  • 3035阅读
  • 4回复
[另类]DIY-LM8365时钟-1 [复制链接]
离线gongfu64@liv
只看楼主 倒序阅读 我要置顶 楼主  发表于: 2012-10-08
LM8365电路做成有时钟显示,眼镜能红录变色的招财猫
市场上有一种会招手的金色招财猫(用太阳能电池、高在12.0公分)
本人利用了其壳体、内部摆动线路,新增加时间数显电路、红录变色电路、外接直流源。
[size=font-size:12.0pt,12.0pt]在装太阳能电池的空间调上四只数显管,内部增加了时钟电路及红、录变色电路。外接[size=font-size:12.0pt,12.0pt]6V[size=font-size:12.0pt,12.0pt]直流源。做成[size=font-size:12.0pt,12.0pt]有时钟显示[size=font-size:12.0pt,12.0pt](调正时间的三只按纽在底部)[size=font-size:12.0pt,12.0pt],眼镜能红录变色的招财猫[size=font-size:12.0pt,12.0pt][size=font-size:12.0pt,12.0pt]
[size=font-size:12.0pt,12.0pt]接通电源即显示时钟(底下有三只按钮来调整时间);[size=font-size:12.0pt,12.0pt]
[size=font-size:12.0pt,12.0pt]身后一只按纽按下后:手臂会摆动、眼镜会红录变色、底座出现一圈兰光。[size=font-size:12.0pt,12.0pt]
[size=font-size:12.0pt,12.0pt]时钟电路采用[size=font-size:12.0pt,12.0pt]LM8365[size=font-size:12.0pt,12.0pt][size=font-size:12.0pt,12.0pt]CD4017[size=font-size:12.0pt,12.0pt][size=font-size:12.0pt,12.0pt]CD4060[size=font-size:12.0pt,12.0pt]产生[size=font-size:12.0pt,12.0pt]60Hz[size=font-size:12.0pt,12.0pt]标准时基信号[size=font-size:12.0pt,12.0pt],校正后每天走时误差在[size=font-size:12.0pt,12.0pt]0.5[size=font-size:12.0pt,12.0pt]秒。[size=font-size:12.0pt,12.0pt]
[size=font-size:12.0pt,12.0pt]该时钟走时准确,调校方便,夜间看时清楚,制作容易。[size=font-size:12.0pt,12.0pt]
[size=font-size:12.0pt,12.0pt]红、录变色电路用[size=font-size:12.0pt,12.0pt]CD4022[size=font-size:12.0pt,12.0pt](或[size=font-size:12.0pt,12.0pt]CD4017[size=font-size:12.0pt,12.0pt])及二只[size=font-size:12.0pt,12.0pt]NPN[size=font-size:12.0pt,12.0pt]三极管组成。[size=font-size:12.0pt,12.0pt]
[size=font-size:12.0pt,12.0pt]由于在底部加了电路印刷板,造成向下凸出,为此利用旧瓶盖或废盒(直经在[size=font-size:12.0pt,12.0pt]90mm[size=font-size:12.0pt,12.0pt]以上,本人用[size=font-size:12.0pt,12.0pt]“[size=font-size:12.0pt,12.0pt]绿盾牌维[size=font-size:12.0pt,12.0pt]E[size=font-size:12.0pt,12.0pt]尿素霜[size=font-size:12.0pt,12.0pt]”[size=font-size:12.0pt,12.0pt]盒,黄色盆正好配金色招财猫),下面再加一片[size=font-size:12.0pt,12.0pt]5-6mm[size=font-size:12.0pt,12.0pt]厚有机玻璃板(此处发兰光,不用也可)、[size=font-size:12.0pt,12.0pt]1-1.5mm[size=font-size:12.0pt,12.0pt]厚的不锈钢板(铝、塑料都可以)。下面装三只橡皮脚。[size=font-size:12.0pt,12.0pt]
[size=font-size:12.0pt,12.0pt]手臂摆动电路利用原来,但因现在电压为[size=font-size:12.0pt,12.0pt]6V[size=font-size:12.0pt,12.0pt](原来[size=font-size:12.0pt,12.0pt]2V[size=font-size:12.0pt,12.0pt]左右),所以加电阻降低电压。[size=font-size:12.0pt,12.0pt]
[size=font-size:12.0pt,12.0pt]㈠时钟电路[size=font-size:12.0pt,12.0pt]
[size=font-size:12.0pt,12.0pt]LM8365[size=font-size:12.0pt,12.0pt]是三洋公司生产的系列时钟集成芯片中的一种,它不但可以显示时间,还可以显示日期(月/日);可按12小时或24小时设置两个定时输出;VDD电压在6.5V-21V,直接驱动LED显示;有减法计时的定时功能(60秒定时)。该电路除可显示“时、分”外还可以显示“月、日”(将[size=font-size:12.0pt,12.0pt]SNOOZE[size=font-size:12.0pt,12.0pt]连接VDD就同时显示,且AO1、AO2的输出暂仃10 钟[size=font-size:12.0pt,12.0pt])。LED由LM8365直接驱动。37脚为时钟CLK输入选择,悬空为60Hz输入,接VDD时为50Hz输入。39脚为12,24小时显示系统选择,悬空为12小时显示,接VDD为24小时显示方式(利用AM、PM、[size=font-size:12.0pt,12.0pt]1Hz[size=font-size:12.0pt,12.0pt]及b/c)。[size=font-size:12.0pt,12.0pt]它是[size=font-size:12.0pt,12.0pt]42[size=font-size:12.0pt,12.0pt]脚双列的塑封件。[size=font-size:12.0pt,12.0pt]
[size=font-size:12.0pt,12.0pt]在这里只用来显示时间(时、分)。[size=font-size:12.0pt,12.0pt]
[size=font-size:12.0pt,12.0pt][size=font-size:12.0pt,12.0pt]60Hz[size=font-size:12.0pt,12.0pt]标准时基[size=font-size:12.0pt,12.0pt]电路[size=font-size:12.0pt,12.0pt]
[size=font-size:12.0pt,12.0pt][size=font-size:12.0pt,12.0pt]CD4060[size=font-size:12.0pt,12.0pt][size=font-size:12.0pt,12.0pt]CD4017[size=font-size:12.0pt,12.0pt]与石英晶振([size=font-size:12.0pt,12.0pt]32768Hz[size=font-size:12.0pt,12.0pt][size=font-size:12.0pt,12.0pt]组成时基电路[size=font-size:12.0pt,12.0pt][size=font-size:12.0pt,12.0pt][size=font-size:12.0pt,12.0pt]钟电路提供精确的60Hz计时脉冲。[size=font-size:12.0pt,12.0pt]
[size=font-size:12.0pt,12.0pt]㈢跳灯电路[size=font-size:12.0pt,12.0pt]
[size=font-size:12.0pt,12.0pt]CD4017[size=font-size:12.0pt,12.0pt]是十进制计数/分频器
[size=font-size:12.0pt,12.0pt]CD4022[size=font-size:12.0pt,12.0pt]是八进制计数/分频器
[size=font-size:12.0pt,12.0pt]数字电路CD4017是十进制计数/分频器,它的内部由计数器及译码器两部分组成,由译码输出实现对脉冲信号的分配,整个输出时序就是Q0、Q1、Q2、…、Q9依次出现与时钟同步的高电平,宽度等于时钟周期。[size=font-size:12.0pt,12.0pt]
[size=font-size:12.0pt,12.0pt]CD4017[size=font-size:12.0pt,12.0pt]有两个时钟端 CP 和INH,若用时钟脉冲的上沿计数,则信号从 CP 端输入;[size=font-size:12.0pt,12.0pt]
[size=font-size:12.0pt,12.0pt]CD4017 [size=font-size:12.0pt,12.0pt]与 CD4022 是一对姊妹产品,主要区别是 CD4022 是八进制的,所以译码输出仅有 Y0~Y7,每输入 8 个脉冲周期,就可得到一个进位输出,它们的管脚相同,不过 CD4022 的 6、9 脚是空脚。
[ 此帖被gongfu64@liv在2012-10-09 08:22重新编辑 ]
关键词: DIYLED
离线希望
只看该作者 1楼 发表于: 2012-10-08
离线qfming-twb
只看该作者 2楼 发表于: 2012-10-08
只看该作者 3楼 发表于: 2012-10-09
离线gongfu64@liv
只看该作者 4楼 发表于: 2012-10-09
回 3楼(亲爱的混蛋) 的帖子
