  • 9385阅读
  • 5回复
[联阳]UT165 量产工具错误代码翻译(修正版) [复制链接]
离线mynamezp
只看楼主 倒序阅读 我要置顶 楼主  发表于: 2010-09-25
— 本帖被 發騷友 从 U盘量产工具 移动到本区(2010-09-26) —
不知道有人发过没有,找到这个翻译比较全的。
Error code definition                 ---错误代码定义
Code Name           Definition
0x10        Disk can't be formated as the selected file system                                              选择的文件系统使磁盘无法格式化
0x11        Disk mounted flash chips doesn't match the setting                                           程式加载的闪存和程式设定不一致
0x12        (1)Disk size does't match the setting (2)Disk is zero size (Unknown flash)   (1)磁盘大小和程式设定不符 (2)磁盘大小为零(未知的Flash型号)
0x13        Disk is write-protected        磁盘写保护
0x14        Mounted flash product ID is not matched                                                               磁盘和程式加载到的ID不符
0x28        Run SCSI command Failed        运行SCSI命令失败
0x41        ISP / CIS blk search Failed        ISP / CIS 模块搜索失败
0x42        Build flash LUT Failed        建立闪存LUT失败
0x44        Bad block count is out of range        坏块数量超出设定界限
0x48        Bad block count exceed tolerance        坏块数量太多以致超出(正常量产所需)的界限
0x51        Single/Dual channel check Failed        单通道/双通道检查失败
0x54        (1)Firmware version mismatch with controller type (2)Firmware is not found (1)固件版本和主控类型不匹配  (2)固件未找到
0x58        Bad block count of table is not match with number of scanned bad block       坏块数量表和扫描到的坏块数量不一致
0x61        Rebuild Flash BAD Blk Failed        重建闪存坏块表失败
0x62        Autorun Image Error        自动运行镜像错误
0x64        Sensor Error        识别错误
0x68        Erase Block Failed        擦除块失败
0x72        Initialize ISP Failed        初始化ISP失败
0x74        Check Disk Information Failed        检查磁盘信息失败
0x78        Update Disk Information Failed        更新磁盘信息失败
0x81        ISO Volume is exhausted        无效的镜像卷标
0x82        Flash Manufacture checking error        闪存检测错误
0x84        Sensor Get Image Failed        识别镜像失败
0x88        Run Disk Stress R/W Failed        运行磁盘读写错误
0x91        Clear Hidden Blk Failed        擦除隐藏块失败
0x92        Source folder doesn't exist or source file is missing                                           源文件不存在或源文件丢失
0x94        Check Disk MBR/FAT Failed        检查磁盘 MBR/FAT失败
0x98        Format Disk Failed        磁盘格式化失败
0xa1        Size of source files is large than partition size during running                          源文件大小超出正在运行的分区的容量
0xa2        Partition Setting Error        分区设定错误
0xa3        Serial number out of range        序列号超出设定范围
0xa4        Size of source files is large than partition size                                                      源文件大小超出分区容量
0xa8        Copy Files Failed        复制文件失败
UT163/UT165打开隐藏功能&常见问题代码解决方法 http://bbs.mydigit.cn/read.php?tid=67120
关键词: UT163UT165
离线sujos
只看该作者 1楼 发表于: 2010-09-26
离线最爱甜甜
只看该作者 2楼 发表于: 2010-10-04
回 楼主(mynamezp) 的帖子
离线xdfdnzhabo
只看该作者 3楼 发表于: 2011-04-23
离线sonic7216
只看该作者 4楼 发表于: 2011-04-23
Re:回 楼主(mynamezp) 的帖子
离线sonic7216
只看该作者 5楼 发表于: 2011-04-23
