  • 2705阅读
  • 3回复
[鑫创]3S量产—软件提示成功但是没有写入ISO 文件,求助 [复制链接]
离线lonnieo
只看楼主 倒序阅读 我要置顶 楼主  发表于: 2013-09-06
量产了一个金士顿DataTraveler G2,软件量产提示成功了,但是ISO文件没写进去,一插U盘提示格式化光盘,求助
U盘信息如下:
  1. --------------- Device 1------------------
  2.   MP Tool Version : V2.182
  3.   INI File Name : 6690_TSB_D2.INI
  4.   Format Date : 2013-09-06 15:05:25
  5.   Flash Part No : Toshiba 43nm D2 MLC
  6.   CE-0, Flash ID=98-D5-94-32-76-54-0A
  7.   VID : 0x0951
  8.   PID : 0x1624
  9.   Vendor Name = Kingston
  10.   Product Name = DataTraveler G2
  11.   Serial Number = 00FF4770A471FD90645C2033
  12.   Volume Label = KINGSTON
  13.   F/W Version : 0xB1
  14.   ISP Version : V1.84
  15.   Flash R/W Timing : 25ns
  16.   Channel : Byte Mode
  17.   Homogeneous Mode : On
  18.   HID Function : Disable
  19.   Planes(F/W) : 2
  20.   Pages/Block : 128 pages
  21.   Max Current : 100 mA
  22.   Total Blocks : 2084
  23.   Bad Blocks : 4
  24.   Capacity : 3360192 Sectors, 1720418304 Bytes
  25.                    1680096 KBytes, 1640.72 MBytes, 1.60 GBytes
report如下:
  1. Starting Time: 15:05:19
  2. Device 1:0xB1
  3.     MP Version:2.182
  4.     INI_File_Name:6690_TSB_D2.INI
  5.     Random delay 0 msec
  6.     --- Download MP ISP ---
  7.     CE-0, Flash ID=98-D5-94-32-76-54-0A-00
  8.     Found BACKUP Table (000000BB-0001)
  9.     Found BACKUP Table (0000013B-0002)
  10.         Original Bad Block - 0:0x0151
  11.         Original Bad Block - 0:0x01BA
  12.         Original Bad Block - 0:0x04AF
  13.         Original Bad Block - 0:0x0806
  14.     Defect Table shows 2080 Good blocks, 4 Bad blocks
  15.     SafeErase (0,2084)
  16.         Erase failed Block - 0:0:0x0151
  17.         Erase failed Block - 0:0:0x01BA
  18.         Erase failed Block - 0:0:0x04AF
  19.         Erase failed Block - 0:0:0x0806
  20.         ---> Max Bad of Plane (2,2)
  21.         ---> Max BAD/DIE = 2
  22.     Total good blocks after SCAN: 2080 / 2084, Bad block=4
  23.     ==> 2-Plane mode
  24.     Max. Bad Block Allowed = 124(4)
  25.     Adjust Max LBA = 3911680, 3911616
  26.     MaxWindows=1/1910, MaxLBA=3911616, Size=1909 MB
  27.     Max BAD of one plane is 2 (62),2084,1,1
  28.     RootSector=0x1DC,Sec/Cluster=64, SuperPage=32 ---> Alignment=4
  29.     Boot Block=0x0001,0x0002
  30.     Lun0(3361472), Lun1(550144), Public=3361472, Secure=0, CDROM=550144
  31.     Special FE Config = 56-0B-00
  32.     --- Download ISP Code:C:\USERS\JASON OU\DOWNLOADS\3S6692_MP_VER2182\3S6692_MP_VER2182\ISP_CODE\6690_B1-A_20100520_V184_699C.BIN---
  33.     --- ISP Code installed.
  34.     Lun0(3361472), Lun1(550144), Public=3361472, Secure=0, CDROM=550144
  35.     Public,Secure,CDROM = 3361472,0,550144
  36.     SN=00FF4770A471FD90645C2033
  37.     === Preformat Done ===
  38.     Low Level Format DONE
  39.     Store INI/ERROR MSG to Block-0x0001:79.
  40.     LBATest 10M activate
  41.     CDROM image:C:\xp.iso
  42.     Total=3911616,CDROM=550144, PublicArea=3361344, SecureArea=0
  43.     Create SECURE(CDROM=1,Public=1641 MB,Secure=0 MB)
  44.       Write LBA(0x00334AC0,128) Fail !
  45.     Send [read data] command timeout 5 times !
  46.     --- T2 start ---
  47.     FW version is: 0xB1
  48.     Vendor ID is:0x0951
  49.     Product ID is:0x1624
  50.     Vendor=Kingston
  51.     Product=DataTraveler G2
  52.     Device capacity : 0 > 19558 > 0
  53.     --- T2 is done ---
  54.     Total Capacity: 3911616 sectors, 1909 MBytes
  55.     Elasped Time = 00:00:11
  56. Ending Time: 15:05:30
是啥情况啊?
拜谢了!
离线lonnieo
只看该作者 1楼 发表于: 2013-09-06
离线shuishou
只看该作者 2楼 发表于: 2013-09-06
回 1楼(lonnieo) 的帖子
本帖最近打赏记录:共1条打赏M币+5
离线wyyyzyq
只看该作者 3楼 发表于: 2013-09-06
本帖最近打赏记录:共1条打赏M币+5
