  • 20229阅读
  • 58回复
[存储]Synology DS212j NAS网络存储安装硬盘顺便拆看做工 [复制链接]
离线pcdoctor
只看楼主 倒序阅读 我要置顶 楼主  发表于: 2013-08-21
全新的synology NAS盒子,型号DS212j
支持双硬盘,RAID 1
外观
后面,
感觉这款型号不够新潮,没有支持USB3.0,只有两个USB2.0口
还有一个网口,还好是支持千兆网的
拆开,看内部
如果只是装硬盘,就不用继续拆了
不过拆客嘛,还是忍不住继续拆,把板子也拆开看看
两块WD的红盘
最后上好外壳,
外壳也加了螺丝固定
下面是转贴的官方网站的详细介绍,英文版,有兴趣的可以读读,
这东西,本身是个小小的Linux系统,厂家进行了二次开发,支持很多种协议,有一定玩的空间
Hardware
  • CPU Frequency : 1.2GHz
  • Hardware Encrypted Engine
  • Memory : DDR2 256MB
  • Internal HDD/SSD : 3.5" or 2.5" SATA(II) X 2 (with Disk Holder) (Hard drive not included)
  • Max Internal Capacity : 6TB (2X 3TB HDD) (Capacity may vary by RAID types) (See All Supported HDD)
  • External HDD Interface : USB 2.0 Port X 2
  • Size (HxWxD) : 165 X 100 X 225.5 mm
  • Weight : 0.94Kg
  • LAN : Gigabit X1
  • System Fan : 92x92mm X 1
  • Wireless Support
  • Noise Level : 18.3 dB(A)
  • Power Recovery
  • AC Input Power Voltage : 100V to 240V AC
  • Power Frequency : 50 / 60Hz, Single Phase
  • Power Consumption : 17.6W (Access) ; 5.5W (HDD Hibernation)
  • Operating Temperature : 40 to 95°F (5 to 35°C)
  • Storage Temperature : 15 to 155°F (-10 to 70°C)
  • Relative Humidity : 5% to 95% RH
  • Maximum Operating Altitude : 10,000 feet
  • Certification : FCC Class B, CE Class B, BSMI Class B
  • Warranty : 2 Years
Applications
  • File Browser
  • File Station
  • FTP Server
  • Bandwidth Control, Custom FTP Passive Port Range, Anonymous FTP, Transfer Log
  • Mail Server
  • Supported Mail Server Protocol : POP3, SMTP, IMAP
  • Web Station
  • Virtual Host (up to 30 websites)
  • PHP/MySQL
  • Alternative HTTP Error Page
  • 3rd-Party Applications Support
  • Surveillance Station
  • MAX IP cam # (Licenses required) : 5 (1 Free License) (See All Supported IP Cameras)
  • Total frame rate (FPS) : 50 FPS @ D1 (NTSC:720x480, PAL:720x576), 10 FPS @ WXGA (1280x800).
  • Recording Modes : Manual, Continuous, Motion Detection, Alarm, Motion Detection and Alarm
  • Event Playback : Sync Mode (4 Channels), Time Slicing Mode
  • Centralized Management
  • Compression Formats : MJPEG, MPEG-4, H.264
  • Photo Station
  • Supported Image Format : BMP, JPG (jpe, jpeg), GIF, RAW (arw, srf, sr2, dcr, k25, kdc, cr2, crw, nef, mrw, ptx, pef, raf, 3fr, erf, mef, mos, orf, rw2, dng, x3f)
  • Supported Video Format : 3G2, 3GP, ASF, AVI, DAT, DivX, FLV, M4V, MOV, MP4, MPEG, MPG, QT, WMV, XviD, RM, RMVB, VOB, RV30, RV40, AC3, AMR, WMA3
    User can click and download the following video formats: RM, RMVB, VOB, RV30, RV40, AC3, AMR, WMA3, but not able to play it in Photo Station as compressed Flash video.
  • Audio Station
  • Supported Audio Format (USB Mode) : AAC, FLAC, M4A, MP3, Ogg Vorbis, WMA, WMA VBR
  • Supported Audio Format (Streaming Mode) : MP3, M4A, M4B
  • Supported Playlist Format : M3U, WPL
  • Internet Radio : SHOUTcast, Radioio
  • DLNA/UPnP Media Server
  • PS3/Xbox 360 Support
  • Supported Audio Format : AAC, FLAC, M4A, MP3, Ogg Vorbis, PCM, WAV, WMA, WMA VBR, WMA PRO, WMA
  • Supported Video Format : 3GP, 3G2, ASF, AVI, DAT, DivX, DVR-MS, ISO, M2T, M2TS, M4V, MKV, MP4, MPEG1, MPEG2, MPEG4, MTS, MOV, QT, SWF, TP, TRP, TS, VOB, WMV, XviD, RMVB (The actual playback capabilities may vary depending on the DLNA/UPnP client)
  • Supported Image Format : BMP, JPG (jpe, jpeg), GIF, ICO, PNG, PSD, TIF (tiff), UFO
  • Download Station
  • Supported Download Protocols : BT/HTTP/FTP/NZB/eMule
  • Custom BT Port Range
  • BT / eMule Bandwidth Control
  • iTunes Server
  • Supported Audio Format : MP3, M4A, M4P, WAV, AIF, The music in WAV and AIF format can be streamed, but the metadata (ex: title, album) may not be indexed on the iTunes
  • Supported Video Format : M4V, MOV, MP4
  • Print Server
  • Max Printer # : 2
  • Printing Protocols : LPR, CIFS, AppleTalk, Appel AirPrint, Multi Functional Print Server (Only PostScript USB printers are supported in MAC environment)
  • Packages Center
  • Directory Server
  • HiDrive Backup
  • Mail Station2
  • phpMyAdmin
  • VPN Server
  • Webalizer
  • Squeezebox Server
  • Syslog Server
  • WordPress
  • Time Backup
  • iPhone/Android Applications
  • DS photo+
  • DS audio
  • DS cam
  • DS file
  • DS finder
General
  • Networking Protocols
  • CIFS
  • AFP
  • NFS
  • FTP
  • WebDAV
  • iSCSI
  • Telnet
  • SSH
  • SNMP
  • File System
  • EXT4
  • EXT3(External Disk Only)
  • FAT (External Disk Only)
  • NTFS (External Disk Only)
  • Storage Management
  • Max Volume # : 256
  • Max File System Size : 16TB
  • Max iSCSI Target # : 10
  • Max iSCSI LUN # : 10
  • Supported RAID Type : Synology Hybrid RAID, Basic, JBOD, RAID 0, RAID 1
  • RAID Migration : Basic to RAID 1
  • Volume Expansion with Larger HDDs : RAID 1
  • File Sharing Capability
  • Max User Accounts : 512
  • Max Groups : 128
  • Max Shared Folder : 256
  • Max Concurrent Connections : 64
  • Windows Access Control List (ACL)
  • Windows ADS Domain Integration
  • Domain Users login via Samba/AFP/FTP/File Station
  • Backup Solutions
  • Network Backup
  • Local Backup
  • Desktop Backup (using Synology Data Replicator 3 or Apple Time Machine backup application)
  • Shared Folder Sync - Max task number : 2
  • Time Backup - Max task number : 2
  • Time Machine Backup (Mac)
  • Security
  • FTP over SSL/TLS
  • IP Auto-Block
  • Firewall
  • Encrypted Network Backup over Rsync
  • HTTPS Connection
  • Management
  • Auto DSM Upgrade
  • Administrator Group
  • Email Notification
  • SMS Notification
  • Customized User Quota
  • DDNS Support
  • IPv6 Support
  • PPPoE
  • Resource Monitor
  • UPS Management
  • Scheduled Power On/Off
  • Custom Management UI HTTP/HTTPS Ports
  • HDD Management
  • HDD Hibernation
  • S.M.A.R.T.
  • Dynamic Bad Sector Mapping
  • Utilities
  • Synology Assistant
  • Synology Data Replicator
  • Supported Clients
  • Windows XP onward
  • Mac OS X 10.5 onward
  • Ubuntu 9.04 onward
  • Supported Browsers
  • Chrome
  • Firefox
  • Internet Explorer : 7, 8, 9
  • Safari (MAC) : 4, 5
  • Supported Mobile Devices (Photo Station, File Station)
  • iPhone OS 2.2.1 onward
  • Android OS 1.5 onward
  • Windows Mobile (IE Mobile or Opera 9.0 onward)
  • Symbian OS 9.1, S60 3rd Edition onward
  • Language : Czech, Danish, Dutch, English, French, German, Hungarian, Italian, Japanese, Korean, Norwegian, Polish, Portuguese Brazil, Portuguese European, Russian, Simplified Chinese, Spanish, Swedish, Traditional Chinese, Turkish
Environment and Packaging
  • Environment
  • RoHS Compliant
  • Package Content
  • Main Unit X 1
  • Installation CD/DVD X 1
  • Welcome Note X 1
  • Assembling Kit X 1
  • AC Power Adapter X 1
  • AC Power Cord X 1
  • 2M RJ-45 LAN Cable X 1
  • Optional Accessories
  • Remote
  • Camera License Pack
  • Disk Holder : Type C
  • VS80
拆解完毕,谢谢观赏
本帖最近打赏记录:共28条打赏M币+153
只看该作者 1楼 发表于: 2013-08-21
离线antons
只看该作者 2楼 发表于: 2013-08-21
离线lovecj
只看该作者 3楼 发表于: 2013-08-21
离线ladenaiqq
只看该作者 4楼 发表于: 2013-08-21
离线shmilyuho
只看该作者 5楼 发表于: 2013-08-21
Re:还是一网络存储设备synology NAS安装硬盘顺便看看做工
离线baimianmomo
只看该作者 6楼 发表于: 2013-08-21
本帖最近打赏记录:共1条打赏M币+1
离线84848264
只看该作者 7楼 发表于: 2013-08-21
离线顺劲通信
只看该作者 8楼 发表于: 2013-08-21
只看该作者 9楼 发表于: 2013-08-21
