  • 4963阅读
  • 11回复
求助TEA加解密问题,用电脑和单片机加密同一个内容结果不一样? [复制链接]
离线fhl323225577
只看楼主 倒序阅读 我要置顶 楼主  发表于: 2013-02-21
求助     TEA加解密问题,用电脑和单片机加密同一个内容结果不一样?
单片机反回的是:
12345678
C0 9C 13 85 0A 74 C4 A2
12345678
电脑反回的是:
12345678
03 c9 89 06 69 53 d1 ad
12345678
单片机是用keil 4生成的代码是
#include "reg52.h"
void send_char(unsigned char txd);
void printuf(char *str, unsigned char cb) ;
void encrypt(unsigned long *v1, unsigned long *v2,unsigned long *k);/*tea加密函数定义*/
void decrypt(unsigned long *v1,unsigned long *v2, unsigned long *k);/*tea解密函数定义*/
unsigned long *key   = (unsigned long *)"1234567890abcde\0";/*常量密钥*/
   unsigned char   tea[8];
   unsigned char i;
void InitUART(void)
    TMOD = 0x20;
    SCON = 0x50;
    TH1 = 0xFD;
    TL1 = TH1;
    PCON = 0x00;
    EA = 1;
    ES = 1;
    TR1 = 1;
    void main()
  unsigned long *y1,*y2;
   tea[0]=0x31;
   tea[1]=0x32;
   tea[2]=0x33;
   tea[3]=0x34;
   tea[4]=0x35;
   tea[5]=0x36;
   tea[6]=0x37;
   tea[7]=0x38;
InitUART();
  for (i=0; i < 8; i++)
  send_char(tea);
  send_char(13);
  y1=(unsigned long *)&tea[0];
     y2=(unsigned long *)&tea[4];
     encrypt (y1,y2,key) ;
  printuf("%x ",tea);
  send_char(13);
  decrypt(y1,y2,key);
  send_char(tea);
  send_char(13);
while(1) ;
  unsigned long y=*v1, z=*v2, sum=0, i;
  unsigned long delta=0x9e3779b9;
  unsigned long a=k[0], b=k[1], c=k[2], d=k[3];
  for (i=0; i < 32; i++)
  sum += delta;
   y += ((z<<4) + a) ^ (z + sum) ^ ((z>>5) + b);
   z += ((y<<4) + c) ^ (y + sum) ^ ((y>>5) + d);     }
   *v1=y;
   *v2=z;
  unsigned long y=*v1, z=*v2, sum=0xC6EF3720, i;
  for(i=0; i<32; i++) {
  z -= ((y<<4) + c) ^ (y + sum) ^ ((y>>5) + d);
  y -= ((z<<4) + a) ^ (z + sum) ^ ((z>>5) + b);
  sum -= delta;                                     }
  *v1=y;
  *v2=z;
// 传送一个字符
SBUF = txd;
while(!TI);    // 等特数据传送
TI = 0;     // 清除数据传送标志
// *str内容中遇到%x的内,就会从cb中的值转成十六进显示    开始
code char hex[16]  = {'0', '1', '2', '3', '4', '5', '6', '7', '8', '9', 'A', 'B', 'C', 'D', 'E', 'F'};
void printuf(char *str, unsigned char cb)   //*str内容中遇到%x的内,就会从cb中的值转成十六进显示
idata char *ct = str;
idata char cx1;
idata char cx2;
while (*ct != '\0')
  if (*ct == '%')
   if (*(ct + 1) == 'x')
    ct += 2;
    cx1 = cb / 16;
    cx2 = cb % 16;
    send_char (hex[cx1]);
    send_char(hex[cx2]);
    continue;
   if (*(ct + 1) == 'c')
    ct += 2;
   send_char(cb);
    continue;
  if (*ct == '\n')
  send_char(13);
  send_char(*ct);
  ct++;
// *str内容中遇到%x的内,就会从cb中的值转成十六进显示 结束
电脑上是用WIN-TC 1.91板。代码是
#include<stdio.h>
  #include<string.h>
  void encrypt(unsigned long *v1, unsigned long *v2,unsigned long *k);/*加密函数定义*/
   void decrypt(unsigned long *v1,unsigned long *v2, unsigned long *k);/*解密函数定义*/
    void main()
   unsigned char de[8];
   unsigned char i;
    de[0]=0x31;
    de[1]=0x32;
    de[2]=0x33;
    de[3]=0x34;
    de[4]=0x35;
    de[5]=0x36;
    de[6]=0x37;
    de[7]=0x38;
  for (i=0;i<8;i++)
           printf("%c",(unsigned char)de);
            printf("\n");
         y1=(unsigned long *)&de[0];
         y2=(unsigned long *)&de[4];
          encrypt(y1,y2,key);/*加密*/          for (i=0;i<8;i++)
           printf("%2x ",(unsigned char)de);
            printf("\n");
               decrypt(y1,y2,key);/*解密*/              for (i=0;i<8;i++)
            printf("\n");
                getch();
                 }                 void encrypt(unsigned long *v1, unsigned long *v2,unsigned long *k)
                 {  unsigned long y=*v1, z=*v2, sum=0, i;
                  {sum += delta;
                   *v1=y;
                    *v2=z;  }
                      {     unsigned long y=*v1, z=*v2, sum=0xC6EF3720, i;
                      sum -= delta;                                     }
                      *v1=y;     *v2=z;  }
离线fhl323225577
只看该作者 1楼 发表于: 2013-02-22
离线std_johnwoo
只看该作者 2楼 发表于: 2013-02-23
回 1楼(fhl323225577) 的帖子
离线cmheia
只看该作者 3楼 发表于: 2013-02-23
回 2楼(std_johnwoo) 的帖子
离线fhl323225577
只看该作者 4楼 发表于: 2013-02-23
离线fhl323225577
只看该作者 5楼 发表于: 2013-02-23
离线liyf
只看该作者 6楼 发表于: 2013-02-23
离线风云剑
只看该作者 7楼 发表于: 2013-02-23
离线wb.chn
只看该作者 8楼 发表于: 2013-02-23
[ 此帖被wb.chn在2013-02-23 23:30重新编辑 ]
离线fhl323225577
只看该作者 9楼 发表于: 2013-02-24
