Array
  • 3379阅读
  • 3回复
[WiFi]请大神们帮我看看 按那个健 中断呢 [复制链接]
离线zggo
只看楼主 倒序阅读 我要置顶 楼主  发表于: 2014-06-20
请大神们帮我看看 按那个健 中断呢
请大神们帮我看看 按那个健 中断呢
AR7161 CPU 680MHz, DDR 340MHz, AHB 170MHz
+Ethernet eth1: MAC address ff:ff:ff:ff:ff:ff
IP: 192.168.1.2/255.255.255.0, Gateway: 0.0.0.0
Default server: 192.168.1.1
RedBoot(tm) bootstrap and debug environment [ROMRAM]
Non-certified release, version UNKNOWN - built 10:58:18, May  6 2011
Copyright (C) 2000, 2001, 2002, 2003, 2004 Red Hat, Inc.
Board: JA76PF2HX
RAM: 0x80000000-0x83ff0000, [0x80050b50-0x83fd1000] available
FLASH: 0xbf000000 - 0xbfff0000, 256 blocks of 0x00010000 bytes each.
== Executing boot script in 3.000 seconds - enter ^C to abort
RedBoot> fis load -d vmlinux.bin.gz;exec
Image loaded from 0x80060000-0x802be086
Now booting linux kernel:
Base address 0x80050000 Entry 0x8029a000
Cmdline : console=ttyS0,115200 root=31:02 rootfstype=jffs2 init=/sbin/init lm75.force=0,0x48 board=ja76hx
Linux version 2.6.15--LSDK-7.3.0.387 (blackdragon@aqlinux) (gcc version 3.4.4) #202 Fri Apr 22 08:53:14 HKT 2011
flash_size passed from bootloader = 16
arg 1: console=ttyS0,115200 root=31:02 rootfstype=jffs2 init=/sbin/init lm75.force=0,0x48 board=ja76hx
CPU revision is: 00019374
Determined physical RAM map:
memory: 02000000 @ 00000000 (usable)
User-defined physical RAM map:
memory: 04000000 @ 00000000 (usable)
Built 1 zonelists
Kernel command line: console=ttyS0,115200 root=31:02 rootfstype=jffs2 init=/sbin/init lm75.force=0,0x48 board=ja76hx mem=64M
Unknown boot option `lm75.force=0,0x48': ignoring
Primary instruction cache 64kB, physically tagged, 4-way, linesize 32 bytes.
Primary data cache 32kB, 4-way, linesize 32 bytes.
Synthesized TLB refill handler (20 instructions).
Synthesized TLB load handler fastpath (32 instructions).
Synthesized TLB store handler fastpath (32 instructions).
Synthesized TLB modify handler fastpath (31 instructions).
Cache parity protection disabled
PID hash table entries: 512 (order: 9, 8192 bytes)
Using 340.000 MHz high precision timer.
Console: colour dummy device 80x25
Dentry cache hash table entries: 16384 (order: 4, 65536 bytes)
Inode-cache hash table entries: 8192 (order: 3, 32768 bytes)
Memory: 61952k/65536k available (1898k kernel code, 3544k reserved, 377k data, 148k init, 0k highmem)
Mount-cache hash table entries: 512
Checking for 'wait' instruction...  available.
NET: Registered protocol family 16
Generic PHY: Registered new driver
AR7100 GPIOC major 0
JFFS2 version 2.2. (NAND) (C) 2001-2003 Red Hat, Inc.
Initializing Cryptographic API
io scheduler noop registered
io scheduler deadline registered
Serial: 8250/16550 driver $Revision: #1 $ 4 ports, IRQ sharing disabled
serial8250.0: ttyS0 at MMIO 0x0 (irq = 19) is a 16550A
RAMDISK driver initialized: 1 RAM disks of 8192K size 1024 blocksize
Searching for RedBoot partition table in ar7100-nor0 at offset 0xfe0000
7 RedBoot partitions found on MTD device ar7100-nor0
Creating 7 MTD partitions on "ar7100-nor0":
0x00000000-0x00040000 : "RedBoot"
0x00040000-0x00160000 : "vmlinux.bin.gz"
0x00160000-0x00f60000 : "rootfs.squashfs"
0x00f60000-0x00fd0000 : "config"
0x00fd0000-0x00fe0000 : "board-config"
0x00fe0000-0x00fef000 : "FIS directory"
mtd: partition "FIS directory" doesn't end on an erase block -- force read-only
0x00fef000-0x00ff0000 : "RedBoot config"
mtd: partition "RedBoot config" doesn't start on an erase block boundary -- force read-only
Creating 1 MTD partitions on "ar7100-nor0":
0x00fe0000-0x00ff0000 : "fisconfig"
u32 classifier
    Perfomance counters on
    OLD policer on
NET: Registered protocol family 2
IP route cache hash table entries: 1024 (order: 0, 4096 bytes)
TCP established hash table entries: 4096 (order: 2, 16384 bytes)
TCP bind hash table entries: 4096 (order: 2, 16384 bytes)
TCP: Hash tables configured (established 4096 bind 4096)
TCP reno registered
TCP bic registered
NET: Registered protocol family 10
lo: Disabled Privacy Extensions
IPv6 over IPv4 tunneling driver
NET: Registered protocol family 17
802.1Q VLAN Support v1.8 Ben Greear <greearb@candelatech.com>
All bugs added by David S. Miller <davem@redhat.com>
VFS: Mounted root (jffs2 filesystem) readonly.
Freeing unused kernel memory: 148k freed
init started:  BusyBox v1.4.2 (2011-04-22 14:34:32 HKT) multi-call binary
Algorithmics/MIPS FPU Emulator v1.5
Mounting file systems
ln: /etc/resolv.conf: File exists
chown: unknown user/group root:root
Device version is the newest.
AP
in ap83 pro_ctl_mod init
HX-7161
no such device type
ag7100_mod: module license 'unspecified' taints kernel.
AG7100: Length per segment 512
AG7100: Max segments per packet 4
AG7100: Max tx descriptor count    400
AG7100: Max rx descriptor count    252
AG7100: fifo cfg 3 018001ff
AG7100CHH: Mac address for unit 0
AG7100CHH: ff:ff:ff:ff:ff:ff
AG7100CHH: Mac address for unit 1
AG7100CHH: 00:15:61:91:60:3b
ath_hal: 0.9.17.1 (AR5212, AR5416, RF5111, RF5112, RF2413, RF5413, RF2316, RF2317, DEBUG, REGOPS_FUNC, WRITE_EEPROM, 11D)
wlan: 0.8.4.2 (Atheros/multi-bss)
ath_dfs: Version 2.0.0
Copyright (c) 2005-2006 Atheros Communications, Inc. All Rights Reserved
ath_rate_atheros: Copyright (c) 2001-2005 Atheros Communications, Inc, All Rights Reserved
ath_dev: Copyright (c) 2001-2007 Atheros Communications, Inc, All Rights Reserved
ath_pci: 0.9.4.5 (Atheros/multi-bss)
PCI: Enabling device 0000:00:00.0 (0000 -> 0002)
dfs_init_radar_filters: Unknown dfs domain 0
!!!!! SC Callback Registration for wifi0
wifi0: Atheros 9280: mem=0x10000000, irq=48 hw_base=0xb0000000
PCI: Enabling device 0000:00:01.0 (0000 -> 0002)
!!!!! SC Callback Registration for wifi1
wifi1: Atheros 9280: mem=0x10010000, irq=49 hw_base=0xb0010000
wlan: mac acl policy registered
wlan_sms4: Version 1.0.1
Copyright (c) 2001-2007 IWNCOMM Communications, Inc, All Rights Reserved
interface eth1 does not exist!
interface eth0 does not exist!
ag7100_ring_alloc Allocated 4800 at 0x8311c000
ag7100_ring_alloc Allocated 3024 at 0x802b1000
AG7100: cfg1 0x7 cfg2 0x7014
AG7100: unit 0: phy not up carrier 1
Writing 4
ADDRCONF(NETDEV_UP): eth0: link is not ready
ag7100_ring_alloc Allocated 4800 at 0x830ea000
ag7100_ring_alloc Allocated 3024 at 0x83c42000
AG7100: cfg1 0xf cfg2 0x7014
athrs16_reg_init complete.
AG7100: unit 1: phy not up carrier 1
Writing 6
ADDRCONF(NETDEV_UP): eth1: link is not ready
device eth0 entered promiscuous mode
device eth1 entered promiscuous mode
chown: /www: Read-only file system
chown: /usr/lib/web: Read-only file system
hostapd config dir ok
killall: udhcpc: no process killed
dev.wifi0.thinap = 1
wtp.log.txt ok
AG7100: unit 1 phy is up...RGMii 100Mbps full duplex
phy_mode_setup
AG7100: pll reg 0x18050014: 0x1099  AG7100: cfg_1: 0x1ff0000
AG7100: cfg_2: 0x3ff
AG7100: cfg_3: 0x18001ff
AG7100: cfg_4: 0xffff
AG7100: cfg_5: 0x7ffef
AG7100: done cfg2 0x7115 ifctl 0x10000 miictrl 0x10
ADDRCONF(NETDEV_CHANGE): eth1: link becomes ready
default: port 2(eth1) entering learning state
default: topology change detected, propagating
default: port 2(eth1) entering forwarding state
bind: Bad file descriptor
/sbin/mini_httpd: started as root without requesting chroot(), warning only
    Company Name:WUHAN HONGXIN TELECOMMUNICATION TECHNOLOGIES CO., LTD
              SN:000001120700695
         Ap Mode:thinap
     Device Type:FH-AP2400-20AN
             MAC:00:26:7A:21:58:00
Software Version:3.5.12
Hardware Version:2.5
system check:
mount check ok !
Usa
Please press Enter to activate this console.
离线lookball
只看该作者 1楼 发表于: 2014-06-20
离线zggo
只看该作者 2楼 发表于: 2014-06-20
离线fhqpl9
只看该作者 3楼 发表于: 2014-06-21
Array
