  • 2270阅读
  • 3回复
[鑫创]SSS6690 u盘量产失败求指点 [复制链接]
离线ziyizjy1314
只看楼主 倒序阅读 我要置顶 楼主  发表于: 2014-01-28
Device 1:0xB1
    MP Version:2.159
    INI_File_Name:6690_D2.INI
    Random delay 0 msec
    --- Download MP ISP ---
    CE-0, Flash ID=98-D5-94-32-76-54-0B-00
    CE-1, Flash ID=98-D5-94-32-76-54-0B-00
    Found BACKUP Table (000000BB-0001)
    Found BACKUP Table (0000013B-0002)
        Original Bad Block - 0:0x00B8
        Original Bad Block - 0:0x0120
        Original Bad Block - 0:0x02D1
        Original Bad Block - 0:0x04CB
        Original Bad Block - 0:0x059B
        Original Bad Block - 0:0x0613
        Original Bad Block - 0:0x06A7
        Original Bad Block - 0:0x06A9
        Original Bad Block - 0:0x07AB
        Original Bad Block - 0:0x07AC
        Original Bad Block - 1:0x0056
        Original Bad Block - 1:0x0065
        Original Bad Block - 1:0x006E
        Original Bad Block - 1:0x00D0
        Original Bad Block - 1:0x00DE
        Original Bad Block - 1:0x01C1
        Original Bad Block - 1:0x01C3
        Original Bad Block - 1:0x0264
        Original Bad Block - 1:0x071E
        Original Bad Block - 1:0x0800
        Original Bad Block - 1:0x0811
    Defect Table shows 4147 Good blocks, 21 Bad blocks
    SafeErase (0,2084)
        Erase failed Block - 0:0:0x00B8
        Erase failed Block - 0:0:0x0120
        Erase failed Block - 0:0:0x02D1
        Erase failed Block - 0:0:0x04CB
        Erase failed Block - 0:0:0x059B
        Erase failed Block - 0:0:0x0613
        Erase failed Block - 0:0:0x06A7
        Erase failed Block - 0:0:0x06A9
        Erase failed Block - 0:0:0x07AB
        Erase failed Block - 0:0:0x07AC
        ---> Max Bad of Plane (3,7)
    SafeErase (1,2084)
        Erase failed Block - 1:0:0x0056
        Erase failed Block - 1:0:0x0065
        Erase failed Block - 1:0:0x006E
        Erase failed Block - 1:0:0x00D0
        Erase failed Block - 1:0:0x00DE
        Erase failed Block - 1:0:0x01C1
        Erase failed Block - 1:0:0x01C3
        Erase failed Block - 1:0:0x0264
        Erase failed Block - 1:0:0x071E
        Erase failed Block - 1:0:0x0800
        Erase failed Block - 1:0:0x0811
        ---> Max Bad of Plane (7,4)
        ---> Max BAD/DIE = 7
    Total good blocks after SCAN: 4147 / 4168, Bad block=21
    ==> 2-Plane mode
    Max. Bad Block Allowed = 252(21)
    Adjust Max LBA = 7823360, 7823296
    MaxWindows=2/1910, MaxLBA=7823296, Size=3819 MB
    Max BAD of one plane is 7 (63),4168,1,2
    RootSector=0xF4B,Sec/Cluster=32, SuperPage=32 ---> Alignment=21
    Boot Block=0x0001,0x0002
    Lun0(7823296), Lun1(0), Public=7823296, Secure=0, CDROM=0
    Special FE Config = 54-0B-00
    --- Download ISP Code:C:\USERS\ZHANG\DESKTOP\20140128_023944434\6690_TSBD2_MP_V2159\ISP_CODE\6690_B1-A_20110908_V150B_78E3.BIN---
    --- ISP Code installed.
    Public,Secure,CDROM = 7823296,0,0
    SN=0CD2922A024CF411C773202C
    === Preformat Done ===
    Low Level Format DONE
    Store INI/ERROR MSG to Block-0x0001:79.
    Total=7823296,CDROM=0, PublicArea=7823168, SecureArea=0
    ### Err: SECURE failed(32).
Ending Time: 15:16:19
怎么设定
[ 此帖被czwhehehe在2014-01-28 18:38重新编辑 ]
离线shuishou
只看该作者 1楼 发表于: 2014-01-28
本帖最近打赏记录:共1条打赏M币+5
离线wszhl
只看该作者 2楼 发表于: 2014-01-30
[ 此帖被wszhl在2014-01-30 13:24重新编辑 ]
本帖最近打赏记录:共1条打赏M币+5
只看该作者 3楼 发表于: 2014-01-30
本帖最近打赏记录:共1条打赏M币+5
