  • 2239阅读
  • 4回复
[另类]直流电机 1602 [复制链接]
只看楼主 倒序阅读 我要置顶 楼主  发表于: 2012-07-30
#include <reg52.h>
#include <intrins.h>
#define uchar unsigned char
#define uint  unsigned int
sbit RS=P2^2;
sbit RW=P2^3;
sbit E=P2^4;
//Delay Function
void Delay_Ms(uint ms)
    uchar t;
    while(ms--)
        for(t=0;t<120;t++);
//Busy Checking Function
uchar Busy_Check()
    uchar lcd_status;
    RS=0;
    RW=1;
    E=1;
    Delay_Ms(1);
    lcd_status=P0;
    E=0;
    return lcd_status;
//Write LCD Command Function
void Write_LCD_Command(uchar cmd)
     while((Busy_Check()&0x80)==0x80); //busy! wait!!!
    RS=0;
    RW=0;
    E=0;
    P0=cmd;
    E=1;
    Delay_Ms(1);
    E=0;
//Write LCD Data Function
void Write_LCD_Data(uchar dat)
    RS=1;
    RW=0;
    E=0;
    P0=dat;
    E=1;
    Delay_Ms(1);
    E=0;
//LCD Initialize Funtion
void  Initialize_LCD()
    Write_LCD_Command(0x38);
    Delay_Ms(1);
    Write_LCD_Command(0x01);
    Delay_Ms(1);
    Write_LCD_Command(0x06);
    Delay_Ms(1);
    Write_LCD_Command(0x0c);
    Delay_Ms(1);
//Display String Function
void Display_String(uchar x,uchar y,uchar *str)
    uchar i=0;
    if(y==0)                     //setting display char start
        Write_LCD_Command(0x80|x);
    if(y==1)
        Write_LCD_Command(0xc0|x);
    for(i=0;(i<16)&&(str!='\0');i++)
        Write_LCD_Data(str);
离线飙风人生
只看该作者 1楼 发表于: 2012-07-30
只看该作者 2楼 发表于: 2012-07-30
只看该作者 3楼 发表于: 2012-07-30
离线sumandigit
只看该作者 4楼 发表于: 2012-07-30
