0:0x002F
  Original Bad Block - 0:0x0031
  Original Bad Block - 0:0x0032
  Original Bad Block - 0:0x0033
  Original Bad Block - 0:0x0036
  Original Bad Block - 0:0x0037
  Original Bad Block - 0:0x003A
  Original Bad Block - 0:0x003C
  Original Bad Block - 0:0x003E
  Original Bad Block - 0:0x0040
  Original Bad Block - 0:0x0041
  Original Bad Block - 0:0x0043
  Original Bad Block - 0:0x0044
  Original Bad Block - 0:0x0045
  Original Bad Block - 0:0x0047
  Original Bad Block - 0:0x0049
  Original Bad Block - 0:0x004B
  Original Bad Block - 0:0x004C
  Original Bad Block - 0:0x004D
  Original Bad Block - 0:0x004F
  Original Bad Block - 0:0x0050
  Original Bad Block - 0:0x0053
  Original Bad Block - 0:0x0054
  Original Bad Block - 0:0x0055
  Original Bad Block - 0:0x0057
  Original Bad Block - 0:0x0059
  Original Bad Block - 0:0x005B
  Original Bad Block - 0:0x005C
  Original Bad Block - 0:0x005D
  Original Bad Block - 0:0x005F
  Original Bad Block - 0:0x0062
  Original Bad Block - 0:0x0063
  Original Bad Block - 0:0x0064
  Original Bad Block - 0:0x0065
  Original Bad Block - 0:0x0067
  Original Bad Block - 0:0x0069
  Original Bad Block - 0:0x006B
  Original Bad Block - 0:0x006D
  Original Bad Block - 0:0x006F
  Original Bad Block - 0:0x0071
  Original Bad Block - 0:0x0072
  Original Bad Block - 0:0x0073
  Original Bad Block - 0:0x0074
  Original Bad Block - 0:0x0076
  Original Bad Block - 0:0x0077
  Original Bad Block - 0:0x007A
  Original Bad Block - 0:0x007C
  Original Bad Block - 0:0x007E
  Original Bad Block - 0:0x0083
  Original Bad Block - 0:0x0088
  Original Bad Block - 0:0x0089
  Original Bad Block - 0:0x008A
  Original Bad Block - 0:0x008C
  Original Bad Block - 0:0x008D
  Original Bad Block - 0:0x008E
  Original Bad Block - 0:0x008F
  Original Bad Block - 0:0x0090
  Original Bad Block - 0:0x0091
  Original Bad Block - 0:0x0092
  Original Bad Block - 0:0x0094
  Original Bad Block - 0:0x0095
  Original Bad Block - 0:0x0096
  Original Bad Block - 0:0x0097
  Original Bad Block - 0:0x0098
  Original Bad Block - 0:0x0099
  Original Bad Block - 0:0x009A
  Original Bad Block - 0:0x009B
  Original Bad Block - 0:0x009C
  Original Bad Block - 0:0x009D
  Original Bad Block - 0:0x009F
  Original Bad Block - 0:0x00B2
  Original Bad Block - 0:0x0176
  Original Bad Block - 0:0x01E5
  Original Bad Block - 0:0x0202
  Original Bad Block - 0:0x0203
  Original Bad Block - 0:0x0206
  Original Bad Block - 0:0x0207
  Original Bad Block - 0:0x020A
  Original Bad Block - 0:0x020B
  Original Bad Block - 0:0x020D
  Original Bad Block - 0:0x020F
  Original Bad Block - 0:0x0210
  Original Bad Block - 0:0x0211
  Original Bad Block - 0:0x0212
  Original Bad Block - 0:0x0213
  Original Bad Block - 0:0x0214
  Original Bad Block - 0:0x0216
  Original Bad Block - 0:0x0217
  Original Bad Block - 0:0x0218
  Original Bad Block - 0:0x021A
  Original Bad Block - 0:0x021E
  Original Bad Block - 0:0x021F
  Original Bad Block - 0:0x0220
  Original Bad Block - 0:0x0221
  Original Bad Block - 0:0x0222
  Original Bad Block - 0:0x0223
  Original Bad Block - 0:0x0226
  Original Bad Block - 0:0x0227
  Original Bad Block - 0:0x0229
  Original Bad Block - 0:0x022A
  Original Bad Block - 0:0x022E
  Original Bad Block - 0:0x022F
  Original Bad Block - 0:0x0231
  Original Bad Block - 0:0x0232
  Original Bad Block - 0:0x0233
  Original Bad Block - 0:0x0236
  Original Bad Block - 0:0x0237
  Original Bad Block - 0:0x0238
  Original Bad Block - 0:0x0239
  Original Bad Block - 0:0x023A
  Original Bad Block - 0:0x023B
  Original Bad Block - 0:0x023C
  Original Bad Block - 0:0x023E
  Original Bad Block - 0:0x023F
  Original Bad Block - 0:0x0240
  Original Bad Block - 0:0x0241
  Original Bad Block - 0:0x0243
  Original Bad Block - 0:0x0244
  Original Bad Block - 0:0x0245
  Original Bad Block - 0:0x0247
  Original Bad Block - 0:0x0249
  Original Bad Block - 0:0x024C
  Original Bad Block - 0:0x024D
  Original Bad Block - 0:0x024F
  Original Bad Block - 0:0x0250
  Original Bad Block - 0:0x0253
  Original Bad Block - 0:0x0254
  Original Bad Block - 0:0x0255
  Original Bad Block - 0:0x0257
  Original Bad Block - 0:0x0259
  Original Bad Block - 0:0x025B
  Original Bad Block - 0:0x025C
  Original Bad Block - 0:0x025D
  Original Bad Block - 0:0x025F
  Original Bad Block - 0:0x0262
  Original Bad Block - 0:0x0263
  Original Bad Block - 0:0x0264
  Original Bad Block - 0:0x0265
  Original Bad Block - 0:0x0267
  Original Bad Block - 0:0x0268
  Original Bad Block - 0:0x0269
  Original Bad Block - 0:0x026B
  Original Bad Block - 0:0x026D
  Original Bad Block - 0:0x026F
  Original Bad Block - 0:0x0279
  Original Bad Block - 0:0x027A
  Original Bad Block - 0:0x027B
  Original Bad Block - 0:0x027C
  Original Bad Block - 0:0x027E
  Original Bad Block - 0:0x027F
  Original Bad Block - 0:0x0280
  Original Bad Block - 0:0x0281
  Original Bad Block - 0:0x0282
  Original Bad Block - 0:0x0283
  Original Bad Block - 0:0x0284
  Original Bad Block - 0:0x0285
  Original Bad Block - 0:0x0286
  Original Bad Block - 0:0x0287
  Original Bad Block - 0:0x0288
  Original Bad Block - 0:0x0289
  Original Bad Block - 0:0x028A
  Original Bad Block - 0:0x028B
  Original Bad Block - 0:0x028C
  Original Bad Block - 0:0x028D
  Original Bad Block - 0:0x028F
  Original Bad Block - 0:0x0290
  Original Bad Block - 0:0x0291
  Original Bad Block - 0:0x0292
  Original Bad Block - 0:0x0294
  Original Bad Block - 0:0x0295
  Original Bad Block - 0:0x0296
  Original Bad Block - 0:0x0297
  Original Bad Block - 0:0x0298
  Original Bad Block - 0:0x0299
  Original Bad Block - 0:0x029A
  Original Bad Block - 0:0x029B
  Original Bad Block - 0:0x029D
  Original Bad Block - 0:0x029E
  Original Bad Block - 0:0x029F
  Original Bad Block - 0:0x0381
  Original Bad Block - 0:0x0402
  Original Bad Block - 0:0x0403
  Original Bad Block - 0:0x0406
  Original Bad Block - 0:0x0407
  Original Bad Block - 0:0x040A
  Original Bad Block - 0:0x040B
  Original Bad Block - 0:0x040D
  Original Bad Block - 0:0x040F
  Original Bad Block - 0:0x0410
  Original Bad Block - 0:0x0411
  Original Bad Block - 0:0x0412
  Original Bad Block - 0:0x0413
  Original Bad Block - 0:0x0414
  Original Bad Block - 0:0x0416
  Original Bad Block - 0:0x0417
  Original Bad Block - 0:0x0420
  Original Bad Block - 0:0x0421
  Original Bad Block - 0:0x0422
  Original Bad Block - 0:0x0423
  Original Bad Block - 0:0x0426
  Original Bad Block - 0:0x0427
  Original Bad Block - 0:0x0431
  Original Bad Block - 0:0x0432
  Original Bad Block - 0:0x0433
  Original Bad Block - 0:0x0436
  Original Bad Block - 0:0x0437
  Original Bad Block - 0:0x0438
  Original Bad Block - 0:0x0439
  Original Bad Block - 0:0x043A
  Original Bad Block - 0:0x043B
  Original Bad Block - 0:0x043C
  Original Bad Block - 0:0x043E
  Original Bad Block - 0:0x043F
  Original Bad Block - 0:0x0440
  Original Bad Block - 0:0x0441
  Original Bad Block - 0:0x0443
  Original Bad Block - 0:0x0444
  Original Bad Block - 0:0x0445
  Original Bad Block - 0:0x0447
  Original Bad Block - 0:0x0449
  Original Bad Block - 0:0x044B
  Original Bad Block - 0:0x044C
  Original Bad Block - 0:0x044D
  Original Bad Block - 0:0x044F
  Original Bad Block - 0:0x0450
  Original Bad Block - 0:0x0453
  Original Bad Block - 0:0x0454
  Original Bad Block - 0:0x0455
  Original Bad Block - 0:0x0457
  Original Bad Block - 0:0x0459
  Original Bad Block - 0:0x045B
  Original Bad Block - 0:0x045C
  Original Bad Block - 0:0x045D
  Original Bad Block - 0:0x045F
  Original Bad Block - 0:0x0462
  Original Bad Block - 0:0x0463
  Original Bad Block - 0:0x0464
  Original Bad Block - 0:0x0465
  Original Bad Block - 0:0x0467
  Original Bad Block - 0:0x0468
  Original Bad Block - 0:0x0469
  Original Bad Block - 0:0x046B
  Original Bad Block - 0:0x046D
  Original Bad Block - 0:0x046F
  Original Bad Block - 0:0x0471
  Original Bad Block - 0:0x0472
  Original Bad Block - 0:0x0473
  Original Bad Block - 0:0x0474
  Original Bad Block - 0:0x0476
  Original Bad Block - 0:0x0477
  Original Bad Block - 0:0x0479
  Original Bad Block - 0:0x047A
  Original Bad Block - 0:0x047B
  Original Bad Block - 0:0x047C
  Original Bad Block - 0:0x047E
  Original Bad Block - 0:0x047F
  Original Bad Block - 0:0x0480
  Original Bad Block - 0:0x0481
  Original Bad Block - 0:0x0482
  Original Bad Block - 0:0x0483
  Original Bad Block - 0:0x0484
  Original Bad Block - 0:0x0485
  Original Bad Block - 0:0x0486
  Original Bad Block - 0:0x0487
  Original Bad Block - 0:0x0488
  Original Bad Block - 0:0x0489
  Original Bad Block - 0:0x048A
  Original Bad Block - 0:0x048B
  Original Bad Block - 0:0x048C
  Original Bad Block - 0:0x048D
  Original Bad Block - 0:0x048E
  Original Bad Block - 0:0x048F
  Original Bad Block - 0:0x0490
  Original Bad Block - 0:0x0491
  Original Bad Block - 0:0x0492
  Original Bad Block - 0:0x0494
  Original Bad Block - 0:0x0495
  Original Bad Block - 0:0x0496
  Original Bad Block - 0:0x0497
  Original Bad Block - 0:0x0498
  Original Bad Block - 0:0x0499
  Original Bad Block - 0:0x049A
  Original Bad Block - 0:0x049B
  Original Bad Block - 0:0x049C
  Original Bad Block - 0:0x049D
  Original Bad Block - 0:0x049E
  Original Bad Block - 0:0x049F
  Original Bad Block - 0:0x04C7
  Original Bad Block - 0:0x0523
  Original Bad Block - 0:0x05A3
  Original Bad Block - 0:0x05C4
  Original Bad Block - 0:0x05D7
  Original Bad Block - 0:0x0602
  Original Bad Block - 0:0x0603
  Original Bad Block - 0:0x0606
  Original Bad Block - 0:0x0607
  Original Bad Block - 0:0x060A
  Original Bad Block - 0:0x060B
  Original Bad Block - 0:0x060D
  Original Bad Block - 0:0x060F
  Original Bad Block - 0:0x0610
  Original Bad Block - 0:0x0611
  Original Bad Block - 0:0x0612
  Original Bad Block - 0:0x0613
  Original Bad Block - 0:0x0614
  Original Bad Block - 0:0x0616
  Original Bad Block - 0:0x0617
  Original Bad Block - 0:0x0618
  Original Bad Block - 0:0x061A
  Original Bad Block - 0:0x061B
  Original Bad Block - 0:0x061E
  Original Bad Block - 0:0x061F
  Original Bad Block - 0:0x0620
  Original Bad Block - 0:0x0621
  Original Bad Block - 0:0x0622
  Original Bad Block - 0:0x0623
  Original Bad Block - 0:0x0626
  Original Bad Block - 0:0x0627
  Original Bad Block - 0:0x0629
  Original Bad Block - 0:0x062A
  Original Bad Block - 0:0x062E
  Original Bad Block - 0:0x062F
  Original Bad Block - 0:0x0631
  Original Bad Block - 0:0x0632
  Original Bad Block - 0:0x0633
  Original Bad Block - 0:0x0636
  Original Bad Block - 0:0x0637
  Original Bad Block - 0:0x0638
  Original Bad Block - 0:0x0639
  Original Bad Block - 0:0x063A
  Original Bad Block - 0:0x063B
  Original Bad Block - 0:0x063C
  Original Bad Block - 0:0x063E
  Original Bad Block - 0:0x063F
  Original Bad Block - 0:0x0640
  Original Bad Block - 0:0x0641
  Original Bad Block - 0:0x0643
  Original Bad Block - 0:0x0644
  Original Bad Block - 0:0x0645
  Original Bad Block - 0:0x0647
  Original Bad Block - 0:0x0649
  Original Bad Block - 0:0x064B
  Original Bad Block - 0:0x064C
  Original Bad Block - 0:0x064D
  Original Bad Block - 0:0x064F
  Original Bad Block - 0:0x0650
  Original Bad Block - 0:0x0653
  Original Bad Block - 0:0x0654
  Original Bad Block - 0:0x0655
  Original Bad Block - 0:0x0657
  Original Bad Block - 0:0x0659
  Original Bad Block - 0:0x065B
  Original Bad Block - 0:0x065C
  Original Bad Block - 0:0x065D
  Original Bad Block - 0:0x065F
  Original Bad Block - 0:0x0662
  Original Bad Block - 0:0x0663
  Original Bad Block - 0:0x0664
  Original Bad Block - 0:0x0665
  Original Bad Block - 0:0x0667
  Original Bad Block - 0:0x0668
  Original Bad Block - 0:0x0669
  Original Bad Block - 0:0x066B
  Original Bad Block - 0:0x066D
  Original Bad Block - 0:0x066F
  Original Bad Block - 0:0x0671
  Original Bad Block - 0:0x0672
  Original Bad Block - 0:0x0673
  Original Bad Block - 0:0x0674
  Original Bad Block - 0:0x0676
  Original Bad Block - 0:0x0677
  Original Bad Block - 0:0x0679
  Original Bad Block - 0:0x067A
  Original Bad Block - 0:0x067B
  Original Bad Block - 0:0x067C
  Original Bad Block - 0:0x067E
  Original Bad Block - 0:0x067F
  Original Bad Block - 0:0x0680
  Original Bad Block - 0:0x0681
  Original Bad Block - 0:0x0682
  Original Bad Block - 0:0x0683
  Original Bad Block - 0:0x0684
  Original Bad Block - 0:0x0685
  Original Bad Block - 0:0x0686
  Original Bad Block - 0:0x0687
  Original Bad Block - 0:0x0688
  Original Bad Block - 0:0x0689
  Original Bad Block - 0:0x068A
  Original Bad Block - 0:0x068B
  Original Bad Block - 0:0x068C
  Original Bad Block - 0:0x068D
  Original Bad Block - 0:0x068E
  Original Bad Block - 0:0x068F
  Original Bad Block - 0:0x0690
  Original Bad Block - 0:0x0691
  Original Bad Block - 0:0x0692
  Original Bad Block - 0:0x0694
  Original Bad Block - 0:0x0695
  Original Bad Block - 0:0x0696
  Original Bad Block - 0:0x0697
  Original Bad Block - 0:0x0698
  Original Bad Block - 0:0x0699
  Original Bad Block - 0:0x069A
  Original Bad Block - 0:0x069B
  Original Bad Block - 0:0x069C
  Original Bad Block - 0:0x069D
  Original Bad Block - 0:0x069E
  Original Bad Block - 0:0x069F
  Original Bad Block - 0:0x06B3
  Original Bad Block - 0:0x07C1
Defect Table shows 1618 Good blocks, 430 Bad blocks
SafeErase (0,2048)
  Erase failed Block - 0:0:0x0002
  Erase failed Block - 0:0:0x0003
  Erase failed Block - 0:0:0x0006
  Erase failed Block - 0:0:0x0007
  Erase failed Block - 0:0:0x000A
  Erase failed Block - 0:0:0x000B
  Erase failed Block - 0:0:0x000F
  Erase failed Block - 0:0:0x0018
  Erase failed Block - 0:0:0x001A
  Erase failed Block - 0:0:0x001B
  Erase failed Block - 0:0:0x001E
  Erase failed Block - 0:0:0x001F
  Erase failed Block - 0:0:0x0020
  Erase failed Block - 0:0:0x0021
  Erase failed Block - 0:0:0x0022
  Erase failed Block - 0:0:0x0023
  Erase failed Block - 0:0:0x0026
  Erase failed Block - 0:0:0x0027
  Erase failed Block - 0:0:0x0029
  Erase failed Block - 0:0:0x002E
  Erase failed Block - 0:0:0x002F
  Erase failed Block - 0:0:0x0031
  Erase failed Block - 0:0:0x0032
  Erase failed Block - 0:0:0x0033
  Erase failed Block - 0:0:0x0036
  Erase failed Block - 0:0:0x0037
  Erase failed Block - 0:0:0x003A
  Erase failed Block - 0:0:0x003C
  Erase failed Block - 0:0:0x003E
  Erase failed Block - 0:0:0x0040
  Erase failed Block - 0:0:0x0041
  Erase failed Block - 0:0:0x0043
  Erase failed Block - 0:0:0x0044
  Erase failed Block - 0:0:0x0045
  Erase failed Block - 0:0:0x0047
  Erase failed Block - 0:0:0x0049
  Erase failed Block - 0:0:0x004B
  Erase failed Block - 0:0:0x004C
  Erase failed Block - 0:0:0x004D
  Erase failed Block - 0:0:0x004F
  Erase failed Block - 0:0:0x0050
  Erase failed Block - 0:0:0x0053
  Erase failed Block - 0:0:0x0054
  Erase failed Block - 0:0:0x0055
  Erase failed Block - 0:0:0x0057
  Erase failed Block - 0:0:0x0059
  Erase failed Block - 0:0:0x005B
  Erase failed Block - 0:0:0x005C
  Erase failed Block - 0:0:0x005D
  Erase failed Block - 0:0:0x005F
  Erase failed Block - 0:0:0x0062
  Erase failed Block - 0:0:0x0063
  Erase failed Block - 0:0:0x0064
  Erase failed Block - 0:0:0x0065
  Erase failed Block - 0:0:0x0067
  Erase failed Block - 0:0:0x0069
  Erase failed Block - 0:0:0x006B
  Erase failed Block - 0:0:0x006D
  Erase failed Block - 0:0:0x006F
  Erase failed Block - 0:0:0x0071
  Erase failed Block - 0:0:0x0072
  Erase failed Block - 0:0:0x0073
  Erase failed Block - 0:0:0x0074
  Erase failed Block - 0:0:0x0076
  Erase failed Block - 0:0:0x0077
  Erase failed Block - 0:0:0x007A
  Erase failed Block - 0:0:0x007C
  Erase failed Block - 0:0:0x007E
  Erase failed Block - 0:0:0x0083
  Erase failed Block - 0:0:0x0088
  Erase failed Block - 0:0:0x0089
  Erase failed Block - 0:0:0x008A
  Erase failed Block - 0:0:0x008C
  Erase failed Block - 0:0:0x008D
  Erase failed Block - 0:0:0x008E
  Erase failed Block - 0:0:0x008F
  Erase failed Block - 0:0:0x0090
  Erase failed Block - 0:0:0x0091
  Erase failed Block - 0:0:0x0092
  Erase failed Block - 0:0:0x0094
  Erase failed Block - 0:0:0x0095
  Erase failed Block - 0:0:0x0096
  Erase failed Block - 0:0:0x0097
  Erase failed Block - 0:0:0x0098
  Erase failed Block - 0:0:0x0099
  Erase failed Block - 0:0:0x009A
  Erase failed Block - 0:0:0x009B
  Erase failed Block - 0:0:0x009C
  Erase failed Block - 0:0:0x009D
  Erase failed Block - 0:0:0x009F
  Erase failed Block - 0:0:0x00B2
  Erase failed Block - 0:0:0x0176
  Erase failed Block - 0:0:0x01E5
  Erase failed Block - 0:0:0x0202
  Erase failed Block - 0:0:0x0203
  Erase failed Block - 0:0:0x0206
  Erase failed Block - 0:0:0x0207
  Erase failed Block - 0:0:0x020A
  Erase failed Block - 0:0:0x020B
  Erase failed Block - 0:0:0x020D
  Erase failed Block - 0:0:0x020F
  Erase failed Block - 0:0:0x0210
  Erase failed Block - 0:0:0x0211
  Erase failed Block - 0:0:0x0212
  Erase failed Block - 0:0:0x0213
  Erase failed Block - 0:0:0x0214
  Erase failed Block - 0:0:0x0216
  Erase failed Block - 0:0:0x0217
  Erase failed Block - 0:0:0x0218
  Erase failed Block - 0:0:0x021A
  Erase failed Block - 0:0:0x021E
  Erase failed Block - 0:0:0x021F
  Erase failed Block - 0:0:0x0220
  Erase failed Block - 0:0:0x0221
  Erase failed Block - 0:0:0x0222
  Erase failed Block - 0:0:0x0223
  Erase failed Block - 0:0:0x0226
  Erase failed Block - 0:0:0x0227
  Erase failed Block - 0:0:0x0229
  Erase failed Block - 0:0:0x022A
  Erase failed Block - 0:0:0x022E
  Erase failed Block - 0:0:0x022F
  Erase failed Block - 0:0:0x0231
  Erase failed Block - 0:0:0x0232
  Erase failed Block - 0:0:0x0233
  Erase failed Block - 0:0:0x0236
  Erase failed Block - 0:0:0x0237
  Erase failed Block - 0:0:0x0238
  Erase failed Block - 0:0:0x0239
  Erase failed Block - 0:0:0x023A
  Erase failed Block - 0:0:0x023B
  Erase failed Block - 0:0:0x023C
  Erase failed Block - 0:0:0x023E
  Erase failed Block - 0:0:0x023F
  Erase failed Block - 0:0:0x0240
  Erase failed Block - 0:0:0x0241
  Erase failed Block - 0:0:0x0243
  Erase failed Block - 0:0:0x0244
  Erase failed Block - 0:0:0x0245
  Erase failed Block - 0:0:0x0247
  Erase failed Block - 0:0:0x0249
  Erase failed Block - 0:0:0x024C
  Erase failed Block - 0:0:0x024D
  Erase failed Block - 0:0:0x024F
  Erase failed Block - 0:0:0x0250
  Erase failed Block - 0:0:0x0253
  Erase failed Block - 0:0:0x0254
  Erase failed Block - 0:0:0x0255
  Erase failed Block - 0:0:0x0257
  Erase failed Block - 0:0:0x0259
  Erase failed Block - 0:0:0x025B
  Erase failed Block - 0:0:0x025C
  Erase failed Block - 0:0:0x025D
  Erase failed Block - 0:0:0x025F
  Erase failed Block - 0:0:0x0262
  Erase failed Block - 0:0:0x0263
  Erase failed Block - 0:0:0x0264
  Erase failed Block - 0:0:0x0265
  Erase failed Block - 0:0:0x0267
  Erase failed Block - 0:0:0x0268
  Erase failed Block - 0:0:0x0269
  Erase failed Block - 0:0:0x026B
  Erase failed Block - 0:0:0x026D
  Erase failed Block - 0:0:0x026F
  Erase failed Block - 0:0:0x0279
  Erase failed Block - 0:0:0x027A
  Erase failed Block - 0:0:0x027B
  Erase failed Block - 0:0:0x027C
  Erase failed Block - 0:0:0x027E
  Erase failed Block - 0:0:0x027F
  Erase failed Block - 0:0:0x0280
  Erase failed Block - 0:0:0x0281
  Erase failed Block - 0:0:0x0282
  Erase failed Block - 0:0:0x0283
  Erase failed Block - 0:0:0x0284
  Erase failed Block - 0:0:0x0285
  Erase failed Block - 0:0:0x0286
  Erase failed Block - 0:0:0x0287
  Erase failed Block - 0:0:0x0288
  Erase failed Block - 0:0:0x0289
  Erase failed Block - 0:0:0x028A
  Erase failed Block - 0:0:0x028B
  Erase failed Block - 0:0:0x028C
  Erase failed Block - 0:0:0x028D
  Erase failed Block - 0:0:0x028F
  Erase failed Block - 0:0:0x0290
  Erase failed Block - 0:0:0x0291
  Erase failed Block - 0:0:0x0292
  Erase failed Block - 0:0:0x0294
  Erase failed Block - 0:0:0x0295
  Erase failed Block - 0:0:0x0296
  Erase failed Block - 0:0:0x0297
  Erase failed Block - 0:0:0x0298
  Erase failed Block - 0:0:0x0299
  Erase failed Block - 0:0:0x029A
  Erase failed Block - 0:0:0x029B
  Erase failed Block - 0:0:0x029D
  Erase failed Block - 0:0:0x029E
  Erase failed Block - 0:0:0x029F
  Erase failed Block - 0:0:0x0381
  Erase failed Block - 0:0:0x0402
  Erase failed Block - 0:0:0x0403
  Erase failed Block - 0:0:0x0406
  Erase failed Block - 0:0:0x0407
  Erase failed Block - 0:0:0x040A
  Erase failed Block - 0:0:0x040B
  Erase failed Block - 0:0:0x040D
  Erase failed Block - 0:0:0x040F
  Erase failed Block - 0:0:0x0410
  Erase failed Block - 0:0:0x0411
  Erase failed Block - 0:0:0x0412
  Erase failed Block - 0:0:0x0413
  Erase failed Block - 0:0:0x0414
  Erase failed Block - 0:0:0x0416
  Erase failed Block - 0:0:0x0417
  Erase failed Block - 0:0:0x0420
  Erase failed Block - 0:0:0x0421
  Erase failed Block - 0:0:0x0422
  Erase failed Block - 0:0:0x0423
  Erase failed Block - 0:0:0x0426
  Erase failed Block - 0:0:0x0427
  Erase failed Block - 0:0:0x0431
  Erase failed Block - 0:0:0x0432
  Erase failed Block - 0:0:0x0433
  Erase failed Block - 0:0:0x0436
  Erase failed Block - 0:0:0x0437
  Erase failed Block - 0:0:0x0438
  Erase failed Block - 0:0:0x0439
  Erase failed Block - 0:0:0x043A
  Erase failed Block - 0:0:0x043B
  Erase failed Block - 0:0:0x043C
  Erase failed Block - 0:0:0x043E
  Erase failed Block - 0:0:0x043F
  Erase failed Block - 0:0:0x0440
  Erase failed Block - 0:0:0x0441
  Erase failed Block - 0:0:0x0443
  Erase failed Block - 0:0:0x0444
  Erase failed Block - 0:0:0x0445
  Erase failed Block - 0:0:0x0447
  Erase failed Block - 0:0:0x0449
  Erase failed Block - 0:0:0x044B
  Erase failed Block - 0:0:0x044C
  Erase failed Block - 0:0:0x044D
  Erase failed Block - 0:0:0x044F
  Erase failed Block - 0:0:0x0450
  Erase failed Block - 0:0:0x0453
  Erase failed Block - 0:0:0x0454
  Erase failed Block - 0:0:0x0455
  Erase failed Block - 0:0:0x0457
  Erase failed Block - 0:0:0x0459
  Erase failed Block - 0:0:0x045B
  Erase failed Block - 0:0:0x045C
  Erase failed Block - 0:0:0x045D
  Erase failed Block - 0:0:0x045F
  Erase failed Block - 0:0:0x0462
  Erase failed Block - 0:0:0x0463
  Erase failed Block - 0:0:0x0464
  Erase failed Block - 0:0:0x0465
  Erase failed Block - 0:0:0x0467
  Erase failed Block - 0:0:0x0468
  Erase failed Block - 0:0:0x0469
  Erase failed Block - 0:0:0x046B
  Erase failed Block - 0:0:0x046D
  Erase failed Block - 0:0:0x046F
  Erase failed Block - 0:0:0x0471
  Erase failed Block - 0:0:0x0472
  Erase failed Block - 0:0:0x0473
  Erase failed Block - 0:0:0x0474
  Erase failed Block - 0:0:0x0476
  Erase failed Block - 0:0:0x0477
  Erase failed Block - 0:0:0x0479
  Erase failed Block - 0:0:0x047A
  Erase failed Block - 0:0:0x047B
  Erase failed Block - 0:0:0x047C
  Erase failed Block - 0:0:0x047E
  Erase failed Block - 0:0:0x047F
  Erase failed Block - 0:0:0x0480
  Erase failed Block - 0:0:0x0481
  Erase failed Block - 0:0:0x0482
  Erase failed Block - 0:0:0x0483
  Erase failed Block - 0:0:0x0484
  Erase failed Block - 0:0:0x0485
  Erase failed Block - 0:0:0x0486
  Erase failed Block - 0:0:0x0487
  Erase failed Block - 0:0:0x0488
  Erase failed Block - 0:0:0x0489
  Erase failed Block - 0:0:0x048A
  Erase failed Block - 0:0:0x048B
  Erase failed Block - 0:0:0x048C
  Erase failed Block - 0:0:0x048D
  Erase failed Block - 0:0:0x048E
  Erase failed Block - 0:0:0x048F
  Erase failed Block - 0:0:0x0490
  Erase failed Block - 0:0:0x0491
  Erase failed Block - 0:0:0x0492
  Erase failed Block - 0:0:0x0494
  Erase failed Block - 0:0:0x0495
  Erase failed Block - 0:0:0x0496
  Erase failed Block - 0:0:0x0497
  Erase failed Block - 0:0:0x0498
  Erase failed Block - 0:0:0x0499
  Erase failed Block - 0:0:0x049A
  Erase failed Block - 0:0:0x049B
  Erase failed Block - 0:0:0x049C
  Erase failed Block - 0:0:0x049D
  Erase failed Block - 0:0:0x049E
  Erase failed Block - 0:0:0x049F
  Erase failed Block - 0:0:0x04C7
  Erase failed Block - 0:0:0x0523
  Erase failed Block - 0:0:0x05A3
  Erase failed Block - 0:0:0x05C4
  Erase failed Block - 0:0:0x05D7
  Erase failed Block - 0:0:0x0602
  Erase failed Block - 0:0:0x0603
  Erase failed Block - 0:0:0x0606
  Erase failed Block - 0:0:0x0607
  Erase failed Block - 0:0:0x060A
  Erase failed Block - 0:0:0x060B
  Erase failed Block - 0:0:0x060D
  Erase failed Block - 0:0:0x060F
  Erase failed Block - 0:0:0x0610
  Erase failed Block - 0:0:0x0611
  Erase failed Block - 0:0:0x0612
  Erase failed Block - 0:0:0x0613
  Erase failed Block - 0:0:0x0614
  Erase failed Block - 0:0:0x0616
  Erase failed Block - 0:0:0x0617
  Erase failed Block - 0:0:0x0618
  Erase failed Block - 0:0:0x061A
  Erase failed Block - 0:0:0x061B
  Erase failed Block - 0:0:0x061E
  Erase failed Block - 0:0:0x061F
  Erase failed Block - 0:0:0x0620
  Erase failed Block - 0:0:0x0621
  Erase failed Block - 0:0:0x0622
  Erase failed Block - 0:0:0x0623
  Erase failed Block - 0:0:0x0626
  Erase failed Block - 0:0:0x0627
  Erase failed Block - 0:0:0x0629
  Erase failed Block - 0:0:0x062A
  Erase failed Block - 0:0:0x062E
  Erase failed Block - 0:0:0x062F
  Erase failed Block - 0:0:0x0631
  Erase failed Block - 0:0:0x0632
  Erase failed Block - 0:0:0x0633
  Erase failed Block - 0:0:0x0636
  Erase failed Block - 0:0:0x0637
  Erase failed Block - 0:0:0x0638
  Erase failed Block - 0:0:0x0639
  Erase failed Block - 0:0:0x063A
  Erase failed Block - 0:0:0x063B
  Erase failed Block - 0:0:0x063C
  Erase failed Block - 0:0:0x063E
  Erase failed Block - 0:0:0x063F
  Erase failed Block - 0:0:0x0640
  Erase failed Block - 0:0:0x0641
  Erase failed Block - 0:0:0x0643
  Erase failed Block - 0:0:0x0644
  Erase failed Block - 0:0:0x0645
  Erase failed Block - 0:0:0x0647
  Erase failed Block - 0:0:0x0649
  Erase failed Block - 0:0:0x064B
  Erase failed Block - 0:0:0x064C
  Erase failed Block - 0:0:0x064D
  Erase failed Block - 0:0:0x064F
  Erase failed Block - 0:0:0x0650
  Erase failed Block - 0:0:0x0653
  Erase failed Block - 0:0:0x0654
  Erase failed Block - 0:0:0x0655
  Erase failed Block - 0:0:0x0657
  Erase failed Block - 0:0:0x0659
  Erase failed Block - 0:0:0x065B
  Erase failed Block - 0:0:0x065C
  Erase failed Block - 0:0:0x065D
  Erase failed Block - 0:0:0x065F
  Erase failed Block - 0:0:0x0662
  Erase failed Block - 0:0:0x0663
  Erase failed Block - 0:0:0x0664
  Erase failed Block - 0:0:0x0665
  Erase failed Block - 0:0:0x0667
  Erase failed Block - 0:0:0x0668
  Erase failed Block - 0:0:0x0669
  Erase failed Block - 0:0:0x066B
  Erase failed Block - 0:0:0x066D
  Erase failed Block - 0:0:0x066F
  Erase failed Block - 0:0:0x0671
  Erase failed Block - 0:0:0x0672
  Erase failed Block - 0:0:0x0673
  Erase failed Block - 0:0:0x0674
  Erase failed Block - 0:0:0x0676
  Erase failed Block - 0:0:0x0677
  Erase failed Block - 0:0:0x0679
  Erase failed Block - 0:0:0x067A
  Erase failed Block - 0:0:0x067B
  Erase failed Block - 0:0:0x067C
  Erase failed Block - 0:0:0x067E
  Erase failed Block - 0:0:0x067F
  Erase failed Block - 0:0:0x0680
  Erase failed Block - 0:0:0x0681
  Erase failed Block - 0:0:0x0682
  Erase failed Block - 0:0:0x0683
  Erase failed Block - 0:0:0x0684
  Erase failed Block - 0:0:0x0685
  Erase failed Block - 0:0:0x0686
  Erase failed Block - 0:0:0x0687
  Erase failed Block - 0:0:0x0688
  Erase failed Block - 0:0:0x0689
  Erase failed Block - 0:0:0x068A
  Erase failed Block - 0:0:0x068B
  Erase failed Block - 0:0:0x068C
  Erase failed Block - 0:0:0x068D
  Erase failed Block - 0:0:0x068E
  Erase failed Block - 0:0:0x068F
  Erase failed Block - 0:0:0x0690
  Erase failed Block - 0:0:0x0691
  Erase failed Block - 0:0:0x0692
  Erase failed Block - 0:0:0x0694
  Erase failed Block - 0:0:0x0695
  Erase failed Block - 0:0:0x0696
  Erase failed Block - 0:0:0x0697
  Erase failed Block - 0:0:0x0698
  Erase failed Block - 0:0:0x0699
  Erase failed Block - 0:0:0x069A
  Erase failed Block - 0:0:0x069B
  Erase failed Block - 0:0:0x069C
  Erase failed Block - 0:0:0x069D
  Erase failed Block - 0:0:0x069E
  Erase failed Block - 0:0:0x069F
  Erase failed Block - 0:0:0x06B3
  Erase failed Block - 0:0:0x07C1
  ---> Max Bad of Plane (190,242)
  ---> Max BAD/DIE = 242
Total good blocks after SCAN: 1618 / 2048, Bad block=430
==> 2-Plane mode
Max. Bad Block Allowed = 82(430)
### Error: Too many bad block.
### Error: Low level format failed ###
SafeErase (0,2048)
Ending Time: 01:53:52
协议版本: USB 2.00
 当前速度: 高速(HighSpeed)
 电力消耗: 100mA
USB设备ID: VID = 0C76 PID = 0005
设备供应商: GENERIC
 设备名称: USB Mass Storage
设备修订版: 0100
产品制造商: GENERIC
 产品型号: USB Mass Storage
产品修订版: 1.00
 芯片厂商: SSS(鑫创)
 芯片型号: SSS6691-B3
闪存识别码:  ADD7949A - Hynix(海力士) - 1CE/单通道 [MLC-8K] -> 总容量 = 4GB
量产不成功 我找了三天了
离线auq0880wcw
只看该作者 1楼 发表于: 2012-02-10
本帖最近打赏记录:共1条打赏M币+5
离线gamester
只看该作者 2楼 发表于: 2012-02-10
本帖最近打赏记录:共2条打赏M币+10
离线shuishou
只看该作者 3楼 发表于: 2012-02-10
回 楼主(tjliaomao) 的帖子
本帖最近打赏记录:共1条打赏M币+5
离线zgsxzzj
只看该作者 4楼 发表于: 2012-02-10
