  • 5352阅读
  • 17回复
[Indilinx]求IDX1100m00故障分析!(已解决!) [复制链接]
离线listwell
只看楼主 倒序阅读 我要置顶 楼主  发表于: 2013-01-14
非常感谢:"hepcboy "和各位朋友的指点,帖子下面我将修复过程写出来,供大家参考!
前些日子朋友给了一块坏的芝奇 64G的ssd硬盘,故障现象是:接入系统识别为128G,磁盘管理不能初始化。这块盘使用了1年多左右。开盘看了一下,控制芯片是IDX110M00的芯片。先将所有F拖焊了一遍,上机,故障依旧。用量产工具:INDILINX_1819_MPTool 检查显示信息如下:
Firmware revision = 0.0
Serial number = AA0013010E0080003
Model number = DIGICUBE SSD
Flash BIST count = 0
Size of SDRAM is 64 MB
SATA/SDRAM test 100%
initialize flash
bank 00(A0) low: EC D7 55 B6 78 high: EC D7 55 B6 78
bank 01(B0) low: EC D7 55 B6 78 high: EC D7 55 B6 78
bank 02(C0) low: EC D7 55 B6 78 high: EC D7 55 B6 78
bank 03(D0) low: EC D7 55 B6 78 high: EC D7 55 B6 78
bank 08(A2) low: EC D7 55 B6 78 high: EC D7 55 B6 78
bank 09(B2) low: EC D7 55 B6 78 high: EC D7 55 B6 78
bank 10(C2) low: EC D7 55 B6 78 high: EC D7 55 B6 78
bank 11(D2) low: EC D7 55 B6 78 high: EC D7 55 B6 78
bank 00(A0)..blank
bank 01(B0)..blank
bank 02(C0)..blank
bank 03(D0)..NOT blank
bank 08(A2)..NOT blank
bank 09(B2)..blank
bank 10(C2)..NOT blank
bank 11(D2)..NOT blank
WARNING: The NAND Flash is not clean (being reworked) !!!
scan list found on bank 3=D0
scan list found on bank 8=A2
scan list found on bank 10=C2
scan list found on bank 11=D2
erasing NAND Flash for rework...2974
ERROR: erase failure bank 8=A2
high pblk_offset = 2974 --> added to runtime bad block list
erasing NAND Flash for rework...4597
ERROR: erase failure bank 3=D0
high pblk_offset = 4597 --> added to runtime bad block list
erasing NAND Flash for rework...6789
high pblk_offset = 6789 --> added to runtime bad block list
erasing NAND Flash for rework...8074
ERROR: erase failure bank 10=C2
high pblk_offset = 8074 --> added to runtime bad block list
erasing NAND Flash for rework...done
scanning initial bad blocks
显示有4个F 为NO Blank,由于我是第一次接触SSD硬盘,实在找不出是哪几个F,所以又拖焊了一遍,上机故障依旧。
请教各位高手几个问题:
1.NO Blank的那四个F,在板子上是哪几个?
2.这种情况是什么原因造成的,能是这4个F都坏了吗?
3.换F的话,只换这4个可以吗?
4.淘宝上哪家卖的F比较好,大概多少钱1个?
多谢了!
修复过程:
根据“hepcboy ”的意见,我使用公版的开卡工具是不能修复这个SSD的,所以我上了芝奇的网站,在技术支持里面找到了带清除功能的专用1916的开卡工具。下载后运行,能够识别到SSD,点"Clean ssd"清除flash,运行起来后有一些黄色的错误提示,我以为还是Flash芯片有问题,但清除能够继续运行,并提示清除成功,真是天大的好消息!根据提示运行“Upgrade F/W”,运行过程因没在电脑旁,没看到,等我回到电脑旁,看到软件提示去除工厂模式跳线。天啊,竟然修好了!
因为第一次修复,没抱什么希望,所以也没记录下来,所以又进行二次开卡,做了一下记录:
1.运行开卡软件,找到SSD,并正确选择Flash型号和容量
2.清除Flash过程信息,怪了第二次运行竟然没有了任何错误提示,之前那些黄色信息都没有了。
enabling factory mode...done
bank 04(A1) low: 00 00 00 00 00         high: 00 00 00 00 00
bank 05(B1) low: 00 00 00 00 00         high: 00 00 00 00 00
bank 06(C1) low: 00 00 00 00 00         high: 00 00 00 00 00
bank 07(D1) low: 00 00 00 00 00         high: 00 00 00 00 00
bank 12(A3) low: 00 00 00 00 00         high: 00 00 00 00 00
bank 13(B3) low: 00 00 00 00 00         high: 00 00 00 00 00
bank 14(C3) low: 00 00 00 00 00         high: 00 00 00 00 00
bank 15(D3) low: 00 00 00 00 00         high: 00 00 00 00 00
bank 16(A4) low: 00 00 00 00 00         high: 00 00 00 00 00
bank 17(B4) low: 00 00 00 00 00         high: 00 00 00 00 00
bank 18(C4) low: 00 00 00 00 00         high: 00 00 00 00 00
bank 19(D4) low: 00 00 00 00 00         high: 00 00 00 00 00
bank 20(A5) low: 00 00 00 00 00         high: 00 00 00 00 00
bank 21(B5) low: 00 00 00 00 00         high: 00 00 00 00 00
bank 22(C5) low: 00 00 00 00 00         high: 00 00 00 00 00
bank 23(D5) low: 00 00 00 00 00         high: 00 00 00 00 00
bank 24(A6) low: 00 00 00 00 00         high: 00 00 00 00 00
bank 25(B6) low: 00 00 00 00 00         high: 00 00 00 00 00
bank 26(C6) low: 00 00 00 00 00         high: 00 00 00 00 00
bank 27(D6) low: 00 00 00 00 00         high: 00 00 00 00 00
bank 28(A7) low: 00 00 00 00 00         high: 00 00 00 00 00
bank 29(B7) low: 00 00 00 00 00         high: 00 00 00 00 00
bank 30(C7) low: 00 00 00 00 00         high: 00 00 00 00 00
bank 31(D7) low: 00 00 00 00 00         high: 00 00 00 00 00
bank_bmp = 00000F0F
scan list found on bank 0=A0
scan list found on bank 1=B0
scan list found on bank 2=C0
scan list found on bank 9=B2
list of initial bad blocks :
bank 0(A0) L: 0 of 8192 (0.00%)
bank 0(A0) H: 0 of 8192 (0.00%)
bank 1(B0) L: 1 of 8192 (0.01%)
4533
bank 1(B0) H: 0 of 8192 (0.00%)
bank 2(C0) L: 0 of 8192 (0.00%)
bank 2(C0) H: 1 of 8192 (0.01%)
7259
bank 3(D0) L: 0 of 8192 (0.00%)
bank 3(D0) H: 1 of 8192 (0.01%)
4597
bank 8(A2) L: 0 of 8192 (0.00%)
bank 8(A2) H: 2 of 8192 (0.02%)
2974 6789
bank 9(B2) L: 0 of 8192 (0.00%)
bank 9(B2) H: 0 of 8192 (0.00%)
bank 10(C2) L: 0 of 8192 (0.00%)
bank 10(C2) H: 1 of 8192 (0.01%)
8074
bank 11(D2) L: 0 of 8192 (0.00%)
bank 11(D2) H: 0 of 8192 (0.00%)
list of runtime bad blocks :
bank 0(A0) L: 0 of 8192 (0.00%) -
bank 0(A0) H: 0 of 8192 (0.00%) -
bank 1(B0) L: 0 of 8192 (0.00%) -
bank 1(B0) H: 0 of 8192 (0.00%) -
bank 2(C0) L: 0 of 8192 (0.00%) -
bank 2(C0) H: 0 of 8192 (0.00%) -
bank 3(D0) L: 0 of 8192 (0.00%) -
bank 3(D0) H: 0 of 8192 (0.00%) -
bank 8(A2) L: 0 of 8192 (0.00%) -
bank 8(A2) H: 0 of 8192 (0.00%) -
bank 9(B2) L: 0 of 8192 (0.00%) -
bank 9(B2) H: 0 of 8192 (0.00%) -
bank 10(C2) L: 0 of 8192 (0.00%) -
bank 10(C2) H: 0 of 8192 (0.00%) -
bank 11(D2) L: 0 of 8192 (0.00%) -
bank 11(D2) H: 0 of 8192 (0.00%) -
NAND flash has been laundered.
3.清除成功,提示运行“Upgrade SSD”
4.开卡程序开始运行,开卡过程也没有任何错误提示!
Firmware revision = 1916
Serial number = DCGS1303101360001
Model number = G.SKILL FALCON 64GB SSD
initialize flash
bank 00(A0)..blank
bank 01(B0)..blank
bank 02(C0)..blank
bank 03(D0)..blank
bank 08(A2)..blank
bank 09(B2)..blank
bank 10(C2)..blank
bank 11(D2)..blank
5.开卡成功,按提示移除工厂模式跳线
6.移除跳线,重启系统,系统发现新硬件,并初始化。格式化后显示容量为59.6G,(难道是原来坏块较多,屏蔽掉了坏块后,容量减小了?这个我不大懂,瞎猜的!)。运行Diskinfo,信息如图
7.芝奇开卡工具含清除功能哦!
这里要说明的是,原来查帖子说开卡要在USB盒上做,可是我这个在USB盒上,开卡工具根本就识别不到,怪怪!所以我整个过程我一直是接在STAT运行的。
好了,整个过程就是这样,饿着肚子完成了作业,也算是给大家一个交代!再次感谢"hepcboy "!
[ 此帖被listwell在2013-01-14 19:00重新编辑 ]
本帖最近打赏记录:共2条打赏M币+17
离线listwell
只看该作者 1楼 发表于: 2013-01-14
离线羊村村长
只看该作者 2楼 发表于: 2013-01-14
回 楼主(listwell) 的帖子
离线listwell
只看该作者 3楼 发表于: 2013-01-14
离线hepcboy
只看该作者 4楼 发表于: 2013-01-14
离线listwell
只看该作者 5楼 发表于: 2013-01-14
回 4楼(hepcboy) 的帖子
离线listwell
只看该作者 6楼 发表于: 2013-01-14
回 4楼(hepcboy) 的帖子
离线hepcboy
只看该作者 7楼 发表于: 2013-01-14
本帖最近打赏记录:共1条打赏M币+10
离线listwell
只看该作者 8楼 发表于: 2013-01-14
回 7楼(hepcboy) 的帖子
离线苹果网
只看该作者 9楼 发表于: 2013-01-14
