Array
  • 3592阅读
  • 3回复
[鑫创]金士顿量产失败不显示内存sss6692-b5 [复制链接]
离线bianbss
只看楼主 倒序阅读 我要置顶 楼主  发表于: 2013-05-09
 设备描述: [F:]USB 大容量存储设备(GENERIC USB Mass Storage)
 设备类型:  大容量存储设备
 协议版本: USB 2.00
 当前速度: 高速(HighSpeed)
 电力消耗: 100mA
USB设备ID: VID = 0C76 PID = 0005
设备序列号: 00FFA2FDDBEEFD5090A32029
设备供应商: 3system
 设备名称: USB Flash Disk
设备修订版: 0100
产品制造商: GENERIC
 产品型号: USB Mass Storage
产品修订版: 1.00
 主控厂商: SSS(鑫创)
 主控型号: SSS6692-B5
闪存识别码:  2C68044A - Micron(美光) MT29F32G08CBACA - 1CE/单通道 [MLC-4K] -> 总容量 = 4GB
量产工具里cardinfo提示:
---------------- Device 1------------------
FW version:0xB5
  CE-0, Flash ID=2C-68-04-4A-A9-00-00
Found boot block at (0x00000A00)
### Error: Read MBR
错误提示error:8
Device 1:0xB5
MP Version:2.182
INI_File_Name:6692_IM25_256P_4KB.INI
Random delay 0 msec
--- Download MP ISP ---
Auto CE: 0x00 0xFF 0xFF 0xFF 0xFF 0xFF 0xFF 0xFF
CE-0, Flash ID=2C-68-04-4A-A9-00-00-00
Page/Block=256
Searching SORTING BOARD table ...
--> Not Found
Found BACKUP Table (00000A3A-000A)
Defect Table (00001000-0010)
  Original Bad Block - 0:0x0002
  Original Bad Block - 0:0x0003
  Original Bad Block - 0:0x0004
  Original Bad Block - 0:0x0005
  Original Bad Block - 0:0x0006
  Original Bad Block - 0:0x0007
  Original Bad Block - 0:0x0008
  Original Bad Block - 0:0x0009
  Original Bad Block - 0:0x07DC
  Original Bad Block - 0:0x07DD
  Original Bad Block - 0:0x0A00
  Original Bad Block - 0:0x0A01
  Original Bad Block - 0:0x0A02
  Original Bad Block - 0:0x0A03
  Original Bad Block - 0:0x0A04
  Original Bad Block - 0:0x0A05
  Original Bad Block - 0:0x0A06
  Original Bad Block - 0:0x0A07
  Original Bad Block - 0:0x0A08
  Original Bad Block - 0:0x0A09
  Original Bad Block - 0:0x0A0C
  Original Bad Block - 0:0x0A0E
  Original Bad Block - 0:0x0A0F
  Original Bad Block - 0:0x0A10
  Original Bad Block - 0:0x0A11
  Original Bad Block - 0:0x0A12
  Original Bad Block - 0:0x0A14
  Original Bad Block - 0:0x0A17
  Original Bad Block - 0:0x0A18
  Original Bad Block - 0:0x0A19
  Original Bad Block - 0:0x0A1B
  Original Bad Block - 0:0x0A1C
  Original Bad Block - 0:0x0A1D
  Original Bad Block - 0:0x0A1E
  Original Bad Block - 0:0x0A1F
  Original Bad Block - 0:0x0A20
  Original Bad Block - 0:0x0A22
  Original Bad Block - 0:0x0A24
  Original Bad Block - 0:0x0A25
  Original Bad Block - 0:0x0A27
  Original Bad Block - 0:0x0A29
  Original Bad Block - 0:0x0A2A
  Original Bad Block - 0:0x0A2C
  Original Bad Block - 0:0x0A2E
  Original Bad Block - 0:0x0A30
  Original Bad Block - 0:0x0A31
  Original Bad Block - 0:0x0A32
  Original Bad Block - 0:0x0A33
  Original Bad Block - 0:0x0A34
  Original Bad Block - 0:0x0A35
  Original Bad Block - 0:0x0A36
  Original Bad Block - 0:0x0A37
  Original Bad Block - 0:0x0A38
  Original Bad Block - 0:0x0A39
  Original Bad Block - 0:0x0A3A
  Original Bad Block - 0:0x0A3B
  Original Bad Block - 0:0x0A3C
  Original Bad Block - 0:0x0A3D
  Original Bad Block - 0:0x0A3E
  Original Bad Block - 0:0x0A3F
  Original Bad Block - 0:0x0A40
  Original Bad Block - 0:0x0A41
  Original Bad Block - 0:0x0A42
  Original Bad Block - 0:0x0A43
  Original Bad Block - 0:0x0A44
  Original Bad Block - 0:0x0A45
  Original Bad Block - 0:0x0A46
  Original Bad Block - 0:0x0A47
  Original Bad Block - 0:0x0A48
  Original Bad Block - 0:0x0A49
  Original Bad Block - 0:0x0A4A
  Original Bad Block - 0:0x0A4B
  Original Bad Block - 0:0x0A4C
  Original Bad Block - 0:0x0A4D
  Original Bad Block - 0:0x0A4E
  Original Bad Block - 0:0x0A4F
  Original Bad Block - 0:0x0A91
  Original Bad Block - 0:0x0A92
  Original Bad Block - 0:0x0A93
  Original Bad Block - 0:0x0A94
  Original Bad Block - 0:0x0A95
  Original Bad Block - 0:0x0A96
  Original Bad Block - 0:0x0A97
  Original Bad Block - 0:0x0AD9
  Original Bad Block - 0:0x0ADA
  Original Bad Block - 0:0x0ADB
  Original Bad Block - 0:0x0ADC
  Original Bad Block - 0:0x0ADD
  Original Bad Block - 0:0x0ADE
  Original Bad Block - 0:0x0ADF
Defect Table shows 4006 Good blocks, 90 Bad blocks
SafeErase (0,4096)
  Erase failed Block - 0:0:0x0002
  Erase failed Block - 0:0:0x0003
  Erase failed Block - 0:0:0x0004
  Erase failed Block - 0:0:0x0005
  Erase failed Block - 0:0:0x0006
  Erase failed Block - 0:0:0x0007
  Erase failed Block - 0:0:0x0008
  Erase failed Block - 0:0:0x0009
  Erase failed Block - 0:0:0x07DC
  Erase failed Block - 0:0:0x07DD
  Erase failed Block - 0:0:0x0A00
  Erase failed Block - 0:0:0x0A01
  Erase failed Block - 0:0:0x0A02
  Erase failed Block - 0:0:0x0A03
  Erase failed Block - 0:0:0x0A04
  Erase failed Block - 0:0:0x0A05
  Erase failed Block - 0:0:0x0A06
  Erase failed Block - 0:0:0x0A07
  Erase failed Block - 0:0:0x0A08
  Erase failed Block - 0:0:0x0A09
  Erase failed Block - 0:0:0x0A0C
  Erase failed Block - 0:0:0x0A0E
  Erase failed Block - 0:0:0x0A0F
  Erase failed Block - 0:0:0x0A10
  Erase failed Block - 0:0:0x0A11
  Erase failed Block - 0:0:0x0A12
  Erase failed Block - 0:0:0x0A14
  Erase failed Block - 0:0:0x0A17
  Erase failed Block - 0:0:0x0A18
  Erase failed Block - 0:0:0x0A19
  Erase failed Block - 0:0:0x0A1B
  Erase failed Block - 0:0:0x0A1C
  Erase failed Block - 0:0:0x0A1D
  Erase failed Block - 0:0:0x0A1E
  Erase failed Block - 0:0:0x0A1F
  Erase failed Block - 0:0:0x0A20
  Erase failed Block - 0:0:0x0A22
  Erase failed Block - 0:0:0x0A24
  Erase failed Block - 0:0:0x0A25
  Erase failed Block - 0:0:0x0A27
  Erase failed Block - 0:0:0x0A29
  Erase failed Block - 0:0:0x0A2A
  Erase failed Block - 0:0:0x0A2C
  Erase failed Block - 0:0:0x0A2E
  Erase failed Block - 0:0:0x0A30
  Erase failed Block - 0:0:0x0A31
  Erase failed Block - 0:0:0x0A32
  Erase failed Block - 0:0:0x0A33
  Erase failed Block - 0:0:0x0A34
  Erase failed Block - 0:0:0x0A35
  Erase failed Block - 0:0:0x0A36
  Erase failed Block - 0:0:0x0A37
  Erase failed Block - 0:0:0x0A38
  Erase failed Block - 0:0:0x0A39
  Erase failed Block - 0:0:0x0A3A
  Erase failed Block - 0:0:0x0A3B
  Erase failed Block - 0:0:0x0A3C
  Erase failed Block - 0:0:0x0A3D
  Erase failed Block - 0:0:0x0A3E
  Erase failed Block - 0:0:0x0A3F
  Erase failed Block - 0:0:0x0A40
  Erase failed Block - 0:0:0x0A41
  Erase failed Block - 0:0:0x0A42
  Erase failed Block - 0:0:0x0A43
  Erase failed Block - 0:0:0x0A44
  Erase failed Block - 0:0:0x0A45
  Erase failed Block - 0:0:0x0A46
  Erase failed Block - 0:0:0x0A47
  Erase failed Block - 0:0:0x0A48
  Erase failed Block - 0:0:0x0A49
  Erase failed Block - 0:0:0x0A4A
  Erase failed Block - 0:0:0x0A4B
  Erase failed Block - 0:0:0x0A4C
  Erase failed Block - 0:0:0x0A4D
  Erase failed Block - 0:0:0x0A4E
  Erase failed Block - 0:0:0x0A4F
  Erase failed Block - 0:0:0x0A91
  Erase failed Block - 0:0:0x0A92
  Erase failed Block - 0:0:0x0A93
  Erase failed Block - 0:0:0x0A94
  Erase failed Block - 0:0:0x0A95
  Erase failed Block - 0:0:0x0A96
  Erase failed Block - 0:0:0x0A97
  Erase failed Block - 0:0:0x0AD9
  Erase failed Block - 0:0:0x0ADA
  Erase failed Block - 0:0:0x0ADB
  Erase failed Block - 0:0:0x0ADC
  Erase failed Block - 0:0:0x0ADD
  Erase failed Block - 0:0:0x0ADE
  Erase failed Block - 0:0:0x0ADF
  ---> Max Bad of Plane (23,22)
  ---> Max BAD/DIE = 23
Total good blocks after SCAN: 4006 / 4096, Bad block=90
==> 2-Plane mode
Adjust Max LBA = 7995392, 7954368
MaxWindows=2/1942, MaxLBA=7954368, Size=3883 MB
Max BAD of one plane is 23 (27),4096,1,1
RootSector=0xF8B,Sec/Cluster=32, SuperPage=32 ---> Alignment=21
Boot Block=0x000A,0x000C
Lun0(7954368), Lun1(0), Public=7954368, Secure=0, CDROM=0
Special FE Config = 54-0B-00
Defect Table Block=0x0010
--- Download ISP Code:F:\20130509_013649846\3S6692_MP_VER2182\ISP_CODE\6692_B5-IM_20110217_VBB0300_5DA8.BIN---
--- ISP Code installed.
Public,Secure,CDROM = 7954368,0,0
PHY: E2/E4/E6=72h/36h/04h,  D0/C0/CFG10=DFh/0Bh/87h
SN=00E04C125B25FD5099CB2030
=== Preformat Done ===
Low Level Format DONE
Store INI/ERROR MSG to Block-0x000A:78.
### Error: Device capacity is 0 bytes
求各位大神讲解  万分谢谢!
[ 此帖被bianbss在2013-05-09 15:46重新编辑 ]
关键词: sss6692-b5
离线shuishou
只看该作者 1楼 发表于: 2013-05-09
回 楼主(bianbss) 的帖子
离线lvg
只看该作者 2楼 发表于: 2013-05-09
离线lpbdiy
只看该作者 3楼 发表于: 2013-06-18
Array
