Array
  • 5757阅读
  • 10回复
[SandForce]2281开卡失败 求教~ [复制链接]
离线nfy123
只看楼主 倒序阅读 我要置顶 楼主  发表于: 2014-07-07
[ni@localhost ~]$ su
密码:
su: 密码不正确
密码:
[root@localhost ni]# cd sf
[root@localhost sf]# ./SF_Genesis -PROCESS_SSD 3:0:0:0 /home/ni/fw/FW_SF-2000_MP_5-0-7_Client.1.mfp /home/ni/fw/Configuration_Files/22119.1.driveconfig 12345 www_123 log=
SandForce Genesis Utility v1.5.21.20110919-fc14-32bit
SF_Core Library: v1.7.0.20110919-fc14-32bit
Copyright 2010-2011, SandForce Inc., All Rights Reserved Worldwide.
[Mon 07/07/2014 08:38:37] - SF_Genesis has been invoked with the following parameters:
                      argv[1]: -PROCESS_SSD
                      argv[2]: 3:0:0:0
                      argv[3]: /home/ni/fw/FW_SF-2000_MP_5-0-7_Client.1.mfp
                      argv[4]: /home/ni/fw/Configuration_Files/22119.1.driveconfig
                      argv[5]: 12345
                      argv[6]: www_123
                      argv[7]: log=
[Mon 07/07/2014 08:38:37] - Instructing the operating system to purge any existing cached data for device: '3:0:0:0'
[Mon 07/07/2014 08:38:42] - Issuing a discovery command for device: '3:0:0:0'
[Mon 07/07/2014 08:38:48] - Discovery command completed...
[Mon 07/07/2014 08:38:48] - Waiting 5 seconds for the system to settle...
[Mon 07/07/2014 08:38:53] - Device designation string '3:0:0:0' is mapped to node '/dev/sg1'
[Mon 07/07/2014 08:38:53] - Proceeding to process SSD device with the following parameters:
              DeviceName = /dev/sg1
    MFP Package Filename = /home/ni/fw/FW_SF-2000_MP_5-0-7_Client.1.mfp
      Configuration File = /home/ni/fw/Configuration_Files/22119.1.driveconfig
              Serial No. = 12345
         World Wide Name = www_123
[Mon 07/07/2014 08:38:53] - Successfully received the IDENTIFY data from the drive...
SF_Internal_PackageManager::OpenExisting:
                     HeaderCRC32: -1448548789,(A9A8E64B)
     _Package.Header.HeaderCRC32: -1448548789,(A9A8E64B)
                    OverallCRC32: -246870280,(F1490EF8)
    _Package.Header.OverallCRC32: -246870280,(F1490EF8)
[Mon 07/07/2014 08:38:55] - Successfully opened the package: /home/ni/fw/FW_SF-2000_MP_5-0-7_Client.1.mfp
[Mon 07/07/2014 08:38:55] - Successfully extracted *.DriveConfig file: /home/ni/fw/Configuration_Files/22119.1.driveconfig
[Mon 07/07/2014 08:38:55] - Extracted Config_ID: 1 (22119) in DriveConfig file: /home/ni/fw/Configuration_Files/22119.1.driveconfig
[Mon 07/07/2014 08:38:55] - Extracted SerialOutputControl: 0
[Mon 07/07/2014 08:38:55] - Successfully extracted Config record: 22119
[Mon 07/07/2014 08:38:55] - Successfully extracted flashware image: 22119_fw_cl_slc_Toshiba_16Gb_TH58TAG6S2FBA89_2Q_4C_1D_PP_R00473_s512.vic
[Mon 07/07/2014 08:38:55] - Successfully extracted manufacturing image: 22119_mf_slc_Toshiba_16Gb_TH58TAG6S2FBA89_2Q_4C_1D_PP_R00473_s512.vic
[Mon 07/07/2014 08:38:55] - Proceeding in ROM mode, download feature 1...
[Mon 07/07/2014 08:38:55] - Successfully downloaded MFB to the drive...
[Mon 07/07/2014 08:38:55] - Waiting (5 sec) for the drive to settle...
[Mon 07/07/2014 08:39:00] - Successfully received the IDENTIFY data from the drive...
[Mon 07/07/2014 08:39:00] - Firmware revision reported to be: '507ABBM0'.  This indicates MFB download was successful.
[Mon 07/07/2014 08:39:00] - Successfully enabled SMART capabilities...
[Mon 07/07/2014 08:39:02] - Successfully issued a diagnostic unlock...
[Mon 07/07/2014 08:39:02] - Performing the flash test of block 0 (0x0000)...
[Mon 07/07/2014 08:45:54] - Flash Test Results:
Flash Test Parameters:
               Block Count: 3
                Page Count: 1
                 Bus Count: 0
        Chip Enabled Count: 1
                 Die Count: 0
                Lane Count: 0
               Plane Count: 0
Results Notes:
   N1 - At least one page tested and passed with no bit errors.
   N2 - No test data available.  Test may have aborted, or failed during the testing.
   N3 - At least one page tested and had errors less than or equal to half the range of ECC correction power.
   N4 - At least  one erased page tested had bit error rate greater than half the correction power.
   N5 - Walking zeros test failed.
   N6 - Walking ones test failed.
   N7 - Block contained factory bad block markings and testing was skipped.
   N8 - At least one page tested and had bit error rate greater than the correction power on plane 0.
   N9 - Block in plane 0 was marked as a factory bad block.
  N10 - At least one page tested and had bit error rate greater than the correction power on plane 1.
  N11 - Block in plane 1 was marked as a factory bad block.
| Bus  | CE   | Die  | Lane | Value  | Result Notes                               | Overall |
  Total Number of test results: 0
            Number of failures: 0
         Number of Passed with warnings: 0
      No. Passed without warnings: 0
[Mon 07/07/2014 08:45:54] - FATAL_ERROR: Could not perform the DiagIdentify() operation on the drive... (0x12000004:SF_SG_HOST_BAD_TARGET_ERROR)
[Mon 07/07/2014 08:45:54] - End of Genesis manufacturing log.
[Mon 07/07/2014 08:45:54] - Exiting...
[Mon 07/07/2014 08:45:54] - Overall Result for Device: /dev/sg1 ****** FAIL ******
这是日志~ 失败原因不明  求指导~
离线guoke1930
只看该作者 1楼 发表于: 2014-07-07
离线kasumi777
只看该作者 2楼 发表于: 2014-07-07
离线cylnpy
只看该作者 3楼 发表于: 2014-07-07
离线jacythomas
只看该作者 4楼 发表于: 2014-07-07
离线剧毒
只看该作者 5楼 发表于: 2014-07-07
离线qhdxfws
只看该作者 6楼 发表于: 2014-07-07
离线ssdtools
只看该作者 7楼 发表于: 2014-07-07
本帖最近打赏记录:共1条打赏M币+5
离线剧毒
只看该作者 8楼 发表于: 2014-07-07
离线wt186
只看该作者 9楼 发表于: 2014-07-08
Array
