  • 7846阅读
  • 24回复
[SandForce]蛤蛤!我的2241vb4   sp900s7 有结果出来了 [复制链接]
离线ctnet
只看楼主 倒序阅读 我要置顶 楼主  发表于: 2018-12-06
[ctnet@6   ~]$ su
密码:
[root@6   ctnet]# lsscsi
[0:0:0:0]    disk    ATA      SILICONMOTION SM 2015  /dev/sda
[1:0:0:0]    disk    ATA      SandForce{200026 402A  /dev/sdb
[root@6   ctnet]# ./SF_Genesis -PROCESS_SSD 1:0:0:0 /home/ctnet/ssd/mpt/FW_PPRO_6_0_A_Release.1134440.release--123456/FW_PPRO_6_0_A_Release.1134440.release.123456.mfp  /home/ctnet/ssd/mpt/FW_PPRO_6_0_A_Release.1134440.release--123456/Configuration_Files/28064.123456.ct.edriveconfig 12345 www_ 123 log=/home/ctnet/ssd/ssd.log
bash: ./SF_Genesis: 没有那个文件或目录
[root@6   ctnet]# dir
asiacom_SF-2000_20120629_lic.lic  公共的  视频    未保存文档\ 1  下载  桌面
ssd                  模板      图片    文档           音乐
SandForce Genesis Utility v1.7.0.01020130612-fc14-32bit
SF_Core Library: v1.7.1.20130612-fc14-32bit
Copyright 2010-2012, LSI Corporation, All Rights Reserved Worldwide.
[Thu 12/06/2018 21:43:22] - SF_Genesis has been invoked with the following parameters:
                      argv[1]: -PROCESS_SSD
                      argv[2]: 1:0:0:0
                      argv[3]: /home/ctnet/ssd/mpt/FW_PPRO_6_0_A_Release.1134440.release--123456/FW_PPRO_6_0_A_Release.1134440.release.123456.mfp
                      argv[4]: /home/ctnet/ssd/mpt/FW_PPRO_6_0_A_Release.1134440.release--123456/Configuration_Files/28064.123456.ct.edriveconfig
                      argv[5]: 12345
                      argv[6]: www_
                      argv[7]: 123
                      argv[8]: log=/home/ctnet/ssd/ssd.log
[Thu 12/06/2018 21:43:22] - Instructing the operating system to purge any existing cached data for device: '1:0:0:0'
[Thu 12/06/2018 21:43:27] - Issuing a discovery command for device: '1:0:0:0'
[Thu 12/06/2018 21:43:32] - Discovery command completed...
[Thu 12/06/2018 21:43:32] - Waiting 5 seconds for the system to settle...
[Thu 12/06/2018 21:43:37] - Device designation string '1:0:0:0' is mapped to node '/dev/sg1'
[Thu 12/06/2018 21:43:37] - Proceeding to process SSD device with the following parameters:
              DeviceName = /dev/sg1
    MFP Package Filename = /home/ctnet/ssd/mpt/FW_PPRO_6_0_A_Release.1134440.release--123456/FW_PPRO_6_0_A_Release.1134440.release.123456.mfp
      Configuration File = /home/ctnet/ssd/mpt/FW_PPRO_6_0_A_Release.1134440.release--123456/Configuration_Files/28064.123456.ct.edriveconfig
              Serial No. = 12345
         World Wide Name = www_
[Thu 12/06/2018 21:43:37] - Successfully received the IDENTIFY data from the drive...
[Thu 12/06/2018 21:43:37] - Validating Manufacturing Firmware Package: /home/ctnet/ssd/mpt/FW_PPRO_6_0_A_Release.1134440.release--123456/FW_PPRO_6_0_A_Release.1134440.release.123456.mfp
[Thu 12/06/2018 21:43:44] - Successfully opened the package: /home/ctnet/ssd/mpt/FW_PPRO_6_0_A_Release.1134440.release--123456/FW_PPRO_6_0_A_Release.1134440.release.123456.mfp
[Thu 12/06/2018 21:43:44] - File : /home/ctnet/ssd/mpt/FW_PPRO_6_0_A_Release.1134440.release--123456/Configuration_Files/28064.123456.ct.edriveconfig in processing ...
[Thu 12/06/2018 21:43:44] - file  /home/ctnet/ssd/mpt/FW_PPRO_6_0_A_Release.1134440.release--123456/Configuration_Files/28064.123456.ct.edriveconfig Loaded successfully
[Thu 12/06/2018 21:43:44] - Warning:  Unable to query diagnostics information to perform power management settings check
[Thu 12/06/2018 21:43:44] - B01 Power Management configuration request detected
[Thu 12/06/2018 21:43:44] - Successfully extracted *.DriveConfig file: /home/ctnet/ssd/mpt/FW_PPRO_6_0_A_Release.1134440.release--123456/Configuration_Files/28064.123456.ct.edriveconfig
[Thu 12/06/2018 21:43:44] - Extracted Config_ID: 1 (28064) in DriveConfig file: /home/ctnet/ssd/mpt/FW_PPRO_6_0_A_Release.1134440.release--123456/Configuration_Files/28064.123456.ct.edriveconfig
[Thu 12/06/2018 21:43:44] - Extracted SerialOutputControl: 0
[Thu 12/06/2018 21:43:44] - Searching for flashware image for configuration 28064
[Thu 12/06/2018 21:43:44] - Manifest found for configuration 28064
[Thu 12/06/2018 21:43:44] - Flashware image extracted: 28064_fw_cl_mlc_Micron_32Gb_MT29F128G08CBACAWP_1Q_2C_1D_S_PP_R01182_s512.vic
[Thu 12/06/2018 21:43:44] - Searching for manufacturing image for configuration 28064
[Thu 12/06/2018 21:43:44] - Manufacturing image extracted: 28064_mf_mlc_Micron_32Gb_MT29F128G08CBACAWP_1Q_2C_1D_S_PP_R01182_s512.vic
[Thu 12/06/2018 21:43:44] - Proceeding in ROM mode, download feature 3...
[Thu 12/06/2018 21:43:45] - Successfully downloaded MFB to the drive...
[Thu 12/06/2018 21:43:45] - Waiting (5 sec) for the drive to settle...
[Thu 12/06/2018 21:43:50] - Successfully received the IDENTIFY data from the drive...
[Thu 12/06/2018 21:43:50] - Firmware revision reported to be: '60AABBM0'.  This indicates MFB download was successful.
[Thu 12/06/2018 21:43:50] - Successfully enabled SMART capabilities...
[Thu 12/06/2018 21:43:52] - Successfully issued a diagnostic unlock...
[Thu 12/06/2018 21:43:53] - Performing the flash test of block 0 (0x0000)...
[Thu 12/06/2018 21:43:54] - Flash Test Results:
Flash Test Parameters:
               Block Count: 0
                Page Count: 1
                 Bus Count: 1
        Chip Enabled Count: 2
                 Die Count: 1
                Lane Count: 4
               Plane Count: 2
Results Notes:
   N1 - At least one page tested and passed with no bit errors.
   N2 - No test data available.  Test may have aborted, or failed during the testing.
   N3 - At least one page tested and had errors less than or equal to half the range of ECC correction power.
   N4 - At least  one erased page tested had bit error rate greater than half the correction power.
   N5 - Walking zeros test failed.
   N6 - Walking ones test failed.
   N7 - Block contained factory bad block markings and testing was skipped.
   N8 - At least one page tested and had bit error rate greater than the correction power on plane 0.
   N9 - Block in plane 0 was marked as a factory bad block.
  N10 - At least one page tested and had bit error rate greater than the correction power on plane 1.
  N11 - Block in plane 1 was marked as a factory bad block.
| Bus  | CE   | Die  | Lane | Value  | Result Notes                               | Overall |
| 0    | 0    | 0    | 0    | 0x0374 | N4,N5,N6,N8,N10                            |    FAIL |
| 0    | 0    | 0    | 1    | 0x0374 | N4,N5,N6,N8,N10                            |    FAIL |
| 0    | 0    | 0    | 2    | 0x0374 | N4,N5,N6,N8,N10                            |    FAIL |
| 0    | 0    | 0    | 3    | 0x0374 | N4,N5,N6,N8,N10                            |    FAIL |
| 0    | 1    | 0    | 0    | 0x0374 | N4,N5,N6,N8,N10                            |    FAIL |
| 0    | 1    | 0    | 1    | 0x0374 | N4,N5,N6,N8,N10                            |    FAIL |
| 0    | 1    | 0    | 2    | 0x0374 | N4,N5,N6,N8,N10                            |    FAIL |
| 0    | 1    | 0    | 3    | 0x0374 | N4,N5,N6,N8,N10                            |    FAIL |
  Total Number of test results: 8
            Number of failures: 8
         Number of Passed with warnings: 0
      No. Passed without warnings: 0
[Thu 12/06/2018 21:43:54] - End of Genesis manufacturing log.
[Thu 12/06/2018 21:43:54] - Exiting...
[Thu 12/06/2018 21:43:54] - Overall Result for Device: /dev/sg1 ****** FAIL ******
[root@6   ctnet]#
好像是flash不对吧??
本帖提到的人: @6
离线ctnet
只看该作者 1楼 发表于: 2018-12-06
离线perter
只看该作者 2楼 发表于: 2018-12-06
离线fangyinghh
只看该作者 3楼 发表于: 2018-12-06
离线ctnet
只看该作者 4楼 发表于: 2018-12-07
离线ctnet
只看该作者 5楼 发表于: 2018-12-07
[ 此帖被ctnet在2018-12-07 12:19重新编辑 ]
离线ctnet
只看该作者 6楼 发表于: 2018-12-07
离线lanwuwu
只看该作者 7楼 发表于: 2018-12-07
离线ctnet
只看该作者 8楼 发表于: 2018-12-07
回 lanwuwu 的帖子
离线fangyinghh
只看该作者 9楼 发表于: 2018-12-07
