Starting command:[/root/ssd/soft/SF_Genesis/SF_Genesis -PROCESS_SSD 0:0:0:0 "/root/ssd/Mpt/27762/FW_PPRO_6_0_A_Release.1134440.release_2--123456/FW_PPRO_6_0_A_Release.1134440.release_2.123456.mfp" "/root/ssd/Mpt/27762/FW_PPRO_6_0_A_Release.1134440.release_2--123456/Configuration_Files/27762.123456.driveconfig" 123456 78900 LOG="/root/ssd/log/123456_localhost.localdomain_DATETIMESTAMP_0.0.0.0_PROCESS_SSD_RESULT.log" ]...
SandForce Genesis Utility v1.7.0.01020130612-fc14-32bit
SF_Core Library: v1.7.1.20130612-fc14-32bit
Copyright 2010-2012, LSI Corporation, All Rights Reserved Worldwide.
[Sun 11/11/2018 04:39:32] - SF_Genesis has been invoked with the following parameters:
argv[1]: -PROCESS_SSD
argv[2]: 0:0:0:0
argv[3]: /root/ssd/Mpt/27762/FW_PPRO_6_0_A_Release.1134440.release_2--123456/FW_PPRO_6_0_A_Release.1134440.release_2.123456.mfp
argv[4]: /root/ssd/Mpt/27762/FW_PPRO_6_0_A_Release.1134440.release_2--123456/Configuration_Files/27762.123456.driveconfig
argv[5]: 123456
argv[6]: 78900
argv[7]: LOG=/root/ssd/log/123456_localhost.localdomain_DATETIMESTAMP_0.0.0.0_PROCESS_SSD_RESULT.log
[Sun 11/11/2018 04:39:32] - Instructing the operating system to purge any existing cached data for device: '0:0:0:0'
[Sun 11/11/2018 04:39:37] - Issuing a discovery command for device: '0:0:0:0'
[Sun 11/11/2018 04:39:42] - Discovery command completed...
[Sun 11/11/2018 04:39:42] - Waiting 5 seconds for the system to settle...
[Sun 11/11/2018 04:39:47] - Device designation string '0:0:0:0' is mapped to node '/dev/sg0'
[Sun 11/11/2018 04:39:47] - Proceeding to process SSD device with the following parameters:
DeviceName = /dev/sg0
MFP Package Filename = /root/ssd/Mpt/27762/FW_PPRO_6_0_A_Release.1134440.release_2--123456/FW_PPRO_6_0_A_Release.1134440.release_2.123456.mfp
Configuration File = /root/ssd/Mpt/27762/FW_PPRO_6_0_A_Release.1134440.release_2--123456/Configuration_Files/27762.123456.driveconfig
Serial No. = 123456
World Wide Name = 78900
[Sun 11/11/2018 04:39:48] - Successfully received the IDENTIFY data from the drive...
[Sun 11/11/2018 04:39:48] - Validating Manufacturing Firmware Package: /root/ssd/Mpt/27762/FW_PPRO_6_0_A_Release.1134440.release_2--123456/FW_PPRO_6_0_A_Release.1134440.release_2.123456.mfp
[Sun 11/11/2018 04:39:48] - Successfully opened the package: /root/ssd/Mpt/27762/FW_PPRO_6_0_A_Release.1134440.release_2--123456/FW_PPRO_6_0_A_Release.1134440.release_2.123456.mfp
[Sun 11/11/2018 04:39:48] - file /root/ssd/Mpt/27762/FW_PPRO_6_0_A_Release.1134440.release_2--123456/Configuration_Files/27762.123456.driveconfig Loaded successfully
[Sun 11/11/2018 04:39:48] - Warning: Unable to query diagnostics information to perform power management settings check
[Sun 11/11/2018 04:39:48] - B01 Power Management configuration request detected
[Sun 11/11/2018 04:39:48] - Successfully extracted *.DriveConfig file: /root/ssd/Mpt/27762/FW_PPRO_6_0_A_Release.1134440.release_2--123456/Configuration_Files/27762.123456.driveconfig
[Sun 11/11/2018 04:39:48] - Extracted Config_ID: 1 (27762) in DriveConfig file: /root/ssd/Mpt/27762/FW_PPRO_6_0_A_Release.1134440.release_2--123456/Configuration_Files/27762.123456.driveconfig
[Sun 11/11/2018 04:39:48] - Extracted SerialOutputControl: 0
[Sun 11/11/2018 04:39:48] - Searching for flashware image for configuration 27762
[Sun 11/11/2018 04:39:48] - Manifest found for configuration 27762
[Sun 11/11/2018 04:39:48] - Flashware image extracted: 27762_fw_cl_mlc_Intel_64Gb_X29F64B08XCMF3_2Q_2C_2D_PP_R01951_s512.vic
[Sun 11/11/2018 04:39:48] - Searching for manufacturing image for configuration 27762
[Sun 11/11/2018 04:39:48] - Manufacturing image extracted: 27762_mf_mlc_Intel_64Gb_X29F64B08XCMF3_2Q_2C_2D_PP_R01951_s512.vic
[Sun 11/11/2018 04:39:48] - Proceeding in ROM mode, download feature 3...
[Sun 11/11/2018 04:39:48] - Successfully downloaded MFB to the drive...
[Sun 11/11/2018 04:39:48] - Waiting (5 sec) for the drive to settle...
[Sun 11/11/2018 04:39:53] - Successfully received the IDENTIFY data from the drive...
[Sun 11/11/2018 04:39:53] - Firmware revision reported to be: '60AABBM0'. This indicates MFB download was successful.
[Sun 11/11/2018 04:39:53] - Successfully enabled SMART capabilities...
[Sun 11/11/2018 04:39:55] - Successfully issued a diagnostic unlock...
[Sun 11/11/2018 04:39:56] - Performing the flash test of block 0 (0x0000)...
[Sun 11/11/2018 04:39:57] - Flash Test Results:
Flash Test Parameters:
Block Count: 0
Page Count: 1
Bus Count: 2
Chip Enabled Count: 2
Die Count: 2
Lane Count: 4
Plane Count: 2
Results Notes:
N1 - At least one page tested and passed with no bit errors.
N2 - No test data available. Test may have aborted, or failed during the testing.
N3 - At least one page tested and had errors less than or equal to half the range of ECC correction power.
N4 - At least one erased page tested had bit error rate greater than half the correction power.
N5 - Walking zeros test failed.
N6 - Walking ones test failed.
N7 - Block contained factory bad block markings and testing was skipped.
N8 - At least one page tested and had bit error rate greater than the correction power on plane 0.
N9 - Block in plane 0 was marked as a factory bad block.
N10 - At least one page tested and had bit error rate greater than the correction power on plane 1.
N11 - Block in plane 1 was marked as a factory bad block.
| Bus | CE | Die | Lane | Value | Result Notes | Overall |
| 0 | 0 | 0 | 0 | 0x0374 | N4,N5,N6,N8,N10 | FAIL |
| 0 | 0 | 0 | 1 | 0x0374 | N4,N5,N6,N8,N10 | FAIL |
| 0 | 0 | 0 | 2 | 0x0374 | N4,N5,N6,N8,N10 | FAIL |
| 0 | 0 | 0 | 3 | 0x0374 | N4,N5,N6,N8,N10 | FAIL |
| 0 | 0 | 1 | 0 | 0x0001 | N1 | PASS |
| 0 | 0 | 1 | 1 | 0x0001 | N1 | PASS |
| 0 | 0 | 1 | 2 | 0x0001 | N1 | PASS |
| 0 | 0 | 1 | 3 | 0x0001 | N1 | PASS |
| 0 | 1 | 0 | 0 | 0x0374 | N4,N5,N6,N8,N10 | FAIL |
| 0 | 1 | 0 | 1 | 0x0374 | N4,N5,N6,N8,N10 | FAIL |
| 0 | 1 | 0 | 2 | 0x0374 | N4,N5,N6,N8,N10 | FAIL |
| 0 | 1 | 0 | 3 | 0x0374 | N4,N5,N6,N8,N10 | FAIL |
| 0 | 1 | 1 | 0 | 0x0001 | N1 | PASS |
| 0 | 1 | 1 | 1 | 0x0001 | N1 | PASS |
| 0 | 1 | 1 | 2 | 0x0001 | N1 | PASS |
| 0 | 1 | 1 | 3 | 0x0001 | N1 | PASS |
| 1 | 0 | 0 | 0 | 0x0374 | N4,N5,N6,N8,N10 | FAIL |
| 1 | 0 | 0 | 1 | 0x0374 | N4,N5,N6,N8,N10 | FAIL |
| 1 | 0 | 0 | 2 | 0x0374 | N4,N5,N6,N8,N10 | FAIL |
| 1 | 0 | 0 | 3 | 0x0374 | N4,N5,N6,N8,N10 | FAIL |
| 1 | 0 | 1 | 0 | 0x0001 | N1 | PASS |
| 1 | 0 | 1 | 1 | 0x0001 | N1 | PASS |
| 1 | 0 | 1 | 2 | 0x0001 | N1 | PASS |
| 1 | 0 | 1 | 3 | 0x0001 | N1 | PASS |
| 1 | 1 | 0 | 0 | 0x0374 | N4,N5,N6,N8,N10 | FAIL |
| 1 | 1 | 0 | 1 | 0x0374 | N4,N5,N6,N8,N10 | FAIL |
| 1 | 1 | 0 | 2 | 0x0374 | N4,N5,N6,N8,N10 | FAIL |
| 1 | 1 | 0 | 3 | 0x0374 | N4,N5,N6,N8,N10 | FAIL |
| 1 | 1 | 1 | 0 | 0x0001 | N1 | PASS |
| 1 | 1 | 1 | 1 | 0x0001 | N1 | PASS |
| 1 | 1 | 1 | 2 | 0x0001 | N1 | PASS |
| 1 | 1 | 1 | 3 | 0x0001 | N1 | PASS |
Total Number of test results: 32
Number of failures: 16
Number of Passed with warnings: 0
No. Passed without warnings: 16
[Sun 11/11/2018 04:39:57] - End of Genesis manufacturing log.
[Sun 11/11/2018 04:39:57] - Exiting...
[Sun 11/11/2018 04:39:57] - Overall Result for Device: /dev/sg0 ****** FAIL ******
Process exited with code 7
=============================================================================SSD 为 威刚 SP900 Premier Pro 256G (主控 SF2281 VB2-SPC)
20nm的颗粒,256G的只有几款,所以,经排查,锁定为 SF-2281-Gold 256GB Intel20nm MLC BGA 4xX29F64B08XCMF3 (RAISE OFF) 官方固件包中也有此VIC固件 在坛子里一直学习,也不知道设置是否有问题,先放上截图 FW包,用的论坛下的 FW_PPRO_6_0_A_Release.1134440.release_2.dfp (3.5G)
Lic文件,用的生成器
开卡时去掉了短接。下面链接为主板照片和故障原因
http://bbs.mydigit.cn/read.php?tid=2580863 Linux 版本为 Fedora-18-i386-DVD.iso 是直接安装到硬盘的,SSD也是直接接到笔记本的SATA接口上,没有使用虚拟机和USB
全部信息都在这里了,恳请大神帮助。
