  • 3920阅读
  • 2回复
求助,关于3s 6677优盘的问题 提示错误为Error8 [复制链接]
离线泡泡龙pp
只看楼主 倒序阅读 我要置顶 楼主  发表于: 2009-03-01
     我在用USB Mass Production Test(m)  2.094制作启动盘的时候总是出错。错误为Error8 。我把其中的报告复制了出来
Starting Time: 18:49:54
Device 1:0xA3
    Random delay 0 msec
    Flash ID:89-D5-94-3E-74
    Intel/Micron Flash
    Hynix/ST/Intel/Micron Flash 05-E0 must be OFF
    ==> Check SORTING TABLE ...
        Sorting Info: 0-0FFF, Solid State System, Flash Sorting Kit V3.0-KTC(2008-01-09)(2 defect table mode)
        ==> Using Sortig Table (4075).
    Intel/Micron Flash
    --> Erase All Block Activated.
    Total good blocks after SCAN: 4075 / 4096
    Activate 6677A2-Intel/Micron workaround
    parameter 2-Plane = 1,0
    PreFormat Option=ID1,255,80,0,1,0,0,5-S111-T0000
    =>Extra reserved block = 5
    =>Max Card Size Enable, Bad Block Allowed=21(21)
    Data block = 3988 / 86 / 4096
    RootSector=0x234,ClusterOffset=1452,Sec/Cluster=64,Boundary=2048
    Enable gDIRC:
    Save SETTING to 003FF458
    Write CIS data.
    Low Level Format DONE
    Store ERROR MSG to Block-0x0FFF.
    =A3=> ................................
    Total=4083711,PublicArea=4083583, SecureArea=0
    Create SECURE(CDROM=0,Public=1993 MB,Secure=0 MB)
    --- T2 start ---
    FW version is: 0xA3
    Vendor ID is:0x0951
    Product ID is:0x1613
    Vendor=Kingston
    Product=DataTraveler2.0
    Device capacity : 0 > 20417 > 0
    DOS Volume=KINGSTON
    Device is formatted.
    --- T2 is done ---
    Total Capacity: 4083711 sectors, 1993 MBytes
    Elasped Time = 00:00:30
Ending Time: 18:50:24
我是没辙了,请哪位有本事的朋友帮帮忙吧,看看怎么解决,先谢谢啦。
关键词: CDROMDOS
离线arscrc
只看该作者 1楼 发表于: 2009-03-01
本帖最近打赏记录:共1条打赏
离线泡泡龙pp
只看该作者 2楼 发表于: 2009-03-04
