  • 9067阅读
  • 25回复
[SandForce]新手做个2281-64G SSD [复制链接]
离线wt186
只看楼主 倒序阅读 我要置顶 楼主  发表于: 2014-07-01
之前无意得到16G的金胜SSD装个WIN7x64就爆红了,
后来看到坛友出2281的拆机板,就入了一个,苦逼攒不够F,关键是等不急想自己折腾个固态体验一把
刷了一个礼拜交易区那天发现有人出平板拆机F,想下价格实惠就入了8片,老板送1片
到货后立马焊F,因卖家说用安国清空过,所以一次性全贴上,
因在公司做测试对于这点芯片还是很自信,全贴再用酒精清洗
微距神器,x10倍PEAK 目镜
中间开卡在AMD台式机上FC14一直问题不断,
后来问了下坛里大神才知道FC在AMD平台会出现莫名其妙的一堆问题,
然后果断换到自己的i5的4740G本本上,安装完各种工具后点下开始出现进度条,满心期待的等......
进度跑到85%左右冒红出现崩溃英文,顿时心都凉半截,果断打开LOG查找原因,
后来和PDF里对比也没找到问题,就拷出LOG关机准备发帖求助坛友:现贴上望大神帮忙解答
SandForce Genesis Utility v1.5.21.20110919-fc14-32bit
SF_Core Library: v1.7.0.20110919-fc14-32bit
Copyright 2010-2011, SandForce Inc., All Rights Reserved Worldwide.
[Tue 07/01/2014 03:19:08] - SF_Genesis has been invoked with the following parameters:
                      argv[1]: -PROCESS_SSD
                      argv[2]: 1:0:0:0
                      argv[3]: /root/ssd/mpt/FW_SF-2000_MP_3-3-0_Client--123456/FW_SF-2000_MP_3-3-0_Client.123456.mfp
                      argv[4]: /root/ssd/mpt/FW_SF-2000_MP_3-3-0_Client--123456/Configuration_Files/SandForce/22214.123456.driveconfig
                      argv[5]: 123321
                      argv[6]: 456789
                      argv[7]: LOG=/root/ssd/mpt/123321_wu_DATETIMESTAMP_1.0.0.0_PROCESS_SSD_RESULT.log
[Tue 07/01/2014 03:19:08] - Instructing the operating system to purge any existing cached data for device: '1:0:0:0'
[Tue 07/01/2014 03:19:13] - Issuing a discovery command for device: '1:0:0:0'
[Tue 07/01/2014 03:19:18] - Discovery command completed...
[Tue 07/01/2014 03:19:18] - Waiting 5 seconds for the system to settle...
[Tue 07/01/2014 03:19:23] - Device designation string '1:0:0:0' is mapped to node '/dev/sg1'
[Tue 07/01/2014 03:19:23] - Proceeding to process SSD device with the following parameters:
              DeviceName = /dev/sg1
    MFP Package Filename = /root/ssd/mpt/FW_SF-2000_MP_3-3-0_Client--123456/FW_SF-2000_MP_3-3-0_Client.123456.mfp
      Configuration File = /root/ssd/mpt/FW_SF-2000_MP_3-3-0_Client--123456/Configuration_Files/SandForce/22214.123456.driveconfig
              Serial No. = 123321
         World Wide Name = 456789
[Tue 07/01/2014 03:19:23] - Successfully received the IDENTIFY data from the drive...
[Tue 07/01/2014 03:19:24] - Successfully opened the package: /root/ssd/mpt/FW_SF-2000_MP_3-3-0_Client--123456/FW_SF-2000_MP_3-3-0_Client.123456.mfp
[Tue 07/01/2014 03:19:24] - Successfully extracted *.DriveConfig file: /root/ssd/mpt/FW_SF-2000_MP_3-3-0_Client--123456/Configuration_Files/SandForce/22214.123456.driveconfig
[Tue 07/01/2014 03:19:24] - Extracted Config_ID: 1 (22214) in DriveConfig file: /root/ssd/mpt/FW_SF-2000_MP_3-3-0_Client--123456/Configuration_Files/SandForce/22214.123456.driveconfig
[Tue 07/01/2014 03:19:24] - Extracted SerialOutputControl: 0
[Tue 07/01/2014 03:19:24] - Successfully extracted Config record: 22214
[Tue 07/01/2014 03:19:24] - Successfully extracted flashware image: 22214_fw_cl_mlc_Micron_64Gb_MT29F64G08CBAAAWP_2Q_1C_1D_PP_R00751_s512.vic
[Tue 07/01/2014 03:19:24] - Successfully extracted manufacturing image: 22214_mf_mlc_Micron_64Gb_MT29F64G08CBAAAWP_2Q_1C_1D_PP_R00751_s512.vic
[Tue 07/01/2014 03:19:24] - Proceeding in non-ROM mode, Download feature 7...
[Tue 07/01/2014 03:19:25] - Successfully downloaded MFB to the drive...
[Tue 07/01/2014 03:19:25] - Waiting (5 sec) for the drive to settle...
[Tue 07/01/2014 03:19:30] - Successfully received the IDENTIFY data from the drive...
[Tue 07/01/2014 03:19:30] - Firmware revision reported to be: '330ABBM0'.  This indicates MFB download was successful.
[Tue 07/01/2014 03:19:30] - Successfully enabled SMART capabilities...
[Tue 07/01/2014 03:19:31] - Successfully issued a diagnostic unlock...
[Tue 07/01/2014 03:19:31] - Performing the flash test of block 0 (0x0000)...
[Tue 07/01/2014 03:19:33] - Flash Test Results:
Flash Test Parameters:
               Block Count: 0
                Page Count: 1
                 Bus Count: 2
        Chip Enabled Count: 1
                 Die Count: 1
                Lane Count: 4
               Plane Count: 2
Results Notes:
   N1 - At least one page tested and passed with no bit errors.
   N2 - No test data available.  Test may have aborted, or failed during the testing.
   N3 - At least one page tested and had errors less than or equal to half the range of ECC correction power.
   N4 - At least  one erased page tested had bit error rate greater than half the correction power.
   N5 - Walking zeros test failed.
   N6 - Walking ones test failed.
   N7 - Block contained factory bad block markings and testing was skipped.
   N8 - At least one page tested and had bit error rate greater than the correction power on plane 0.
   N9 - Block in plane 0 was marked as a factory bad block.
  N10 - At least one page tested and had bit error rate greater than the correction power on plane 1.
  N11 - Block in plane 1 was marked as a factory bad block.
| Bus  | CE   | Die  | Lane | Value  | Result Notes                               | Overall |
| 0    | 0    | 0    | 0    | 0x0003 | N1,N3                                      | WARNING |
| 0    | 0    | 0    | 1    | 0x0002 | N3                                         | WARNING |
| 0    | 0    | 0    | 2    | 0x0002 | N3                                         | WARNING |
| 0    | 0    | 0    | 3    | 0x0003 | N1,N3                                      | WARNING |
| 1    | 0    | 0    | 0    | 0x0002 | N3                                         | WARNING |
| 1    | 0    | 0    | 1    | 0x0002 | N3                                         | WARNING |
| 1    | 0    | 0    | 2    | 0x0002 | N3                                         | WARNING |
| 1    | 0    | 0    | 3    | 0x0002 | N3                                         | WARNING |
  Total Number of test results: 8
            Number of failures: 0
         Number of Passed with warnings: 8
      No. Passed without warnings: 0
[Tue 07/01/2014 03:19:34] - Performing the FORMAT Command with the following parameters:
         MemoryWearCycleCapability = 0
              CurrentPE_CycleCount = 0
                     LifeInSeconds = 0
                   LogicalCapacity = 125045424
                        SectorSize = 512
             SectorAlignmentOffset = 0
                  ExpectedMemoryID = 34860 (0x882C)
                   ExpectedNumDies = 0
               SerialOutputControl = 0
                           Time[8] = 0x0000000000000000
            MiscFlag_Erase_R_Block = 0
     MiscFlag_PanicHandlingEnabled = 0
        MiscFlag_PanicOnSATA_Error = 0
  MiscFlag_WriteThrottlingTestMode = 0
      MiscFlag_DisableUserBandECCX = 1
                        L_PageSize = 0
                        E_PageSize = 0
              ErrorCorrectionPower = 0
      ConfigDeviceReadDisturbCount = 0
   ConfigDeviceReadDisturbCountLow = 0
[Tue 07/01/2014 03:19:52] - FORMAT command completed...
[Tue 07/01/2014 03:19:52] - Waiting (2 sec) for the drive to settle...
[Tue 07/01/2014 03:19:54] - Setting up the stamp information through CDU command...
[Tue 07/01/2014 03:19:57] - Waiting (2 sec) for the drive to settle...
[Tue 07/01/2014 03:19:59] - Downloading the flashware to the drive...
[Tue 07/01/2014 03:20:00] - Successfully downloaded flashware to the drive...
[Tue 07/01/2014 03:20:00] - Waiting (15 sec) for the drive to settle...
[Tue 07/01/2014 03:20:15] - Successfully received the IDENTIFY data from the drive...
[Tue 07/01/2014 03:20:15] - Firmware revision reported to be: 'NC      '
[Tue 07/01/2014 03:20:15] - Enabling SMART support...
[Tue 07/01/2014 03:20:15] - Issuing a diagnostic unlock to the drive...
[Tue 07/01/2014 03:20:16] - Setting up Max LBA settings...
[Tue 07/01/2014 03:20:20] - Applying the remaining ConfigUniqueDrive settings...
[Tue 07/01/2014 03:20:22] - Setting 'Configuration ID' to '22214'
[Tue 07/01/2014 03:20:22] - Setting 'Customer ID' to '123456'
[Tue 07/01/2014 03:20:22] - Setting 'Model No.' to 'Sandforce_sf2281_64g'
结果关机进入 window7后直接提示安装驱动弹出发现磁盘,
需要从新引导扇区点确定然后格式化出现盘符???
惊喜啊,这样也行?然后测试后截图
SATA2下AS
换到AMD台式机SATA3上的AS,和三棒840EVO对比
虽然跑分低,但是4K机械没得比,附上ATTO图
最后来一个DiskInfo截图,健康为0,SSD寿命为0,大神看下什么问题?
本帖提到的人: @剧毒
本帖最近打赏记录:共4条打赏 ,M币+23
离线wt186
只看该作者 1楼 发表于: 2014-07-01
离线kasumi777
只看该作者 2楼 发表于: 2014-07-01
本帖最近打赏记录:共1条打赏 ,M币+1
离线qhdxfws
只看该作者 3楼 发表于: 2014-07-01
本帖最近打赏记录:共2条打赏 ,M币+8
离线yuexiu
只看该作者 4楼 发表于: 2014-07-01
离线huakun888
只看该作者 5楼 发表于: 2014-07-01
离线zimu887
只看该作者 6楼 发表于: 2014-07-01
离线lcfcl
只看该作者 7楼 发表于: 2014-07-01
离线nfy123
只看该作者 8楼 发表于: 2014-07-01
离线guoke1930
只看该作者 9楼 发表于: 2014-07-01
