  • 37384阅读
  • 20回复
[电源]松下BQ-830充电器缺陷召回令及改造方法 [复制链接]
离线mymo
只看楼主 倒序阅读 我要置顶 楼主  发表于: 2009-04-18
— 本帖被 mydigit 从 数码大家谈 移动到本区(2013-10-14) —
原创作者:小宣-天堂雨林
手头有一款松下BQ830(BQ-830)充电器已经使用了蛮久了,最近闲着没事干,上网查询了与之有关的几乎是所有能够查询到的资料,甚至包括了松下公司的召回令都详细阅读过了,见下图:
松下召回令-图
其实这份召回令描述的问题并不严重,全文英文原文如下:
November 10 , 2004
RE : Panasonic Rechargeable Battery Club kit
Dear Valued Consumer
In the event that you have recently purchased a Panasonic rechargeable battery system , model # BQ - 830A / 10KC , we would like to inform you that your charger contains a component that under certain abnormal conditions will cause the charger to stop charging your batteries before they are fully charged . This condition will occur where room temperatures are closer to 95 degrees ( Fahrenheit ) .
This phenomenon does not  cause the batteries or the charger to overheat , smoke , burn or explode . But this may reduce the usage life ofthe batteries and in some applications the battery may not produce sufficient power to allow for the operation ofthe device . In the most extreme case , leakage of the batteries could occur if you use fully charged and less charged batterics mixed together .
For your convenience we offer two options on how you can receive a new replacement battery charger .
option1: Please return the charger and batteries along with kit components to your local Costco Wholesale Club for a full refund of your purchase .
option2 : Please contact Panasonic National Parts Center at 1-800-332-5368 to get a new replacement battery charger sent to you .
We apologize for the inconvenience , and hope that you will again consider purchasing Panasonic products when you have future battery and electronics needs .
中文大意我翻译为:
2004年11月10日
回复:松下电池充电器套装
亲爱的消费者
万一您最近购买了松下充电器,型号为#bq-830a/10kc,我们想通知您,您的充电器其中的一个部分,在某些异常情况,会导致充电器停充电池之前,处于一个完全充电的状态。这种情况将发生在房间的温度接近华氏95度(即摄氏35度)。
这种现象不会导致电池或充电器过热,烟雾,烧伤或爆炸。不过这可能会减少电池的使用寿命,还有在某些应用场合中,电池可能无法产生足够的动力,以便让装置运作。
在最极端的情况下,如果您将充满的电池和未充满的电池进行混充,电池可能发生泄漏。
为了您的方便,我们提供了两种选择,你如何能得到一个新的更换充电器。
选项1:请返回充电器和电池随着原装组件到您的本地松下公司或商店,将全额退还您的购买资金。
选项2:请联系松下全球服务中心1-800-332-5368 ,以得到一个新的电池充电器发送给您。
给您带来的不便,我们深表歉意,希望你们未来有电池和电子产品的需求时,将再次考虑购买松下的产品。
从召回令得知,此款充电器的问题发生在快充满电时,室温超过35摄氏度时,还有电池情况不同却混充时。
而查阅了网友们的资料,其实这款充电器还存在的问题有:
充电过热,损坏电池;
电池容易拒充——对某些明明是充电电池的却显示不能充电;
USB接口形同虚设,不能用电脑的USB口为之提供电源来充电,症状为对所有电池拒充;
对镍氢电池的充电电压判断可能存在误差,所以可能会出现冲得过满或是没有充满便停充的情况;
液晶显示没有夜光功能,液晶查看不方便。
针对液晶显示的背光问题,我已经在之前加了背光解决,而USB接口充电嘛,从来没有用过,也不推荐使用USB接口充电,因为觉得难看~当然,我还是尝试了一次,确实是对所有电池拒充。而充电过热问题,我不知道到底什么是叫过热,因为我觉得只要充电,电池都会很热,这就要考验充电电池的耐热质量了~
但是DIY精神弄得很手痒,于是乎,针对网友们提出的并联R32的改小充电电流的办法,我对充电器进行了如下改造。
首先,R32是一个470Ω的贴片电阻,万用表量其两端电阻值为392Ω(这是电路板上的电阻值),我的并联电阻方法原理图为:
而这两个开关应该放在哪里好呢?观察来观察去,发现充电器底部有几个位置简直就是留给作DIY用的,如下图:
看到没,就放在这里啦,大家可能没看到并联的电阻,其实已经焊在了开关的脚上,用的是很小的贴片电阻~
而电阻并联PCB上的哪个电阻呢?建议不懂得话网上查一查,R32电阻,如下图:
虽然看起来不是并联在R32上,其实连线选择的位置只是为了美观而已,这两个点就是R32的并联点,其实还与图中的那个8脚IC中的3、4脚并联。最终效果图如下图所示:
从此我的充电器就变成了燕子尾啦~哇哈哈……
燕子尾特写
通过开关的4种组合,总共R32两端的实测电阻分别为392Ω、281Ω、213Ω、175Ω,而充电电流也可以在1.6A至0.2A间变化,如下表所示:
下表都是估算电流,并没有实测,但是效果实际充电降温效果是有的,调至较小电流充电时,电池发热确实不如以前明显了,并且将南孚碱性电池放进去都可以显示充电,但是好像存在一个问题,如果充电电流太小的话,当电池充满3格时,由于电流取样电阻R46电流太小,电压达不到MCU的负电压差停充要求,可能就会徘徊在第三格一直充电了,就是说不能判断已经充满了,这是需要调整为较大电流充电,便能很快判断正确,显示4格已充满了~
本帖最近打赏记录:共3条打赏
hddlfz M币 +9 謝謝分享 2018-08-11
965039114 M币 +5 謝謝分享 2018-08-11
链接 M币 +13 謝謝分享 2018-08-11
壹切皆有可能 M币 +20 謝謝分享 2018-05-31
链接 M币 +13 謝謝分享 2018-05-30
离线victor2002
只看该作者 1楼 发表于: 2009-04-18
本帖最近打赏记录:共2条打赏
离线victor2002
只看该作者 2楼 发表于: 2009-04-18
本帖最近打赏记录:共2条打赏
离线tonywawd
只看该作者 3楼 发表于: 2009-04-20
离线hendao
只看该作者 4楼 发表于: 2009-04-23
本帖最近打赏记录:共1条打赏
离线shazhou
只看该作者 5楼 发表于: 2009-04-26
本帖最近打赏记录:共1条打赏
离线chenbangyong
只看该作者 6楼 发表于: 2009-04-27
离线zmxaaa
只看该作者 7楼 发表于: 2009-04-27
离线bg518
只看该作者 8楼 发表于: 2010-05-30
离线adsl_95
只看该作者 9楼 发表于: 2010-05-30
